Question about Dishwashers
I have a Fisher Paykel DD6051 Dishdrawer. She was working fine and then all of a sudden it will not turn on. Cycled power and still nothing. Is there a reset switch some where? Unplog to see if it would reset...nothing. Thanks, Rick
aborcass
  • 2651 Answers
SOURCE: Fisher & Paykel Dishdrawer DS603
2 quarter sized circles on either side of drawer will release the drawer fronts and allow acess to the electronics, behind the bottom drawr taped to back wall of unit is a troubleshooter/techsheet which might prove to be very helpful
Posted on May 02, 2008
SOURCE: Fisher & Paykel DD602 Dishdrawer:
an element fault (disconected or faulty controller)
Posted on Aug 01, 2008
RescueTech
  • 145 Answers
SOURCE: Top drawer Fisher & Paykel Dishdrawer no lights lcd
Your original problem, F4, was the machine trying to tell you that the heater plate was not working. When you turned the drawer up-side down, you may have damaged the wiring harness. If you do get a technician, call a fisher paykel authorized servicer, not an independent, and make sure you tell him about the F4 problem. A new problem has been introduced by the cleaning procedure, and both issues will need to be resolved.
Posted on Dec 11, 2008
RescueTech
  • 145 Answers
SOURCE: blocked drainage hose in Fisher and Paykel top dishdrawer DD603
Hello there..
How do you know the hose is blocked at all? It's rare for that to happen, I work on these machines daily as I am a Factory Authorized tech. You need to be careful in your approach to this, that is an expensive machine and it can be damaged by improper service procedures.
For starters, there is a flap valve on the end of the drain hose that would prevent you from introducing any sort of pressure backwards into the machine via the drain hose. For example, if you took and tried to blow air thru the drain hose outlet end, you would force that flap closed and create pressure in the hose. Also putting caustic drain cleaning substances is very, very bad for your machine and can cause some serious damage.
I will be happy to try to assist you, but let's start at the begining, shall we? What prompted you to conclude that the drain hose is 90% blocked? The first thing you should do is take out the rack, wash arm and tha large stainless steel filter plate. Next, pull the rotor up and out of the pump base (none of these procedures require tools) and make sure the grey impeller is not "freewheeling" or has become detached from the rotor shaft. The blue wash impeller on the top and the grey drain impeller on the bottom must be "one to one" meaning they are firmly connected to the shaft of the motor and turn together.
Next, check the tube or passageway in the drawer between the sump (where that small removeable filter screen is) and the pump's sump area (where you pulled up the rotor)
If you have any blockage, it will be in that tube.
There is some glitch here where I do not get notified of response to questions, so I will check back to this post.
Posted on Dec 14, 2008
RescueTech
  • 145 Answers
SOURCE: current service manual for the Fisher & Paykel DD603SS dishdrawer
I realize this is an older post but for information's sake in case someone happens across this subject, you can get the manual for a DD603 series dishdrawer here:
http://www.fisherpaykelparts.net/index.php?categoryid=115&productid=18
Posted on Dec 15, 2008
Can you please tell me how to reset the machine after the F^ code appears and I have fixed the flooding problem it is model DW60CE
The dishwasher should reset when the power is turned back on. Make sure the water is turned on also. Sometimes pressing the keylock button and holding for 4 or 5 seconds will allow you to continue. What is the actual F code you are seeing?
Mar 27, 2015 | Fisher Paykel Fisher & Paykel DishDrawer...
How do I reset the f1 flood button . Dd603ss
Not sure if you have managed to fix the F1 problem with your dishdrawer. This is a common problem and occurs mainly due to water leaking into the base of the dishdrawer under the bottom drawer.
But if it is occuring only in one drawer then the power filter at the base of dishdrawer is faulty and needs replacement.
Otherwise make sure the mains power to dishdrawer is turned off. Pull out the bottom drawer and stack in some towels behind it if you can to remove the moisture sitting on the base. The flood switch is located there. Then take a hair dryer and run it down behind the drawer to dry things. Push drawer back and turn power back on. Now if you cannot reach the back of the drawer then you will have to pull the drawer out from its rail. Refer the installation manual for this. See link page 7.
You need to find the source of the lead, Fisher Paykel DishDrawer Installation Instructions ManualsOnline com
Jul 05, 2014 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher Paykel Nautilus dishwasher
There is a drying cycle that runs for around an hour once the DD has finished its final rinse . It should show it on the LCD
Jun 03, 2014 | Fisher Paykel Fisher & Paykel DishDrawer...
Lights up wateris on select cycle close drawer nothing happens
I assume you are pressing the "Start" button. I think this model does not auto start.
Have you selected "Delayed Start" by mistake?
Feb 06, 2014 | Fisher Paykel DD24DHT17 Fisher & Paykel...
Water will not empty and beeping will not stop on Fisher & Paykel DD6051
The flood switch has turned on. There is a leak into the base of the housing. Turn mains power off. Open bottom drawer and dry the base using towels etc. Need to find the source of leak. Lid seal or hoses.
Sep 14, 2013 | Fisher and Paykel 24 in. DS-603 Built-in...
Greetings. I have a Fisher & Paykel dishdrawer - the top drawer appears to have lost power mid cycle and the lid has not retracted - no led display - no response from the buttons. The bottom drawer...
Describethe inside of unit,any wear on it anywhere, the rack the dishes go on is it plastic coated? is it wore with rust comeing though on tips here and there?
Mar 07, 2011 | Fisher and Paykel DishDrawer DS605FDSM...
Fisher and Paykel dishdrawer, lid not retracting, no power.
By no power you may be implying there is no display etc and the swithces are not working. Most likely the controller of the top drawer has had it. The controller is mounted on the front of the drawer behind the door panel. Hope things are better than that.
Oct 16, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Turn on and off buy it self
If a Fisher & Paykel dishdrawer is having a problem, it will usually display a fault code beginning with a "U" or an "F". "U" codes are usually solvable by the owner by checking the definition in the owner's manual. "F" codes usually require a service technician. I can tell you from experience that if you have no idea what to do, you should leave this one to someone who does. It's very easy to cause more damage by trying to disassemble it incorrectly. Also, the DD603 utilizes a "smart tool" that enables a technician to use a laptop and F&P software to diagnose the problem correctly.
Apr 25, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dec 02, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwashers Logo
46 people viewed this question
Top Dishwashers Experts
