Rinnai Convector 516TR cannot get it to work, we turn it on green on light comes on fan starts blowing after about 15 sec. it cuts out and red light comes on.
  • rwandjh May 28, 2011
    Thank you so much it was the gas connection its now working.
  • 11,800 Answers
This happens because the gas is not lit so the heater goes in fault mode. The gas is not lit because either the valve gas doesn't open or the sparker is non-operational - both will have to be checked.
For that download and follow the service manual
http://www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/service_info/153.pdf
Posted on May 28, 2011
506 convector rinnai
if the flame does not start at all, so just ticking from the ignitor you have a main valve problem and this is expensive replacement part and it must be done by a trained gas fitter.
May 21, 2014 | Heating & Cooling
I have a Rinnai 516TR showing error code 62
Error Code 62, indicates a faulty fan motor. Which, according to your Owner's Manual, requires a service call by an authorized Rinnai service technician. it may not mean replacing the fan motor. It could also mean a faulty fan sensor.
Hope this helped you. Cheers.
Jul 08, 2011 | Rinnai Heating & Cooling
OUr Rinnai gas heater convector 516tr keeps on turning itself off and flashes 12 on the light panel. What does that mean and how to fix it? tks
Hi.
12 flashes means "Incomplete combustion". The code is prompted when the flame turns off because of a problem.
Check filter, check gas pressure and thermocoupling. Those are the problem that commonly trigger the code 12 error.
Here a manual.
Here Fixya thread on the problem.
Sep 06, 2010 | Heating & Cooling
Hi i have a rinni convector 516tr heater i put it on it switches off a few seconds later i think it has to do with the timers i have lost the book/
I am assuming this is a tankless heater. Are you turning the water on full throttle and is there full flow. First thing to check is the small filter screen on the inlet of the water heater. If the flow is reduced the water heat will not fire.
Sep 05, 2010 | Rinnai Heating & Cooling
Mt Rinnai convector 516tr will not start, have stored it away for summer got it out for this winter plugged all in after pressing start after about 20 seconds No 11 starts flashing
I have had this problem due to the heater 's combustion sensor concluding that all was not well. In my case, the heater had burned up too much of the available oxygen. I didn't notice the lack myself, so it must be very sensitive. I had shut the place up to keep the heat in and eventually it dawned on me to open a door for a minute or so every half hour or so to replenish the oxygen supply.
The situation is worst when the place is very cold as the heater will roar away trying to heat it up as quickly as possible. After I came back for a holiday in winter, I had to set the temperature down to "L" and "Economy" on plus run an electric fan heater for a day to warm the structure to the point where the gas heater could relax and not burn oxygen faster than it could heat the space.
Apr 30, 2009 | Heating & Cooling
Rinnai convector 516TR
Hi This is happening to us and I called Rinnai... they suggested that if anyone either in our apartment or an ajoining one has painted walls or varnished a floor that the convection heater picks up the smell and the only way to get rid of it is to burn it off by running the heater for several hours in a well ventalated room...
I am going to try it tomorrow.
will let you know
Jul 13, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai convector 404
You have a dirty pilot assembly and maybe even a bad ECO switch (safety switch). I would suggest replacing the ECO and removing the pilot assembly and clean it out.
Jun 03, 2008 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Rinnai Convector 404
Hi pinkinfinite,
The 404 is a great heater. I am assuming it is a Natural Gas Heater. All it needs is a good blow out with compressed air. They tend to carbon up in the pilot light area. You will probably also find it is very dusty inside. Easiest way to clean the carbon out is to remove the hose at the heater and with compressed air blow through the fitting where you have removed the hose. Make sure you hold down the start button so the air can get through to the pilot light and jets. Don't connect the electricity for the fan when you do this.
To clean it out internally you only need to remove the front panelling. There are two screws holding the top panel (not to be confused with the side and top). The screws are located inside the bottom grill at the front. There are also screws for the bottom grill there which you will also need to remove and probably best to remove the bottom panel that house the front feet. It should expose all the inside workings of the heater except for the pilot light and jets etc. You should be able to see the fan - it is round and looks like a filter and sits behind the vent section. Make sure you give it a good blow out - it gets all dirt and dust around it. When you do it remove both the rear filters/covers. They are mesh. Blow the top one which is the larger metal one and make sure you blow inside where it fits over to remove the dust and dirt. Same with the other one which should be plastic with mesh. Once you do this put it all back together. Make sure all wires are connected and be wary with the compressed air as it may blow the connectors off from loose fitting parts. Once you get it all back together Test it and hopefully it should work. Hope this helps. I did one the same today that was having trouble starting and it now works like a new one.
Regards
Bryan
May 06, 2008 | Heating & Cooling
Heating & Cooling Logo
308 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
