Question about Freezers
Replacement door seal for walk in freezer
I have the seal that goes around the door to keep air out has shrunk on my walk in freezer ( Vulcan. 8'x12' unit.) and need a replacement but do not what to look for also need a heating strip that fits around the door. I also have a defroster problem - when the unit goes in defrost it leaks from the line ( freezing up) that making a frozen ice mess on the floor. I have repeated repairs done but with no sucess- any suggestions? Thank you
  • Freezers Master
  • 1,218 Answers
First, call Restaurant Parts and More (1-888-814-1110) and ask for Rick. He can help either get you the seal or have one custom made. I've used him for 15 years with great success. If you have model and serial, it would be even greater.
He can do the same for the heaters that go around the door frame.
Don't understand which "Line" you are referring to. In alot of cases, the drain on the drain pan is clogged. This causes water to overflow onto the floor. The drain can be clogged from trash getting into it. Most of the time, the drain heater is either not working or not ever installed. Water refreezes in drain line and causes the overflowing problem.
If this does not help, let me know. Clear up the "Line "question and maybe I can go alittle deeper into this.
Posted on Feb 14, 2009
My upright freezer get icy all the time.
Check the rubber seal around the door edge is correctly fitted.
If you need to adjust the hinges and level your freezer
Clean the seal and then smear a small quantity of vasaline over the seal.
If it keeps icing, you may have to replace the seal
Hope it helps
Feb 03, 2016 | Freezers
Frezzer keeps icein over
Hello;
My name is Peter. I am a retired field service refrigeration technician.
There are several things to check:
1.) Door Gasket -Take a piece of paper. With the freezer door closed run the paper around the gasket. If you can do that, then you are not getting a good seal.
Repair: Clean the freezer door gasket with soap and water. While still wet, take a hair dryer and a spatula, going around the gasket, heat the gasket while pulling the gasket out to expand it.
Note: This only solves the problem if there is frost in the front area of your freezer.
2.) Freezer fan not working - In some cases, The freezer fan helps to prevent warm air from getting into the freezer.
3.) Food Storage - Make sure you do not overload the freezer, and that the food product is inside the bounds of the racks.
4.) Fresh Food Section Air Vent Wide Open - This is your probable cause: Heat goes to Cold like a magnet. When you open your fresh food section door and then close it you are forcing warm air up the vent that goes to the freezer. You probably have a broken air vent assembly.
Oct 08, 2014 | General Electric Top Freezer 21.0 Cubic...
Viking professional defrost cycles
Check the rubber seal inside/around the door. I bet you have a tear or piece of seal that isn't making a solid fit and it's allowing (warm) room air into you freezer. This moist room air will either turn to water droplets and builds up to enough droplets to form puddles in the bottom of the freezer, or it freezes into a blob of ice around the door seal and this allows warm room air into the freezer. Otherwise you need an Appliance Tech to check the Freon refrigerant level. Most times its the door seal causing this problem.
Jun 08, 2014 | Frigidaire 14.1 cu. ft. Upright Freezer...
Why is my freezer door leaking air?
Check the door is sealing all around the rim. The seal may need replacing, or the door may need adjusting.
Apr 26, 2014 | Freezers
How can I replace the seal for the lid?
no need to replace unless damaged. You should be able to pull the seal off the door and place it in the dishwasher or use the solution described below in a sink to clean it. If removal is impracticable then the recommended cleaner (on the door) is a spoonful of regular dish washing liquid + 1/4 C of Lysol (the real stuff- brown smells horrible) and a quart of very warn water....add to this about 1/8 C of household bleach..clean with a sponge/ rag and rinse. This will clean and totally disinfect the door/ seal. Also, remember that unless you have a true allergy to mold there is no proof that it will harm you, its around us every day. Ever taken a walk in the woods at daybreak or sunset- look at the specs flying around- they're mold at max!
Dec 29, 2012 | Magic Chef 7 cu. ft. / 198 liter Chest...
Commercial walk in freezer door damaged needs repair or replace?
I Need two panels replaced on my Walkin Cooler, is there anyone that cacn give me a quote/price for this repair
Nov 14, 2009 | Freezers
Frost free freezer is frosting up
Your door seal is not sealing properly . Check and use a hairdryer to soften the seal and the magnetic portion should seal itself against the cabinet .
Jul 07, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
My walk-in freezer is developing stilagtights (ice castles) on the floor and cieling in front of the evaporator coil.MY drain pan is not plugged when I pour water down it.
You should check for air leaks around the door gasket or any other openings in the compartment such as where pipes or wiring is going through the wall. It sounds like a moisture problem from moisture being drawn into the compartment pass door gaskets or access holes.
Mar 07, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
Freezer vaccum seal not working
check the gasket and make sure that it it not pinched and letting in air whe the door closes. primaryly around where the hinges are.;
Dec 27, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
GE Upright Freezer problem/door
The door seal is damaged or the hindge alignment have allowed the warm air to enter and the cold air to leak out the of the freezer. Look and feel around the door for the cold air and check the top and bottom hinges to make sure they haven't become loose. Look for tears also around the seal because this will do the same thing. Let me know what you find. JT
Oct 23, 2007 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Freezers Logo
173 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
