Question about LG Televison & Video
NTSC ON MY FLAT LCD TV LOSE,WHAT WILL I DO,THERE IS NO SOUND YET.
  • 1,056 Answers
NTSC is a system. How can it be loose? Are you in america or in europe? Here in america we use NTSC system. In Europe I think they use PAL system. Other parts of the world uses SECAM system.
Posted on May 28, 2011
Ive retuned, re-set, unpluggest and plugged back in and i recieve no channeks still, been like this for months
What is your TV source? The Polaroid LCD-2000 only has a NTSC (analog) tuner. Most OTA stations switched to ATSC signals a few years ago and a converter box is required to watch the TV. (A few low power TV stations still broadcast in NTSC but you need to be fairly close to the transmitter to receive the channel.) If you have cable, check if they have migrated to digital cable (QAM for unencrypted channels). If that is the case, you'll need a cable box.
With a digital-to-analog OTA converter box, you can still lose station reception due to the signal strength cliff. Depending on your area, you may need an external antenna or to check the direction of the antenna. I know I have to rotate the outdoor antenna every so often. It shifts in high wind. Even if the antenna only moves 5 degrees, we will lose the signal for half of the stations.
I hope this helps.
Aug 10, 2015 | Polaroid LCD 2000 LCD2000 TV flat screen...
SANYO DP 42848 NTSC to PAL
The TV you specified here can only be used with NTSC system transmission or video data. If you wish to see PAL system signals by this tV, you've to buy PAL to NTSC converter, and should connect it according to connection diagram given along with the converter.
Oct 31, 2013 | Sanyo DP42848 LCD TV
Sony Bravia KDLnd -40S4100 purchsed at US and it is not functioning at Sharjah when electric connection is given. Only sound is comming and picture is not comming. Is there any convertor is available to...
The TV you have purchased from US, will be only meant to receive NTSC video signals. It will not work with PAL signals. No need to alter the TV circuits. Just try to get an NTSC to PAL converter, and connect it.
Sep 25, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
How can i make my samsung LCD TV pictures change fro black and white to coloured in ghana
Set is likely formatted by design for North America which is set up for NTSC transmission system and likely there it is PAL--both issues fit this. You will need a PAL (if system there) to NTSC converter box.
Jun 13, 2012 | Samsung LN37A550P LCD TV
Tv picking up channels except its all static, colorless, and loud static noise..
If the set was purchased in the USA it has the USA format which is NTSC--unless the signal is NTSC picture will be in black and white and no sound.
If the signal format there is PAL OR SECAM you will need a converter that takes that and outputs NTSC for the set to work properly there.
May 16, 2012 | Panasonic Viera TX-32LX70 32 in. LCD TV
I cannt get sound through the tv using cable. only works with DVD
i think you have the wrong receiver system
like pal, ntsc, pal i
it depends in witch country you live
Apr 07, 2010 | Coby TF DVD2294 LCD TV
Can't get sound in Asia
I think you may find that the NTSC & PAL formats my be incorrect, check.
Mar 27, 2010 | Sharp LC-32SB24U 32 in. LCD TV
Cant get dvd player to work on samsumg 6
check the cable and conexion that worked good.
check region dvd format/image for example ntsc or pal
check region tv format for example ntsc or pal
conect your dvd in other tv or lcd or crt and checking
conect your dvd in audio component or home sound
oh, read step by step the manual of tv and dvd manual...
bye....
Mar 07, 2010 | Samsung LA40A450 40 in. LCD TV
Hi,i bought philips lcd tv model-47pfl3609 from singapore.AT present its in philippines.it doesnt have ntsc-m function.please guide if any solution.thank you.
Tv,it not like a DVD player it have two regions PAL/NTSC,u out of luck tv it have only one region in tv.PAL or NTSC.
Oct 22, 2009 | Televison & Video
Convert ntsc to pal for sony bravia tv
While a modern PAL TV can display NTSC sources (namely DVD players and PAL VHS players that support pseudo-NTSC), an NTSC TV can not display a PAL source, unless it's an expensive multi-standard TV. Sorry pal, bad choice.
Mar 30, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Televison & Video Logo
132 people viewed this question
Computer Repairing
Computer Repairing
