Question about Cameras
I have problem with my samsung digital camera always it shows a dcf full error on screen.
    President:
  • 1,607 Answers
Thanks for using fixya!
The problem is from your SD card. First make sure you have copied all the pictures to your computer.
Then, FORMAT your SD card using your samsung camera. (Don't format it on your computer)
I hope this helped you!
Posted on May 28, 2011
I am unable to take photo because of DCF full Erros come often ES30
This is what the manual says:
File names do not match the DCF standard.
Transfer the files on the memory card to your
computer, and then format the card. (p. 76)
Format in the camera, not in a cardslot of your computer.
Lots of errors, can be solved by removing and reinserting the battery(ies)
Nov 02, 2013 | Samsung ES30 Digital Camera
Why does Samsung WB150R reads DCF FULL ERROR when memory card is fitted
Hello, Is the memory card formatted by the camera ? Is the slide on the card set to protect ? Have you tried a different card ?
Jan 21, 2013 | Cameras
When I turn on my camera, in the middle of the screen in a black box it says " DCF full error" what does this mean and how do I get it to go away? I have tried resetting my camera and formatting...
Hello
Thank you for using FIXYA!!!
OK, firstly let me state what exactly the error message you are receiving concludes to:
"The "DCF full error" occurs when you use memory card in your camera which is formatted in another camera. The error is the result of improper formatting of the memory card which leads to incompatibility of the card with the Samsung camera."
Now, i the resolution for this specific problem is to format the memory card in the Samsung camera.
I know you stated that you have already formatted the card, but you did not state if you formatted the card in your camera, or on your computer.
Try the above solution and let me know if the problem still persists.
Please do not hesitate to let me know if you have any further questions.
Kind regards
lock123
May 24, 2011 | Samsung S860 Digital Camera
When l take my SD card, it still says " DCF Full Error"
Hello and Welcome
The DCF error message with your Samsung camera nearly always occurs when you're using a memory card that was formatted with a different camera, and the file format structure is not compatible with your Samsung camera. You will have to format the card with the Samsung camera.However, make sure you download any photos to your computer first
Anymore help, I am here to help
Best of Luck
Concerned:
Uxair Shah
Mar 14, 2011 | Samsung ES30 Digital Camera
When I take my SD card out, it still says "DCF
well as long as it works when u put the sd card in then its all good right?
also
  1. DCF Full Error error message. The DCF error message with your Samsung camera nearly always occurs when you're using a memory card that was formatted with a different camera, and the file format structure is not compatible with your Samsung camera. You'll have to format the card with the Samsung camera. However, make sure you download any photos to your computer first.
Mar 07, 2011 | Samsung ES30 Digital Camera
DCF Full Error
DCF = Digital Camera Full
Usually, that just means you have taken a lot of pictures/videos and your memory card is full.
You should transfer them to a computer via USB or by taking the memory card out and putting it directly into a computer.
If you continue to have problems after emptying the memory card, you may have a faulty memory card.
If you suspect you have a faulty memory card, you might try a different one.
Always try to use a trusted memory card brand (I prefer Sandisk).
Good luck, I hope I was able to help
Feb 28, 2011 | Samsung S860 Digital Camera
When the Camera is turned on it reads DCF Full Error. How can I fix this error?
.try to format both...
remove the sd card on your unit,then insert that to the mmc reader then format it to your pc,,after formatted.,,
open your unit without sd card,,go to menu - setting - format -reset
after that insert it to your unit.,then take atleast 15 shots.,.then turn it off.,.,then open again for you to find out if this procedure will okey.,
Feb 25, 2011 | Cameras
Our Samsung ES30 is showing a DCF Full Error. It is only 1 month old and has a 2gig SD card in it. What is the problem?
Feb 23, 2011 | Cameras
Tl220
camera and or card memory is full?
change card or download photos to computer or other media and delete from the card in the camera to make space for new photos.
Oct 22, 2009 | Samsung L200 Digital Camera
DCF Full Error
I have got a Samsung ES30 Digital camera .Everytime i turn it on it always says DCF Full Error ' which i have no idea means .Please help???
Sep 25, 2008 | Samsung S860 Digital Camera
Cameras Logo
146 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
