Question about Konica Minolta Office Equipment & Supplies
7135 DEVELOPER IS EMPTY IN 2 DAYS - Konica Minolta Office Equipment & Supplies
  • 106 Answers
Have a possible cause developing unit ,charging unit ,transfer unit
Posted on Jun 08, 2011
Hooper assembly is not working in coping but working in 47 mode
remove the drum assy. and have the the drum and developer replaced along with having the drum and developer assy. cleaned and the senors that are on the assy, then have the proper procedures run after the developer and drum are installed, ALSO have the counters reset to let the copier know that new developer and drum have been replaced
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 10, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
Hooper Assy on off Code
sir/mam
Remove the drum assy. and have the the drum and developer replaced along with having the drum and developer assy. cleaned and the senors that are on the assy, then have the proper procedures run after the developer and drum are installed, ALSO have the counters reset to let the copier know that new developer and drum have been replaced
Apr 10, 2014 | Konica Minolta Office Equipment & Supplies
Empty Developer on MP1900
Should replace the TYPE 28 DEVELOPER every 60,000 pages.... this is needed to mix with the toner. if you cleaned the toner/ developer mix out of the developer already then it will definatly give you blank pages ..... hopefully this helps.
Mar 13, 2014 | Ricoh Office Equipment & Supplies
Flashing red flight
Its probably the cleaning light that comes on periodically to remind you to clean the unit. Shut off the unit AND when you do so hold down the power button for several seconds until the flashing red light shuts off. The cleaning light should stay off until the next cleaning is due.
Per the Air-O-Swiss FAQ:
Q: Cleaning light is flashing (AOS U650, AOS 7135, AOS 7142, AOS 7144, AOS 7147)
A: Switch the unit OFF and unplug it. Empty the water in the base. Rinse the base with hot/clean water. Do not submerge the base! Visually inspect the base for dirt or mineral build up. If soft water is used decalcifying the unit every 4 weeks with EZ Cal is suggested. If hard water is used the unit should be decalcified every 2 weeks. Do not forget to reset the clean light after resetting the unit.
Q: Reset cleaning light (AOS U650, AOS 7135, AOS 7142, AOS 7144, AOS 7147)
A: The cleaning light does not automatically reset. Hold down the power button (button A in instruction manual) until the light stops flashing. The light automatically comes on approximately 14 days after plugging in the unit.
Feb 15, 2014 | Air-O-Swiss U7142 Humidifier
Pls give me a TV/FM 7135 drivers donwload address
The drivers for ASUS TV/FM 7135 can be download from the Asus Official support site: -
Click here and follow these steps: -
1. Select Product - Multimedia
2. Select Series - TV Tuner
3. Select Model -
TV/FM 7135 and click search, it would ask you for operating system
4. Select operating system and download drivers
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 06, 2010 | ASUS TV/FM 7135 (TVFM7135)
How to clean air-o-swiss humidifier?
Gererally according to the booklet in the box.
If you no longer have those instructions, simply clean out the
basin, make sure no mold, dust, hardwater or calcium is deposited.
Use a 10% bleach water solution to kill bacteria, and thats is basically it.
Just dont miss any spots, but humdifiers should be cleaned every few uses.
Feb 19, 2010 | Air-O-Swiss 7133 Humidifier
Needs maintenance
Maintenance doesn't necessarily mean developer replacement, if its working well, ignore developer and continue if it requires, pullout the developer unit and remove the toner hopper. Then empty the used developer and put new one. To empty, turn the dev unit upside down while rotating the magnet roller clockwise the return it in normal position and pour the new developer while turning the magnet roller clockwise until evenly distributed. Put back the toner hopper and screw back and install inside the copier then set it with 'P, Interrupt, C, Interrupt keys enter 25 press Start 2 then Execute key and allow to run till it stops then press Interrupt twice and Press 24 Start 3 Execute . Finally Switch OFF and ON.
May 07, 2009 | Sharp AR-407 Copier
Changing developer unit in afficio 450
Remove PCU, remove development unit, remove cover (2 plastic C-clips) remove filter, remove development roller (2 shoulder bolts). Clean roller and empty all developer. Pour in new developer, re-assemble unit. Reinstall drum and Development unit. Place a small piece of paper between the PCU and toner entrance hole to prevent used toner from entering dev. unit during calibration. Perform SP2-801. Remove paper form dev. unit
Apr 24, 2009 | Ricoh Aficio 450 Copier
Need to switch Kyocera 7135 from US Cellular to Alltel
there is nothing FIXYA can do for your situation . of course you could quit Alltel .
Nov 30, 2017 | Kyocera 7135 Handheld
RIcoh MP-4500
It's probably happening because the cleaning blade on the drum needs to be changed or replaced.
Oct 25, 2008 | Office Equipment & Supplies
44 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
