Dell 42 inch 4201 c
I purchased the tv about two years ago and after 14 months i turned it on one day and there were vertical line on the screen. after contacting dell a
service personel stated it sounded as if a buffer module may be the problem does this sound right and if so can repair the module or can i purchase one.
SOURCE:
  • 34 Answers
SOURCE: LG plasma TV
I would suggest having the Y and Z Sustain boards replaced
Posted on May 22, 2008
Kindofcheap
  • 241 Answers
SOURCE: 42inch LG plasma TV
well if you could please give out the model nuumber thank you
Posted on Sep 10, 2008
  • 23 Answers
SOURCE: plasma TV with vertical lines
EASY! ok the 4th video processing unit is malfunctioning, if it is a Piano affect like the keys on the piano, then that can be fixed under your 1year warrenty after your 1year warrenty it will cost $200, but i could be wrong, i never studied panasonic plasma casue they ****, next time get a samsung.
the worst contrast and video ajustments, thats a panasonic.
trust me i am the flat pannel guru!
Posted on May 02, 2009
  • 304 Answers
SOURCE: pink vertical line down my 42 inch digital plasma
I do believe the Panel is bad and needs to be replaced. Check with the manfacture to confirm this.
Posted on Jul 16, 2009
  • 10 Answers
SOURCE: red vertical line down right side of the screen
hi
I think your TV have a trouble inside lcd panel
the controller board contains driver IC. Deffective driver IC can cause of line display.
Three reasons why one vertical line accross screen can happen in LCD;
1.The missing signal from the controller IC to
LCD driver.
2. LCD driver IC itself defective
3. Dry contact in the tape carrier package.
Use masking or electrical tape to mark it where the line was located. press it if the line back to normal but when release your hand came back i think it was intermittent. Open the LCD panel
Use robber
Place the rubber on the top of TCP
Gently close back the top casing
Good luck...
Posted on Aug 21, 2009
Screen Goes Green, with Lines and jumps. 42LG30 1080p TV.
The TV is under a LG factory 1 year warranty.
Unless you bought a refurbished unit which has a 30 day warranty.
Contact LG @ 1 800 243-0000 for warranty repairs.
Be sure to have the...
Date of purchase
Model#
Serial#
And Product code.
The information is on the back of the TV or on a small white tag
on the side of the TV.
Jan 09, 2010 | LG 42LG30 42 in. LCD HDTV
PROSCAN 42' LCD COLOR TV MODEL 42LA45H
I am sorry Sir, the display panel is bad. If you purchased it new, it should under factory's warranty. Please call Proscan for a warranty repair.
Proscan Customer Service:
1-800-968-9853 (US and Canada)
May 31, 2017 | Proscan 42LA45H 42 in. LCD TV
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Vertical black line on the screen of my 42" Magnavox flat panel lcd tv
I wish I could post a solution, but I don't have one. I too have a Magnavox. About 6 months ago, once every 2 weeks or so, the screen would just go black- all but an inch or two on either side. Now, it seems like it's a weekly thing, sometimes every hour or two. As of tonight, it has happened twice in a matter of thirty minutes. It usually repairs itself if I turn it on and then off again but that's just not working anymore. If anyone has a solution, let me know.
Oct 10, 2008 | Televison & Video
No picture
i have the same problem. i took my tv to radioshack, and they said that they dont tale tvs that are bigger that 27 inches. so i took to one of these places that fix tv, they are charging me $270, beacuse they have to change the power supply and sometranssitors,
Sep 20, 2008 | Polaroid FLM-4201 42 in. LCD Television
Black line
Called ghost lines or banding. I researched on toshiba thread LCD screen bad. I have same problem purchased HL196 4/07 problem appeared 1 year and 9 months ago no extended warranty. If still under warranty call toshiba. LCD screen more expensive then orginal price of TV. Should file class action lawsuit for selling defective screens. Lot of people having same problem. goforth2953
Sep 09, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
1/2 the picture
Hello
You will have to a tec. for this one as you have lost half of your vertical sweep.
Sorry
guy9
Jun 16, 2008 | LG 42PX5D 42 in. Plasma HDTV
Vertical Black line 3 inch width on Plasma Samsung 42C96HD after 2 months of use
I also have the same problem I phoned Samsung today to explain the tv was only 14 months old, they didn't wanna no because it was out of warrenty by 2 months. I am getting a black solid line down the left hand side of the screen. I ended up phoning Dixons were we bought it from, they have told me to get an independent engineers report done & send the report to them within 14 days. Dixon told me it was a known problem with Samsungs. They said they will fix it free of charge if they can if not they will send vouchers to the same value of the television. So beware stay clear of Samsungs.
Feb 03, 2008 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Black screen, high pitched squeal
A set that has only a 1/2 inch bright line through the middle of the picture, from left to right, has a vertical output IC that is not working correctly. If the 1/2 inch line is in the middle but going up and down, then the horizontal yoke circuit has stopped working. These are problems which should be looked at by a qualified tech, but if the set was purchased 6 months ago then it should still be under the manufacturer's warranty.
Aug 29, 2007 | Philips Magnavox 20MT4405 20" TV
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Ekse
