I have the mitsubishi diamond screen tv, and the picture keeps cutting out and turning blue. After I turn off the unit and re start it, it works for a bit, then does the same thing again ?
  • 1,056 Answers
Usually this is due to bad reception. If you are using a satellite dish it can be due to bad weather. Usually the picture will pixelize then turn to blue.
Posted on May 28, 2011
I'm back.my mitsubishi ws-48413 tv only has a blue screen when i turn it on. Ive tried several things. I tried turning on the receiver first and waiting 10 seconds and the opposite. I rebooted the tv...
There is a communication error between the source & the TV. When powering up the units, try turning on the receiver first, then turn the TV on, that way there is a signal for the TV to detect at initial start-up.
Dec 12, 2014 | Mitsubishi Televison & Video
I turn on my Mitsubishi WD-73833 TV and it turns itself off
Lessing of brightness on a DLP set is a sign of imminent bulb failure.
A new bulb is in order.
Nov 23, 2013 | Mitsubishi WD-73833 73" HDTV
Our Mitsubishi WD 52525 goes to blue screen and shuts off.
It sounds like you TV is overheating and the video is suffering and the lamp is overheating as well. Also, if your TV is over 2-3 years old, the mirrors (behind and below the big front screen) desperately need to be cleaned. Clean all filters and fans as well. (Look on side and behind the unit). Is the TV in a "hot" environment and/or dirty environment? DLP TV's are NOT sealed units. They need to be cleaned every few years to work well to have a good, clear, bright picture.
Jun 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi 1080 diamond tv screen turns off
Your tv has a lamp inside (refer to your user's manual) make sure is in good condition.
Mar 21, 2009 | Mitsubishi Diamond WD-65831 65" Projection...
No picture or sound mitsubishi 62525
Capacitor failure is the most likely scenario the FMT ans Signal PWB would cause the picture interference and the power pwb would cause the lamp light to turn red and give a 34 code when the device/ input and menu buttons are pressed in together and held for five seconds. That chassis has issues with every board in the chassis having failed capacitors you can get repair kits for the V26 chassis at the follwing link that come with instructions. Your model is the V26 chassis. Heres the link.
http://servicemanuals.vstore.ca/
Jan 25, 2009 | Mitsubishi WD-62525 62" Rear Projection...
I loose picture on my big screen
bad voltage regulator - BA09FP requires a bit of tech experience to replace, but its relatively easy. It took me about 1 hour to replace mine. If you need clarification on this, email me at Doin12volt at yahoo
Jul 03, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi diamond hd1080
It sounds like you will have to replace the convergence IC's in this TV set. Not a really hard repair to do but you will need to know how to solder and work on solid state printed circuit boards. Good Luck
Jun 29, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi black diamond tv
Might be a bad CRT or bad video output IC that drives the CRT that would cause this issue.
Apr 07, 2007 | Mitsubishi VS-1250 TV
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
