My vcr philips vr899/75 does not power up how to fix this.
Tip
Hey tech guy. Have a Magnavox ZV450MW8 DVD \ VCR combo. Unit loses all...
One fix to return DVD player to origional setings, is to go in to the menu and find the factory reset option the will return the setings back to fresh from the factory.
Regards Tech Guy
on Sep 07, 2008 | Panasonic DMRES30V DVD Recorder/VCR Combo
I am trying to get my Radio Shack universal remote (#15-302) to control a Philips DVD/VCR combo (model no. DVP3345V/17). I've read the manual, and there are multiple codes for Philips DVD players and...
If you have a manual for your RS remote , there should be a section on how to search for a code automatically. If not you have to buy the original remote, from Phillips online.
Hope this helps.
Apr 13, 2011 | Philips DVP3345V/17 DVD Player/VCR
Philips VCR model VRX364AT. Remote controller stoped working. No response from the VCR.\r\n Tested controller by pointing it at a cell phone camera to see if infrared light was visible. It is not. Can...
Internal damage to remotes is common, generally most are not worth fixing. If you look on the remote you should see a model number for it. Put that into google and see if the remote is cheap, or if not it might be better to attemp repair.
Aug 16, 2010 | Philips VR620CAT VCR
VCR stuck in VCR eject mode
You can get the manual here. Maybe it will help:
http://www.retrevo.com/support/Philips-27MC4304%2F17-TVs-manual/id/277bh936/t/2/
Jul 16, 2010 | Philips 27MC4304 27 in. TV/VCR/DVD Combo
Have a Magnavox MWR20V6 - have a few things going on, one the power shutting off automatically when i put the vcr on timer and therefore does not record, and 2 vhs tapes that are almost new, gets stuck
Junk it. It's identical to Funai WV20V6. I can't remember exactly what is causing the shutdown. But, I do remember that it says it can't be fixed. Read other posts here at Fixya.
"Funai wv20v6 dvd/vcr player recorder"
Mar 17, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Problem with philips magnavox vcr
Most Philips/Magnavox VCR uses "PL" to indicate that the unit is on Parental Lock. Push and hold the power button on the remote control and wait for the unit to power up. This should be within 7 seconds.
Additionally, most (but not all) Philips/Magnavox VCRs are sub-contracted to Funai. Pls try here for Funai downloads of user's manual.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 16, 2008 | Televison & Video
Philips DVP 3150V
saida horizontal com deficiencia faz com que a fonte aciona circuito de proteção.
Feb 09, 2008 | Philips CCB092AT 9 in. TV/VCR Combo
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
