Question about Video Game Consoles & Games
Whenever I try to turn on my xbox 360 I get a red ring around the power button.
  • 22 Answers
These red leds(also know as the red ring of death or RROD) around the power button is a way for the xbox to tell you that something is wrong. Different combinations usually have to do with different errors. I recommend that you send it to a repair shop or back to microsoft if the warranty is still good. Don't forget to give them any relevant information and which leds were flashing. Also an error code would help them alot.
Posted on May 28, 2011
My xbox turns on an as soon as the xbox 360 logo goes on screen it freezes its berly a 2 month old xbox
Are you getting the 'red ring of death' (the red ring that lights up around the power button)?
This could be either a problem with your television set, or more than likely an issue with the Xbox's harddrive.
Jun 29, 2011 | Video Game Consoles & Games
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
How can I fix "Red ring of death" on my XBox 360
Three flashing red lights around the Xbox 360 power button (nicknamed the "Red Ring of Death" or "Red Lights of Death" or "Red Ring of Doom"), instead of the one to four green lights indicating normal operation, represent an internal problem that requires service. Warning signs may include freeze-ups, graphical problems in the middle of gameplay, such as checkerboard or pinstripe patterns on the screen, and sound errors, and the console only responds to pressing the power button to turn it off. These events may happen once or several times until the hardware failure occurs, or not at all. If the console freezes occasionally, the error will not necessarily follow. The technical problems seem to affect some generations of consoles more than others. e.g. Xbox 360 60GB This error code is usually caused by failure of one or more hardware components, although it can indicate that the console is not receiving enough power from the power supply, which can either be due to a faulty power supply or if the power supply cable is not fully inserted into the console. The 3 flashing lights can also be caused by power surges; if the console is connected to an outlet that receives a power surge, it may have a failure and the 3 lights will appear as long as the console is plugged into the outlet. Turning off the console, unplugging all power cables and plugging them back in, and restarting the console will fix the issue in this case. hope this helps
Nov 30, 2010 | Microsoft Xbox 360 Console
When I turned on my system, it had system error contact xbox customer support. There is a red light flashing on the bottom right, around the power button. I don't know what to do. Please help.
Some of us suddenly when we turn on our Xbox 360 console one day we got one red light flashes on the ROL (Ring of Light) around the Xbox 360 power button, and we got an Error message appearing on the TV screen "System error" also might occur with any error code like E66, E67, E68, E71, E74 or E77, all the same.
When you get any of these messages appearing on your screen with one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
So, first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more.
If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you.
The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
Read more: http://xbox360help.blogspot.com/2007/03/one-red-flashing-light-xbox.html#ixzz14pQlSds6
Nov 09, 2010 | Microsoft Xbox 360 Console
Whenever i turn on my xbox, around the power button turns all red and the xbox dashboard does not show up, what is happening?
If you have 4 red lights that would indicate the video cable is not connected correctly. Disconnecte the video cable and reconnect it.
The 3 red lights issue is known as the red ring of death(or RROD)
This is caused by the x clamps used to hold down the processor.
The x clamps cause to much pressure which causes the xbox 360 to think it is over heating. Microsoft has issued a extended warranty for the RROD issue. You can reach Microsoft by calling 1800 my xbox. The link below is to a Youtube video walk through on how to resolve the issue.
http://www.youtube.com/watch?v=fuIl0kGf7dM
I hope the info listed above has helped in some way.
If possible please rate this solution.
Aug 29, 2010 | Microsoft Xbox 360 Console
Trying to turn xbox on and getting blinking red ring around power button
If you are having three red lights flashing around the power button with upper right corner not flashing, it means that your Xbox 360 is having a general hardware failure. This is caused by the internal components of the console experiencing a malfunction. You can contact Microsoft Xbox Support for it to be repaired.
May 10, 2010 | Microsoft Xbox 360 Console
I HAVE 4 RED RING WHEN I TURN ON MY XBOX
Four lights around the power button flash red on your Xbox 360 console. Four flashing lights indicates that the console does not detect an audio/video (AV) cable.
Note Four flashing red lights will not appear on consoles that have both an AV port and an HDMI port.
Solution
http://support.microsoft.com/kb/906652
Mar 23, 2010 | Microsoft Xbox 360 Console
Xbox 360
ring of death sorry you can try this get a towel rap it around the xbox turn power on at the xbox leave it for 15 minute turn the power off take the towel off leave to cool down for 15 minutes it should work good luck
shaun
Jul 31, 2009 | Microsoft Xbox 360 Console
Have sound no picture and 2 green rings around power button
They are green?!? usualy when people have problems with  the xbox 360 hardware, the lights turn red. This xbox 360 may have a birth defect... Best thing to do is call 1800-4my-xbox. Talk to a representative about sending your xbox in, ONLY if you have not voided the warranty. If so, you will most likely have to buy a new xbox or new motherboard for it.
Also try changing your video settings to tv instead of hd, or hd if it is plugged into a hd tv. You might have toggled the HD switch on the video/audio chords.
Dec 31, 2008 | Microsoft Xbox 360 Console
Xbox 360
Your xbox had gotten the red ring of death. If you send it to microsoft and its in warrenty they will fix it or send you a brand new one. You have to go to there website, and they will ask you for a bunch of info, it will say if its in warrenty or not and if it is they will send you a box to mail it to them in.
usually about 1 month turn around time
Oct 27, 2008 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
37 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
