Question about Alpine Car Audio & Video
Have a alpine 3530 bridgeable 4-channel how do i hook it up to my stearo wire harness`which color wire is hot + and ground-
SOURCE: I need to know which factory wires are hot and ground so I can install a new radio without a wiring harness
what you are going to need is the wiring diagram... either car manual might have it or a local car audio place might have it... obviously the charge you for it... usualy for newr cars you can find it for free just by researching it on google... i found this for you duno if it helps... just code the wires and cut them to make your new bridge to the unit without a harnest
Have fun
goodluck
1991 Chevrolet Caprice Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′ x 6′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Posted on Apr 28, 2009
etirbynnor
  • 655 Answers
SOURCE: What is the best way to connect 4 speakers and a sub to a 4 channel amp.
Hello emscarboroug,
You did not specify which Alpine 4-channel you have. If you have the MRP-F240 or MRP-F250, they can be run as 2/3/4 channels. Unbridged, the channels can output to either a 2ohm or a 4ohm load.
In your case, to run 4 speakers and 1 sub, it would be best to connect 2 of the speakers in parallel to each of channels 1 and 2 and connect the sub bridged to channels 3 and 4. The bridged terminals for the sub would be the 1st(-) and last(+) on the bottom row of terminals. The sub must be 4ohm or higher. And with this arrangement, you'll have different settings for the filter switches. For channels 1 and 2, set the filter to "OFF" (leftmost position. For channels 3 and 4, set the filter to "LP" (rightmost position).
Hope this helps.
Posted on May 01, 2009
  • 95 Answers
SOURCE: 99 Mazda Protege and Parrot CK3100 Problem
Some of the autoradio has the mute function already included to the autoradio, and when you add it, it may create troubles.
Then try without the mute cable connect and see if it is working.
Did you select the harness which the right reference of audio system?
You will have to ensure it.
Posted on Mar 18, 2010
caroldon
  • 17130 Answers
SOURCE: Alpine 3530 Bridgeable 4 channel power amplifier
Use the left and right to connect the positive and negative to the respective speakers in the right and left. Please make sure of the polarity and so be cautious. next you can connect the sub woofer from the left and right channel as the amp is bridgeable. Use the lead to connect from the R- positve to L negative. test and check the phasing of the speakers, must get good low bass or else you can reverse the sub woofer and check again. If you ae having frint speakers connect accordingly the the other channel. Helpful Good day
Posted on Jul 13, 2010
  • 8 Answers
SOURCE: How should I wire a 4 channel amp for alpine sps 600, 609
they are only 4 ohm speakers so just put the front speakers on channels 1&2 or a&b and the rear on 3&4 or c&d since you are using a 4 channel amp thats what they are designed for
Posted on Jul 15, 2010
Alpine wiring diagram
If you contact Alpine they will be able to tell you if there is an adapter that will plug right into your existing OEM harness. If not then, you'll have to figure out Which wires are which on your OEM harness, here is the Alpine wire code:
Alpine wiring help
HU harness color code pretty much universal.
red=ignition
yellow=battery +
black=ground
blue/white=remote turn on
blue=power antenna
pink/black=audio interupt in (not sure if you have one)
speaker wires
gray=right front
violet=right rear
green=left rear
white=right rear
speaker wire with black stripes is negative.
Sep 29, 2016 | 2011 Dodge Ram Pickup 1500
I have a 1998 Toyota Camry...Trying to hook up an Alpine...Need to know what wires to connect to the alpine.Car Wires are same with grey spots.....
From what I can tell you cut the wires to your factory wiring harness and that is what you want to hook up to. My advice is to reconnect the factory harness and buy the adapter harness for your car and use that to hook up to the alpine it will save you hours and possibly your sanity. If you want to hook up directly to your car without the adapter you will need to figure out what wires are the power ignition and ground with a multimeter or power light. Easiest way to find ground is to just put in a ground wire with in a foot or so from the deck. Then it's just a guess and check for the correct placement of power. I suggest turning the power placement on the deck to what speaker you want and repeat for all speakers until your finished. Or you can buy a Chiltons or Haynes manual the should have a wiring diagram
Sep 03, 2014 | Car Audio & Video
I hooked up a dual mosfet 4 channel amp and i am not getting power to it. the way it is setup is from battery to 100 amp fuse, from fuse to inside cab of truck then to 500 K farad, Split from + to power on...
Bad ground sounds like you may have paint or undercoating stopping the ground from making good contact or unhook the remote wire and run a small wire from the main power to the remote hook up and see if it works ...... May have a faulty remote
Apr 25, 2011 | Dual 2-Channel Bridgeable MOSFET Amplifier...
I just bought Alpine car stereo CDE-100EUB but I'm having trouble connecting it to my old car toyota Rav 4 2004 model because the wire harness are different. also the alpine wires are more in numbers than...
Please let me know if you have any questions, and thanks for using FixYa.
2004 Toyota RAV4 Car Stereo Radio Wiring Diagram Alpine wire color
Radio Constant 12V+ Wire: Blue/Yellow yellow
Radio Ignition Switched 12V+ Wire: Gray red
Radio Ground Wire: Brown black
Radio Illumination Dimmer Wire: Green none
Radio Antenna Trigger Wire: N/A blue
Radio Amplifier Trigger Wire: N/A blue/white
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Wire (+): Pink white
Left Front Speaker Wire (-): Purple white/black
Right Front Speaker Wire (+): Light Green gray
Right Front Speaker Wire (-): Blue gray/black
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Wire (+): Black green
Left Rear Speaker Wire (-): Yellow green/black
Right Rear Speaker Wire (+): Red violet
Right Rear Speaker Wire (-): White violet/black
Jan 02, 2011 | Alpine Car Audio & Video
Alpine 3530 Bridgeable 4 channel power amplifier how do i connect the wires/speakers
Jul 12, 2010 | Alpine Car Audio & Video
What color wire do i hook the pink wire to
Pink wire is generally the parking brake safety. If you dont want the dvd player to play video while in drive wire it to the ground on your parking brake sensor wire. If you do want it to play video while your driving, wire it directly back to the ground wire on your stereo.
May 15, 2010 | Alpine IVA-D300 Car DVD Player
Can this power a subwoofer and what is the rms wattage
Hello crucible19,
The Alpine MRP-F240 is a 4-channel amp that outputs 40 watts RMS per channel. It is more suited for powering normal speakers, but since it is bridgeable, you could power a small sub by bridging 2 of the channels.
Hope this helps.
Oct 02, 2009 | Alpine MRP-F240 Car Audio Amplifier
Alpine pdx 1.000 keeps cutting out
You are going to want to make sure all your power wires and grounds are 4 gauge as well as the wire leads to and from the capacitor-4 gauge also. make sure you have a very good ground - the power wire from the battery should hit a distribution block-from the dist. block a 4 gauge should go to the capacitor another 4 gauge to the mono amp and another to the 4 channel amp -every component should have a good solid ground even if you have to bust out a grinder and a drill and some self tapping sheet metal screws and go nuts on it- see if that helps you
May 26, 2009 | Alpine PDX-1.600 Car Audio Amplifier
Heating up on back of cde 9852 alpine cd player
try to chek the regulator or replace it and install a heatsink for him
Jan 31, 2008 | Alpine CDE-9852 CD Player
Car Audio & Video Logo
159 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
