Question about Vocopro UHF5805 Microphone
Hello My yellow color coded mic is sounding like its getting inteference, i adjust the squel level but i had no luck please help
Is there a LINE IN input at the back of the PC that is not a MIC input?
Hello jeff_glover
All computers have a line in and out input at the back of the tower . I 'm not familiar with your machine but if you can't find the inputs , go to the Device manager and check the sound, video and games controller .
Maybe it's only a question of driver and go then for an update from there . If you don't find the controller , you 'll need to purchase a sound card ( pci or vga ) .
Here are a few places where you can make your choise : http://www.google.com/search?sourceid=navclient&aq=2&oq=sound+cards&ie=UTF-8&rlz=1T4GGLL_enBE391BE393&q=sound+cards+for+pc#q=sound+cards+for+pc&hl=en&rlz=1T4GGLL_enBE391BE393&prmd=ivns&source=univ&tbm=shop&tbo=u&sa=X&ei=96KMTf3cONGRswby-P2NCg&ved=0CDUQrQQ&biw=1003&bih=630&bav=on.2,or.r_gc.r_pw.&fp=7c15a4d4522ad2f7
Best regards ,
fanaudi
Mar 25, 2011 | Gateway GT5438 PC Desktop
I get no sound from the mic
Hi Maria,
Please make sure you have connected to the right port. Typically, this will be color coded in red. Upon inserting the mic please make sure that the Microphone is on and the volume is set to a audible level.
Thanks,
Vick
Mar 03, 2011 | GE Audio Players & Recorders
I'm trying to use skype with my webcam but can't get sound. Also the circle around the logitech logo dosen't light up however when I'm in photo booth it does. Can I turn on the webcam somehow? Thanks
If you have a laptop make sure your webcam mic is set to default before you go to Skype
Laptop x Vista x Skype
You may have to access your hardware from the Control Panel if you have an earlier OS
BODY,.aolmailheader {font-size:10pt; color:black; font-family:Arial;} a.aolmailheader:link {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:visited {color:magenta; text-decoration:underline; font-weight:normal;} a.aolmailheader:active {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:hover {color:blue; text-decoration:underline; font-weight:normal;} TEST SPEAKERS Right click on speaker icon in System Tray Select "Playback Devices" The speaker icon ( checked as working) and volume level graph should be visible Right click on the volume graph and click "Test" Left hand speakers followed by right hand should be heard SET DEFAULT & TEST MIC Click "Recording" tab. Set required mic as default - click on mic font to highlight and click "Properties" In lower dropbox display "Use this device enable" click OK
Click "Levels" tab, ramp up slider ( adjust to suit later) > OK
Return to "Recording". Test mic by speaking and make sure volume graph displays CONFIGURE TO SKYPE
Start Skype
On the Tools menu, click Options.
In the navigation pane of the Skype Options window, click Audio Settings.
Select your webcam as the default microphone.
Save
In your Inbox make a test call using Echo/Sound test.
Oct 07, 2009 | Logitech Webcam
Well i just bought the ge minicam pro ho98067.the mic doesnt work
You do not say what your OS is and if the minicam has a built in mic or what program you want to chat in
This is how I set my mic up with Yahoo Messenger X Vista Home Premium
BODY,.aolmailheader {font-size:10pt; color:black; font-family:Arial;} a.aolmailheader:link {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:visited {color:magenta; text-decoration:underline; font-weight:normal;} a.aolmailheader:active {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:hover {color:blue; text-decoration:underline; font-weight:normal;} TEST SPEAKERS Right click on speaker icon in System Tray Select "Playback Devices" The speaker icon ( checked as working) and volume level graph should be visible Right click on the volume graph and click "Test" Left hand speakers followed by right hand should be heard SET DEFAULT & TEST MIC Click "Recording" tab. Set required mic as default - click on mic font to highlight and click "Properties" In lower dropbox display "Use this device enable" click OK Click "Levels" tab and set slider to 80% ( adjust to suit later) Return to "Recording". Test mic by speaking and make sure volume graph displays
CONFIGURE TO MESSENGER Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the lower two boxes > Apply > OK Click ( > ) Messenger > Preferences > Calling and Audio Set mic and speakers to show Default equipment Run call up assistant to test audio equipment > Apply > OK
WINDOWS LIVE MESSENGER
> Show menu > tools > audio and video set up - set mic as default -check settings > Next > set webcam as default - check settings > FINISH
Aug 17, 2009 | GE MiniCam Pro HO98067 Webcam
I try to record a video with my web cam and it has no audio
Hi, first of all you need to make sure you have the microphone configured properly. If using the cams built in mic you need to make sure it works . If using XP Open the control panel and click the sounds and audio deviecs, click the voice tab, there you can select which Mic to use: the USB cam mic or another mic , then click test hardware. If you should see a mic playback test. if the level is there then the mic is working. next see if there is a mic level test/adjustment within the camera software, if using skype you also need to set it up and turn up the Mic level there too. you may need to add a mic, some USB cam built in mic aren't that good. you can buy a cheap mic and plug it into the pink jack.
hope this helps, please leave a 5 thumbs up if this helped
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Aug 17, 2009 | Facebook Social Network
I have been filming wildlife in my garden with a webcam through a 5mt  ext lead. The video works fine,but how can I get live sound from the webcam mic to play live sound through my PC speakers ?
Audio set up Vista
Aug 16, 2009 | Microsoft LifeCam VX-3000 Web Camera
Low Sound on a dell latitude D600 (PLEASE HELP)
check the sound devices selected and the volume level is proper.
Jul 09, 2009 | Dell Latitude D600 Notebook PC
Mic problem
Hi and welcome to FixYa,
Offhand, the 4 pin mic connector and corresponding pin # would depend on the communications equipment the Astatic was initially wired for. However, the color coding of the wires in an Astatic would be:
  • white - mic audio;
  • shield/blue - gnd;
  • black - NC or speaker;
  • red - NO or PTT;
  • yellow - not normally used.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 09, 2008 | Astatic 636L Noise Canceling Microphone...
MIC PLAYBACK IS NOT COMING OUT TO THE SPEAKERS
Dear sir/madam,
Go to the sound properties in tray icon, check the Mic is not muted and there is Line in button, u scroll up to high for sound in mic. check all the check box are not MUTED. ok.
thanks
good luck
Don't forget to rate the solution
Jul 23, 2008 | Microsoft Windows Vista Home Premium with...
Distortion sound
turn down the gain at the mic pre, first plug in the mic then put the channel fader at optimum level, the 0 mark, then use the mic gain adjustment at the mic pre to set the level on the channel/ input meter, if recording using a digital platform keep the level as high as possible without going into red at all on the channel/ input meter, use the master fader to adjust listening volume and use the channel fader to make fine adjustments if needed but the point is to primarily use the mic gain knob to adjust the input level. If you are recording a loud instrument or cabinet with it then you may want to use the pad on the mic or the pad on the console/ mixer if after going through the above steps the level at input is still too hot, should be a switch on the mic or console wich says pad, if the mic has one then use the one on the mic instead of the one on console.
Jul 07, 2008 | Sennheiser ew 135-p G2 Professional...
Vocopro UHF5805 Microphone Logo
Top Vocopro Audio Players & Recorders Experts
 Grubhead
Grubhead
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Vocopro Audio Player and Recorder Expert? Answer questions, earn points and help others
