Question about Maytag Washing Machines
Maytag 3000 series washer error code F29 door is locked
  • 34 Answers
SOURCE: Maytag Neptune washer error FL
There is a manual door release tab in the dispenser area. You have to take the screws out and remove the dispenser to pull the tab and release the door. This is a pretty common issue, if you haven't yet you should contact your Maytag authorized dealer and ask about a more permanent solution. Hope you can get your clothes out.
Thanks
Posted on Apr 30, 2009
VtToolMan
  • 704 Answers
SOURCE: Planning to purchase a pair of 3000 Series Maytag
These days, everyone offers front loading washers and dryers. The things to know about them, is that unlike the old style top loading washers (and even the very old type of front washers from 20+ years ago) is that they function much differently.
First off, remember that you should only use He (High Efficiency) detergent and that the amount you'll be using is much less as well, so you'll have to change your habit of pouring in too much, as it will cause you problems.
You'll also need to get used to the different noises, or lack of, when the washer is running. Except for the spin cycle, you'll hardly know its running. Now about the spin cycle, most front loading washers go into "turbo" mode and get going very fast, which is great since it leaves the clothes barely damp in most cases when you take them out.
Now for the not so good issues with front loading washers. You'll want to also change your wash day habits by doing starting your laundry washing with the cold water washing first and finishing with your whites or hot water washing as the last load you do. The reason for this is that front loaders tend to retain just a little bit of water in them when they're done, and by doing the hot water loads last, you give the washer the best opportunity to keep any odor forming bacteria the least chance to start with.
Another key thing that none of the front load washer makers tell you to do is, keep the door of the washer open slightly when you're done with your laundry, as the door gaskets will hold some water and that is part of where the moldy smells, that many people experience, comes from. We've found that by doing that little thing, along with an occaisional wiping out of the door bellows gasket, keeps our washer from having any nasty odors.
Some folks recommend using special tablets once a month (Whirl-out), but I have an adversion to doing a "load" without clothes and hot water, and an cleaning tablet - seems to me that kinda of defeats the whole "less energy-less cost" premise of efficient front loaders. So by leaving the door open, we've avoided all that and haven' had the odor problems at all.
OK, by now you're wondering when I'm going to give you something on the Maytags you wanted to know about! Almost any front loading washer will do a great job and provide you with a decent working life. I prefer the GE, Maytag, Whirlpool, Kenmore, etc., but really don't like the LG's. My reasoning is that the LG's seem to have more issues with torn door gaskets and error codes than the others. While the LG's look nice and most folks buy them because they're so darned pretty, they are a disappointment in where it really counts, in my opinion.
So buy any of the American made washer/dryer units mention and you'll be very pleased with them, and by the way, the Maytag 3000 series, do look pretty nice too!
Take time to read your manual with your new appliances and you'll be ahead of most folks and get the best performance out of them for years to come!
Hope you find this Very Helpful and best regards!
Posted on Oct 24, 2009
kel1guy2002
  • 3740 Answers
SOURCE: getting f21 error on my front loading 3000 series
F21 is too long to drain:: (more than 4 mins) Check your drain hose outflow into a couple of 5 gal buckets it should flow pretty fast. If not, there is both a suds sensor and the water level pressure switch that can be causing the problem. Since you do not have SUDS showing on your control panel I am assuming the suds sensor is fine. The water pressure switch itself can cause the problem even if you hear audible clicks when testing with an external hose. A clogged drain pump strainer can do the same thing. Lastly... the obvious... is the drain hose kinked???? Good luck and hope this helps.
Posted on Jan 11, 2010
livewire874
  • 618 Answers
SOURCE: maytag 3000 series washer f70 error code only the
If you unplug the M13 connection from the ccu (main control) and the error goes away then replace the MCU (motor control unit) if it does not go away then replace the CCU
Posted on Nov 20, 2010
richroth
  • 9472 Answers
SOURCE: My maytag clothes washer Bravo quiet series 300,
What does the Sd code mean?
This code indicates that excessive detergent suds occurred during the cycle. The washer will not be able to spin out water with the excess suds. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the wash action and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This process is necessary and may occur several times to eliminate the suds.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
Use only HE High Efficiency detergent for BravosTM washers.
Is "Sd" displayed and the wash cycle dial is flashing?
This indicates the washer was not able to clear all the excess suds from the washer. Re-select your desired cycle using cold water. Press Start/Pause. Do not add detergent.
Is "Sd" displayed and the wash cycle dial is not flashing?
If "Sd" is displayed and the wash cycle dial is not flashing, allow the machine to continue running, even if it appears that nothing is happening. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the wash action will pause to allow the bubbles in the suds to break, and the washer will add water for better rinsing. This rinsing process is necessary and may occur several times to eliminate the suds.
Is the drain hose kinked or clogged?
Make sure that the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose.
To remove the error display, press Power/Cancel or Pause/Cancel once.
If Power/Cancel or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start/Pause.
NOTE: If the error remains on the display, and all of the other questions above have been checked, call for service.
Posted on Dec 27, 2010
I have a maytag 5000 series washer. We are getting an f21 error code. I unscrewed the white drain filter and cleared it. There was little in it. I keep getting the f21 error though. Can you help?
Search Results
    whirpool f21 error code - YouTube
    ? 3:04
    https://www.youtube.com/watch?v=b24PVv-ORqg
    Jul 1, 2012 - Uploaded by davidmontabon
    whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
    My maytag 5000 series steam washer stopped and said Sud ...
    www.fixya.com/support/t8682656-maytag_5000_series_steam
    Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
    Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
    fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
Feb 09, 2016 | Maytag Washing Machines
Code f10 and f29 came up while On self cleaning what does this mean ?
Washer Error Codes Below is a list of... - Elite Appliance ...
https://www.facebook.com/permalink.php?story_fbid...id...
Right now you will find error codes for Asko, Fisher & Paykel, Frigidaire, GE, Kenmore, LG, Maytag, Samsung, ... Check pump trap and clean. ... Musical series of beeps every 5 seconds and Wash cycle light flashing-Washer is overloaded. ... E47--Board thinks the door PTC circuit is open in spin .... F29--Door unlock error
Range Error Code F10: Troubleshooting Runaway Oven ...
? 2:20
https://www.youtube.com/watch?v=z6tcnpDKDns
Oct 1, 2015 - Uploaded by searspartsdirect
If you see F10 on your range, it means that your electroni. ... exceeds the temperature you set it at in either .
Nov 07, 2015 | Electrolux E30EW85EPS Electric Kitchen...
Maytag 3000 series front load washer has code F29. What does hat mean?
That error is a control board error. You might want to try unplugging the power for 5 minutes to see if it resets. If you using the pause cancel and start sequence don't work then you need to replace the control board.
Oct 04, 2014 | Maytag Washing Machines
Code f 29
F29 is a door unlock error, this error occurs after the washer has made 6 attempts to unlock the door. Usually this occurs when the door lock mechanism is broken and/or the door switch/unit lock has failed. To resolve this issue you'll need to check the door switch, door lock mechanism and the wire harness between the central control unit & door switch, replace the part that has gone bad.
Aug 13, 2012 | Whirlpool Duet GHW9150P Front Load Washer
When i try to start my washing machine it is giving f29 error
F29 is a Door Latch Unlock error. This occurs after the door attempts to lock 6 times. With no successful lock achieved, the error code will be generated. Check the following:
  1. First, UNPLUG the washer in an attempt to reset the Central Control Unit (CCU). Sometimes this is all that required in order to clear momentary glitches with the unit. If the error code reappears, proceed to step 2.
  2. Check the door switch/latch for foreign objects that may have become lodged in the mechanism and may be preventing it from operating.
  3. Check the wiring harness from the CCU to the door latch. The harness can be accessed by removing the washer top panel. Remove the panel by removing the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, and then off
Dec 26, 2010 | Washing Machines
When we start our Maytag Series 3000 washer we are getting a F-29 code about half the time. What is a F-29 code?
"F29" is a door latch error code. The following link explains many causes of the error and possible recommendations to correct the problem:
http://www.fixya.com/support/r3608614-f29_error_code
For an explanation of all the error codes, each one of these washers comes with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
Read through the information provided and if you have questions, please post back and let me know. I hope you find this information helpful.
Nov 17, 2010 | Maytag EPIC MFW9700S Front Load Washer
What does an f22 error message on my Maytag 3000 series washer mean?
F22 is door lock error. This is usually fixed replacing the door lock. Connection from door lock to CCU (control panel) may also be responsible.
Nov 01, 2010 | Washing Machines
Error code F29 continually reappears on our washer which is only 4-5 months old. We have tried to troubleshoot the problem, but have had no success. HELP!!!!!
Hi
Thanks for using FixYa. F29 is a door unlock error, this error occurs after the washer has made 6 attempts to unlock the door. Usually this occurs when the door lock mechanism is broken and/or the door switch/unit lock has failed. To resolve this issue you’ll need to check the door switch, door lock mechanism and the wire harness between the central control unit & door switch, replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Showing F29 ??
  3. Check the wiring harness from the CCU to the door latch. The harness can be accessed by removing the washer top panel. Remove the panel by removing the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, and then off.
COURTESY:JSROCK- A SENOR EXPERT OF FIXYA
http://www.fixya.com/support/r1484196-f29_error_code_whirlpool_duet_kenmore
May 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
187 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
