Question about Carrier 38CKC036 Air Conditioner
Curious to know about high pressure switches
I was once told that a high pressure overload can be caused by low charge to a unit. I have never heard of such thing, can you please elaborate the details of a high pressure switch for me? Please email me at Timmmmy1978@yahoo.com.
  • 236 Answers
High pressure switch use to detect the high pressure in the system. It is use to protect the unit from high pressure during operation.
Posted on Aug 29, 2008
Compressor after 10minutes stop but outdoor fan still working. Only 30psi and 8.2 ampere.what is cause of this problem for LG gold
It looks like you are low on refrigerant and low pressure switch is shutting the compressor down or it's shutting down on the thermal overload in the compressor. You need to have the unit charged.
Aug 31, 2016 | LG Heating & Cooling
Where is the reset button located?
The manual for your sprayer list several possible causes of the motor not starting, but does not indicate the presence of a reset switch. It has Thermal Overload but is reset by simply letting the motor cool.
From the manua: lProblem
A.
The unit will not run.
Troubleshooting cause
1.
The unit is not plugged in.
2.
Tripped breaker.
3.
The pressure is set too low (pressure
control knob set at minimum setting does
not supply power to unit).
4.
Faulty or loose wiring.
5.
Excessive motor temperature.
6.
ON/OFF switch is defective
Hope this helps!
Dec 05, 2015 | Titan Impact 1140 High Rider Airless Paint...
After turning the AC unit on roughly 10-15mins. outdoor unit turns off head unit still on
It sound like you have problem with compressor overheated. Make sure your is clean and correct amount of freon
Nov 06, 2013 | Fujitsu 18C1 Air Conditioner
I purchaed a used T30 2475N7.5 with a three phase motor. Converted it to single phase. It acts like it is starting under a high load and kicks either the breaker or re-set every time there it pressu
it sounds like the pressure switch needs replacing as this unloads the machine from the check valve up to the heads if pressure present when trying to restart it will cause it to trip when machine stops should get air leaking from under pressure switch for 1-2 seconds then it will stop
Oct 30, 2012 | Ingersoll Air Tools & Compressors
I have to push the red reset button about once a day on my outside unit. What can cause this?
Depends on what the reset button is for.
If it is a low pressure cut off then you are probably low on refrigerant or have a dirty inside evaporator coil or bad airflow across the evaporator coil.
If it is a high pressure cutoff then you have a bad condenser fan motor, dirty condenser coil or it is over charged with refrigerant.
If it is an electrical overload reset button then the unit is pulling too many amps or over heating due to refrigerant loss and/or dirty condenser coil.
I'd wash out the condenser coil, ensure that the condenser fan is running, make sure you have a clean filter inside and that the blower is operating properly. If those things are OK and it still pops that reset then call a service tech to look it over for you.
Jun 18, 2011 | Ruud Heating & Cooling
We cleaned the coils outside. Now the compressor only stays on about 30 seconds and shuts off. It will come again in approximately 4 minutes. The fan outside and the blower inside stays on. We have a...
sounds like it's cycling on the high pressure cut-out switch. Note: it could be a low-pressure switch that is causing the cycling but most units (today) don't have low pressure switches. If your unit has either of these two switches it will (usually) be the high pressure switch, although it's possible it has the low pressure switch too. My guess is it only has a 'high pressure cut-out.'
I would seriously look at the coil again and make sure you've cleaned it real good.
Many Carrier Air Conditioners have what is called a SPLIT coil. If this is what you have you will need to (WITH ALL POWER OFF) disassemble the outside unit enough to where you can manually pull these coils apart (be careful - you just need to get a small gap between them) and wash IN BETWEEN the two coils.
Pretty difficult to do - but doable.
It's possible you have an overcharged unit - but unless you've recently had it charged I would not suspect this.
If it is not the high pressure switch - and 'you do have' a low pressure switch - chances are you're out of refrigerant and you will need a serviceperson to (a) fix the leak and (b) re-charge the unit
Jun 05, 2011 | Carrier 38BRC036 Air Conditioner
My 40g shuts off after running perfect for a feww minutes
It is very likely you are having a problem with the low oil pressure switch or the high temperature switch. Both of these are connected to the No.85 wire which in turn goes back to the control board. If the temperature exceeds the predetermined level (apprx 305 degrees F) the high temperature switch will then ground wire 85 causing the unit to shut down. Same thing with the oil pressure switch, if the oil pressure switch goes below 10 psi the low oil pressure switch will ground wire 85 causing the unit to shut down. To determine which is causing the problem disconnect first the low oil pressure switch (Located by the oil filter) and start unit if it contunues to run after 10 seconds and does not shut down then the oil pressure is the problem. Then you must use a mechanical pressure gauge connected where the low oil pressure switch is to determine if you actually have less than 10 psi of oil or if the low oil pressure switch is just bad. Try the same thing with the high temperature switch also located close to the oil filter if you disconnect it and it continues to run more than 10 seconds then you have and engine that might be overheating. Anything that gets caught in the air intake on the generator itself ill cause this unit to overheat, I've seen it **** garbage in through the air intake and cause the unit to overheat because of poor air flow. If their are no restrictions and you have good air flow than chances are you have a bad high temperature sensor.
Hope this helps, please let me know.
Dec 01, 2009 | Guardian Rv Generator 4800 Watt, Gasoline,...
Sanyo split high pressure side tube icing
ok, on these units, if by high side line you mean the small tube going from outside to inside, that tube is actually on the low side, the metering device is in the outdoor unit. If you shut the unit down, let everything thaw then restart and find that small tube is freezing up right at the outdoor unit right away, my guess is its low on charge. I see that you put some in, make sure it is the right knid of refrigerant. they do not hold alot. Where is your suction pressure running. If you put 2 to 3 pounds with no change, you may have overcharged but that is telling you that there is a restriction in the line inside the outdoor unit, probably the filter if it has one, or the metering device itself. Let me know what you find.
Jun 16, 2009 | Sanyo Split System Air Conditioner
After approx 40 min of highway driving the AC stops blowing cold
The frosting of the line is normal. Did you use a gauge set when charging the unit? AND, most important, Did you evacuate the system before putting in the freon? Very important.What was your final low side reading and your final high side reading?
Jun 02, 2009 | 2003 Hyundai Santa Fe
Carrier 38CKC036 Air Conditioner Logo
240 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
