Question about HP LaserJet 4050 Printer
No internal print messages appear on print screen
Nothing will print even from command prompt. Printer powers up fine but no messages on printer window. Like 'initializing' and then ready. Help please.
I don't no
Posted on Dec 31, 2008
Cannot print from command prompt - Epson U220D Windows 7 32-bit New parallel port with driver New centronix to parallel cable Epson driver APD_455dE (I was using Windows 7 64 bit with a...
The Epson works fairly well with XP. It is to be connected to
a parallel port, usually LPT1
using an IEEE certified parallel printer cable. The computer BIOS
setting is best set for standard parallel port, SPP, bi-directional port
or similar. If possible, do not set it to ECP or EPP or ECP & EPP.
The only native driver for the printer is on the Windows CP CD. Install
using the Add Printer wizard.
The Epson LQ-860 drivers, and a few others, can be used. Using these
drivers, you will discover that the printer actually has some resident
fonts (in printer ROM) that are not accessible from the Stylus
driver. However, with this driver, graphics printing quality is
compromised.
Windows 9x drivers _cannot be used_.
Let us know.
Tom
MSMVP
Windows Shell/User
"the_best_of_fools" <thebestoffools@discussions.microsoft.com> wrote in
message news:E7A27E3E-81E7-46CC-B38E-C63AA474A239@microsoft.com...
:I have an Epson stylus color 600 I can't get to work with Windows XP.
This
: printer worked fine with my old Mac.
: I've tried everything I could and nothing is working. The printer is
: connected to
: the computer via parallel LPT1 port. I've installed the WindowsXP
resident
: drivers
: for this printer model (the Epson drivers are too old and not
verified). The
: computer doesn't detect the new hardware with Plug and Play when
turned ON
: (don't know why) so I had to manually Add Hardware (Printer Port) with
the
: Hardware Wizard. I'm not sure how to recognize if the LPT1 port is
active or
: not and set up properly in the BIOS? I read something about having to
set the
: parallel port to ESP or ECP depending on the printer's requirement
(which I
: don't know) in the BIOS?
: Everytime I send a test page or print from a command prompt or WordPad
: nothing happens for 1-2 minutes and then I get a "Printer Out of
Paper"
: message in the pop-up. Of course, the printer has enough paper (and I
can
: print a sefl-test page from the printer). I also tried with another
parallel
: cable and it still doesn't work. I've tried uninstalling/reinstalling
the
: printer's driver many time and it's still not printing.
May 13, 2014 | Epson TM-U220D Matrix Printer
Won't let me set new printer as default
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured Right click on the error message select properties you will see all details about the error or click start type in event viewer press ENTER you might be able work your way through the problem
You can change the default printer to any other printer that you have connected to your computer. This will simplify your printing tasks, since you can select the most frequently used printer to be the default. These instructions are for Windows 98. Instructions for other operating systems or versions may vary.
Click on the Start menu and click on Settings, then Printers. A window will appear showing the icons of all the printers that are installed on your system. Right-click on the icon for the printer you want to use as the default. A menu will appear. Click on Set as Default. To make sure the correct printer is now set as the default, right-click on the printer icon again. When the menu opens, a check mark should appear before Set as Default. Default Printer for All New Users b> Microsoft Windows supports a number of printers connected to any one machine. Windows allows users to customize their preferred printer for one-click and quick printing. If you create a new user on a Windows system, the default printer will not be set. Windows 7 allows you to configure a default printer for all users with a quick command-line setting. You must have Administrative access to the system and have the printer configured to run this command. b> Click "Start" and type "Command Prompt" in the Start menu. Press "SHIFT"+"ENTER" to run the Command Prompt with Administrator privileges. Click "Start" and type "Print Management." Press "Enter." Look at the name listed under "Printer Name" for the printer you would like to make default. Double-click it to open the "Properties" dialog. Right-click the highlighted "Printer Name" label and click "Copy." Return to your console Window and type "ntprint /setdefault name=<printer name>" and press "Enter." Replace <printer name> with the printer name on your clipboard. You can paste this by right-clicking the console window and clicking "Paste."
http://technet.microsoft.com/en-us/library/cc731857.aspx
Jan 28, 2013 | Toshiba Satellite L505DGS6000 Notebook
My printer stopped printing? Canon Pixma 210 New
Go to START MENU
Choose Commamd prompt, right click mouse and run as administrator (You should be in this command C:\WINDOWS\SYSTEM32- If not type this command when you in the dos command prompt "CHDIR C:\WINDOWS\SYSTEMS32\ and press enter")
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C: drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer and must also turn off your printer and then switch it on.
It will work fine right now
I hope it helps you
Apr 20, 2011 | Canon PIXMA MP210 InkJet Printer
Hp officejet 6500a plus error message saying " refer to printer documentation 0x610000f6"
Hi try these solutions.
Go to START MENU
Exit
Go to C: drive
Click show content
Choose spool folder
Choose printer
Please try this solution.
Remove the USB cable into the printer and leave the printer on.
Remove all the cartridges.
Close the cartridge door and wait for the INSERT INK MESSAGE to appear.
Disconnect the power cable and from the power source supply.
Move the carriage using your hand from the original position to the other side of the printer and then move it back to original position. Wait for couple of minutes
Reconnect power cord and turn on the printer.
Return all the ink cartridges and close the door. Wait for the calibration process.
Print the test page to check if it working.
Reconnect the USB cable and try to print again.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
Apr 18, 2011 | HP Officejet 6500 Wireless All-in-One...
The printer green light keeps flashing and the message......"processing Port 9100" is on the screen. Won't print and it won't cancel any of the jobs in the queue
Hi
Try this solution
Go to START MENU
Exit
Go to C: drive
Click show content
Choose spool folder
Choose printer
I hope it helps you
Apr 14, 2011 | Dell 3100cn Laser Printer
Unable to carry out print command
Issue : Desk jet 5150 Not printing
Environment :
OS - Not provided
Printer : Deskjet 5150
Solution :
There could be 2 reasons for your problem
check the following links
Solution 1 fig are available
Step 1: Press the Resume button
Press the Resume button. Wait for approximately one minute and then print a self-test by pressing and holding the Power button and pressing the Resume button four times. Release the Power button. The self-test page should print. If the carriage is still stuck, go to the next step.
Step 2: Power cycle the printer
Turn the power off and back on, following these instructions:
1. Turn off the printer by pressing and releasing the Power button. If it will not turn off, proceed to Step 3. If it does turn off, proceed to the next step.
2. Turn on the printer.
3. If the Power light is on steady, print a self test with the instructions above in Step 1.
Step 3: Clear the paper path
Reset the printer and clear the paper path of any paper that may be jammed in it, using the following instructions:
1. Leave the printer turned on and disconnect the power cable and the USB or parallel cable from the back of the printer. Do not reconnect them until instructed later.
2. Remove the paper from the in-tray.
3. Remove the rear access door or duplexer (if installed) from the back of the printer.
Figure 4: Removing the rear access door
4. Open the top cover of the printer.
5. Check for and remove any paper still in the printer. A paper jam could cause the error message and the carriage stall.
6. Replace the rear access door, close the top cover, and replace the paper in the in-tray.
7. Reconnect only the power cable. If the printer does not automatically turn on, turn it on with the Power button.
NOTE: The printer may go through a warm-up period of up to two minutes. Lights may flash and the carriage may move. Wait until this warm-up period is complete before going to the next step.
8. If the Power light is on steady, do an internal test as described in Step 1 above.
If the carriage is still in a stalled position, contact HP Technical support to have the printer serviced.
IntroductionWhen printing with a HP Deskjet printer on Windows XP, the user may get the following error messages:
  • Error with USB
  • Out of paper message
  • Error lost communication with printer
  • Any other error messages related to communication.
The following performance failures could also be observed:
  • Partial page is printed, then ejects incomplete.
  • Blank page is ejected with nothing printed on it.
InstructionsThe error may be either a hardware or software issue. Firstly, make sure that all connections between the printer and PC are secure. Secondly, check if the printer can perform an internal test. Once the internal test has been printed properly, follow the instructions below to install a generic printer driver to know if HP printer driver is working fine:
  1. Click Start , Control Panel and Printers and Other Hardware .
  2. Click View installed printers or faxes .
  3. Highlight the printer to be removed.
  4. Click File and Delete .
  5. Click Yes when the deletion confirmation screen appears.
  6. Click File , Server and Properties .
  7. Click on the Drivers tab, highlight the printer to be removed and click Remove .
  8. Click Yes when asked to confirm deletion.
  9. In the printer folder , click on the Add a Printer task.
  10. Click Next and then, the Add New Hardware Wizard screen appears.
  11. Click Next on the Local or Network Printer screen.
  12. Click Next on the New Printer Detection screen.
  13. Click on the down pointing arrow next to Use the following port box and select USB001 or USB002 (virtual printer port for USB) and click Next .
  14. Under Manufacturer option, please select HP .
  15. Select the appropriate printer and click Next .
  16. Select Yes when asked Do you what to use this printer as the default printer? and click Next .
  17. Select Do not share this printer and click Next .
  18. Select Yes or No when asked Do you want to print a test page? and click Next .
  19. Then, click Finish .
  20. Try printing.
Jan 03, 2010 | HP DeskJet 5150 InkJet Printer
Transfer roller usage message on Phaser 7700. replaced..still wont print
I found the answer here: http://office.support.xerox.com/SRVS/cgi-bin/webcgi.cgi
Resetting Transfer Roller Life
  • Resetting the transfer roller life is to be performed only if the Transfer Roller Assembly was defective and or the assembly is replaced before an end of life or near end of life message. Not to extend the life of the assembly. Doing so may cause premature failure of other internal printer components.
  • The printer will prompt the user to reset the life counts if the assembly is replaced after receiving a Replace Transfer Roller or Replace Transfer Roller Soon message.
note_image33x30.gif    Note: If the main Menu does not appear on the front panel screen and only Replace Transfer Roller is displayed, there may be a print job that is either processing or currently printing. Try the following steps to clear the print jobs and reset the Transfer Roller life:
  1. Press the cancel button several times to flush processing jobs from the printer.
  2. If you do not receive access to the front panel menu by doing this, power off the printer and disconnect Ethernet, parallel or USB cable from the printer.
  3. Turn the printer back on, and while it is powering up, immediately start pushing the cancel key repeatedly until you receive access to the front panel menu.
  4. If the printer menu appears on the front panel screen, follow the instructions below to reset the Transfer Roller life if the printer did not prompt you to reset it:
  1. With Menus highlighted press OK.
  2. Press the Down Arrow and scroll to Supplies Info Menu.
  3. Press OK.
  4. Press the Down Arrow and scroll to Exit at the bottom of the menu tree.
  5. Now scroll up to Reset Transfer Roller Life.
  6. Press OK.
  7. Reset Transfer Roller NOW is displayed.
  8. Press OK to reset the transfer roller life.
Sep 30, 2008 | Xerox Phaser 7700 Laser Printer
Zebra Mother Board's problem
The main logic board is locked and needs to be replaced.
Sep 21, 2007 | Zebra Z4Mplus Printer: Internal ZebraNet...
HP LaserJet 4050 Printer Logo
Seeker5211
Seeker5211
