Question about Amana ABC2037DEW / ABC2037DEB / ABC2037DEQ Bottom Freezer Refrigerator
Amana Model # ABC2037DEW My Bottom freezer built an Ice Dam in the back . Refrig not cooling and freezer cooling 70 percent . It is 5 years old and first time frig isn't cooling. Any suggestions? Yikes!!
huuum
  • 750 Answers
SOURCE: 11 year old amana bottom freezer icemaker drips water when filling tray
Hello dunc444444
Welcome,
You said, Bottom freezer works fine, but upper refrigerator has no cold air
Is your freezer so full that it is packed to the top especially in the rear?
Refrigerators and freezers share the air from the compressor and travel through vents in the rear of the freezer and fridge.
Sometimes it can effect the cooling in the fridge if the freezer articles block the vents!
The water overfilling in the ice maker is an ice maker problem only.
When we install an ice maker there is a short white plastic tube that we push through the rear
hole of the fridge which supply's the water to the maker, the outside water line attaches to this.
That tube we push through the fridge must go in till it stops. And empties in to a little sistran at the rear of the ice maker. Make sure it did not sip out or backwards a little when you may have moved
rolled the fridge out to clean under it!
Also you need periodically to remove the front grill down in front of the fridge and gently run a refrigerator brush under the coils to clean out the dust that may block air flow over the coils.(the coils are metal black tubes that run back and forth along the bottom of your fridge.
The vacuum will not reach in to that tight space. That's why they make a special brush for this chore.
Let me know how you do?
Huuum {
Let me know.
Huuum
Please remember to leave a rating.
Posted on Oct 05, 2008
  • 85 Answers
as long as the temp in the frz is normal. the i/m could have a bad thermostat that, could be causing it cycling too soon or the tray is leaking water. either way i/m needs to be replaced, sorry
Posted on Dec 14, 2008
SOURCE: Amana Bottom Freezer
amana bottom freezer has brown liquid draining on floor near the left leg
Posted on Jan 10, 2009
  • 1214 Answers
SOURCE: amana refrigerator warm
Chances are if they are getting cool but not cold-
1) the evaporator fan in the freezer is not running
2) Defrost heater has failed
3) Defrost sensor has failed
4) Defrost timer/refrigerator control has failed.
Check for ice build-up on the back wall of the freezer. If there is ice, unplug or turn the unit off for 6-8 hours with the doors open (put any food in a cooler with ice to maintain). Note water may come out of the refrigerator.
Plug the unit back in or turn it back on, close the doors, and check temperature after a couple of hours of operation. If all OK, you will need to have the above tested, or, if you know how to use a multimeter and can read a schematic/wiring diagram, I can instruct you on how to check the above.
Posted on Jan 20, 2009
aborcass
  • 2651 Answers
SOURCE: i have an amana side by side refrig, the frig side cools a little
sounds like yhour compressor is not runnning, look behind the unit and se of the fan down below is turning and if the compressor is cold, or overheated and redhot
Posted on Mar 13, 2009
Amana ABC2037DEB after 4 years, now freezer click and hum melting
that click followed by a hum can only be one thing
pull the unit out and feel the compressor, if its really hot you have a relay and overload issue, and it struggles to start.
with any luck, it is the external relay and overload found mounted to the comresssor should be a lil white block
if not it will be two differant parts
a lil white one and a brown one
let these cool a bit and check both for continutity
ive included a link for the parts
they are 10 and 11 on the schematic
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174380&diagram_id=1358665#d1358665
Oct 22, 2009 | Amana ABC2037DEW / ABC2037DEB / ABC2037DEQ...
Hi, My Amana Refirg is about 30 years old-refrig on bottom freezer w/ice maker on top. The ice maker was skipping and would not stop by raising the arm. Consequently is ceased, now however the freezer is...
do you see alot of frost on the rear panel of the frzer if so it has failed to defrost and repair is req or do a manual defrost until a tech can get to you if no frost sorry sounds like you have a weak tired compressor or leak of freon and being 30 yrs old it is not cost effective to repair this item....
Aug 19, 2009 | Amana Refrigerators
Refrig not cooling
Either the fan that blows cold air from the freezer compartment to the fresh food compartment is burned out or the door/flap that seperates the compartments is stuck or the linkage connecting it to the fresh food temperature dial is stuck or broken.
The evaporator coils are in the freezer compartment and air is blown from the freezer compartment to cool the fresh food compartment. For some reason, air is not moving to fresh food compartment.
If the fan is running, it could be something as simple as Ice blocking to door between the freezer and fresh food compartment. I know modern refrigerators are self-defrosting, but that's only the evaporator coils, which are defrosted by a timer and a heater.
Ice can form on passageways inside the refrigerator, like the exit of the ice maker and in this case, on the door and 'tunnel' between the freezer and fresh food compartment. It's free, and doesn't take a lot of time, so try completely defrosting the unit before doing anything else.
BE SURE to keep the doors open, as odors can form as particles of food are allowed to defrost that may have been frozen in an ice pack for months or even years. Clean the interior of the refrigerator while you have everything out and reset the controls to normal settings.
If this doesn't help, there may be a mechanical problem with the air transfer control flap/door that will need to be fixed.
Hope this helps.
Jun 10, 2009 | Refrigerators
Amana bottom freezer refrig runs at maximum coolness
Thanks for your inquiry. I think I may have fixed it. I unpluged it and took everything out of the refrigerator and freezer, cleaned it thoroughly inside and out and unscrewed the back wall inside the freezer. There was a huge ice buildup on the coils so I let it sit for 12 hours like a defrost. I turned it back on and it seems to be working fine. It is not running constantly and is maintaining about 5 degrees below. If this doesn't stay working, I guess I have to call a repairman.
Feb 14, 2009 | Amana ABB1927DE Bottom Freezer...
Amana refrigerator warm
Jan 20, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
either you ice maker is overflowing,(not likely but possible) or you have a clog in your drain behind hte rear cover, not allowing defrost water to drain away in to the pan under refrig instead flowing to bottom of freezer area. rempove the rear cover and thawe all ice, especially near the middle of hte aluminum oan yull find a clogged/frozen drain tube
Nov 10, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Hello dunc444444
Welcome,
Huuum {
Let me know.
Huuum
Oct 05, 2008 | Amana ARB9059CS Bottom Freezer...
Sep 26, 2008 | Amana ABB1927DE Bottom Freezer...
Amana BX22A2W - freezer works, fridge not cooling
Same problem here with an Amana refrigerator with the freezer on the bottom. I removed the back panels and vacuumed dust and cat hair out. The back panel in the freezer was frosted over with ice on the bottom. I removed the shelves and food and used a hairdryer to loosen the panel. The ice maker made it harder to remove the plastic panel so I pulled it back and saw the cooling fins frozen solid. I used the hairdryer to melt the ice and a shop vacuum to collect the water. It works like new again.
Dec 02, 2007 | Refrigerators
Amana ABC2037DEW / ABC2037DEB / ABC2037DEQ Bottom Freezer Refrigerator Logo
50 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
