My ipod is just playing without the sound carrying through to the speakers. I dont know how to make it work?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Audio Player... Master
  • 1,001 Answers
Bluetooth Headphones V3.0 Handsfree Stereo Wireless Headset with Microphone earbuds for Apple and Samsung LG https://www.amazon.com/Charm-sonic-Bluetooth-Headphones-Microphone/dp/B01H6D7P7O/ref=lp_14423925011_1_7?srs=14423925011&ie=UTF8&qid=1484015952&sr=8-7
Posted on Jan 10, 2017
  • 3,267 Answers
Verify there is nothing plugged into the headset port, including headsets, headphones, or adapters.
Original iPhone only: While on the Home screen, adjust the volume buttons. If you see the icon below, indicating that headphones are attached, there may be debris in the headset port:
To remove debris in the headset port, try connecting a pair of headphones to the headset port and then remove the headphones. Repeat this several times.
If you have paired with a Bluetooth headset that is nearby, either use the headset or turn Bluetooth off (choose Settings > General > Bluetooth).
If that doesn't work, try restarting the iPhone. Hold the Sleep/Wake button until "slide to power off" appears. Slide to power off your device. When it is off, press the Sleep/Wake button to turn it back on.
If restarting the iPhone doesn't resolve the issue, try restoring the device.
Posted on May 28, 2011
New Alpine radio, went through setup, plays fine on radio/tuner on all four speakers, but ipod (USB port) or internal CD only plays on front speakers.
Just a thought - the usb provides a digital signal which carries information about how the signal is to be processed; mono, stereo, surround sound stereo, etc.
If the mp3 music file was only recorded in 2 speaker stereo perhaps that is how it plays back.
Admittedly the radio signal is stereo and yet it plays on four speakers but unless it is a DAB radio it is analogue and maybe that makes a difference.
Perhaps there is an internal electronic fault with the digital processing part of the unit. I suggest reading the handbook again and then perhaps contacting the seller.
Mar 28, 2016 | Alpine Car Audio & Video
Internal speaker stopped working on my ipod 5th gen, headphones still work tho.... anyone got the solution??? cheers
Well, the internal speaker does not play sounds... It is not possible for the iPod's internal speaker to play music, as it is only capable of making three disctinct sounds:
the clicky noise
the alarm sound
the chirpy noise when you boot into diagnostic mode
You can get those sounds back by going into SETTINGS on the IPOD and turning the sounds back on.
Sep 09, 2010 | Apple iPod nano 5th Generation
I pod wont play sound on the left speaker or
if you have already tried a new pair of headphones , and still have same problem . you probably have a bigger problem , i had the same problem with one i bought from pawnshop . i immediately took it back knowing the problem was wear and tear on the audio out jack for headphones . usually happens when people carry there ipod in there pocket and are active , the audio headphone jack ends up breaking or bending insdie . this should work work > http://www.amazon.com/Cables-Go-35508-iPod-Compatible-Connector/dp/B000J022G6 AND THiS http://www.amazon.com/Cables-Go-35508-iPod-Compatible-Connector/dp/B000J022G6 YOU COULD ALSO CALL APPLE to see if they jave anything else like this.
May 02, 2010 | Apple iPod classic MP3 Player
ILive Bar Speaker not playing sound
I have an iLive bar speaker ipod dock and it has worked great until today. The sound isn't working. You can hear that it is on, but it isn't playing music. The display works and everything. Is this fixable?
Apr 18, 2010 | GPX iLive IB-R2807DPBLK Portable Music...
My 2yr old was playing with my ipod in my griffin speakers
Unfortunately, it sounds like she broke the jack inside of it. It has lost connection to the main circuit board, and is of course now useless. If you know what you are doing and it is NOT under warranty, you could try opening it and resoldering it, not that it will definitely work. Otherwise, if it is under warranty, back it up (if you can), and take it back to the store.
May 01, 2009 | Griffin Technology FireWave Surround Sound...
Itouch music problem
i think its the  music its most likely a bad quality of music try other songs
Jan 05, 2009 | Apple iPod touch
Only 3 speakers work!
I took the bottom off my go play to have a look inside, the internal port is connected to one rear speaker grill and the other is blanked off, so no sound will come out of that one.
Dec 24, 2008 | Harman Kardon Go + Play Portable Speaker...
My iPod stopped playing through speakers- but only at work...
Esmurfette
First things First!
1) check on other speakers to see if your iPod work fine
2) check connector for loosing electric connectivity.
3) check with your headphones to see if your iPod play music well.
4) Check, power on the computer spk. you got. or the input that is working right.
Good Luck
Jan 29, 2008 | Apple Logitech Inc MM50 Portable Speakers...
HELP - we have no sound!!!
Ok i looked further into your problem. Let me try and explain something to you.
When i look up the specifications for your speakers, it says you can plug them into an ipod or or any audio device, (including your computer) , and then they will work. You cant install audio drivers for the ipod, but! they will still work with the ipod. Therefor you dont need a driver for these speakers. Now what the problem MAY BE is your sound card. I can possibly help you if you can give me some specifics as to which sound card you have and what Operating system are you using ( windows xp, windows 98, windows vista etc etc..) please let me know iw ould like to help!
Jan 20, 2008 | ViewSonic NeoSat SP2002 Computer Speakers
118 people viewed this question
 Grubhead
Grubhead
