Question about Sony FD Trinitron WEGA KV-29LS35 29" TV
Is it widescreen or standard screen - Sony FD Trinitron WEGA KV-29LS35 29" TV
  • 373 Answers
Standard glass tube (screen)
Posted on May 28, 2011
Screen flashed and stopped displaying widescreen
Usually this is because the display has been changed from 16:9 (widescreen) mode to 4:3 (standard) mode. On the front panel there's a button labelled "4:3 in Wide." Press this button to return to Widescreen mode. If it says "OSD Locked" then you need to hold the "Menu" key for several seconds to unlock the controls, before changing it to widescreen.
If that doesn't correct the problem then you need to adjust your computer's output resolution to a 16:9 ratio like 1920x1080 (1080p) or 1280x720 (720p.)
Oct 22, 2012 | LG W1934S-BN 19" Monitor
The screen for Wii Zumba Fitness is very small and the prompts I can't read. Furthermore, one of the tutorials goes very fast -- it must be a glitch
Hopefully you have gotten this problem solved. If not, go to WII options -> settings -> screen -> widescreen setting -> change from standard to (widescreen (16:9)) and retry. This worked for me.
Dec 12, 2010 | Majesco Zumba Fitness for Nintendo Wii
I install window 7 but my benq 15" lcd monitar's screen rosuation not competible. pls guide me how i increase the rosulation thnx
As for your 15" LCD BENQ Monitor, "1024 x 768" pixels is the Maximum Resolution
If you increase your screen higher than the Maximum resolution you get a black screen! because the monitor cannot support the resolution higher than "1024x768" pixels.
How to change your screen resolution Win 7-> Link
FYI
Here are typical resolutions for some popular screen sizes
19-inch screen (standard ratio): 1280 x 1024 pixels
20-inch screen (standard ratio): 1600 x 1200 pixels
22-inch screen (widescreen): 1680 x 1050 pixels
24-inch screen (widescreen): 1900 x 1200 pixels
Hope it helps.
Nov 22, 2010 | Computers & Internet
Why my regular dvd player with widescreen movies does not fill my hd tv ?
ok, There are 2 aspect ratio's for tv/movies. Widescreen Standard
If you have a Widescreen TV, Widescreen formatted dvd's will fill the hole screen, Standard formatted dvd's will not fill the whole screen
if you have a Standard TV, Standard formatted dvd's will fill the whole screen, Widescreen formatted dvd's will not fill the whole screen
this is normal, check to see the format of the dvd you are trying to use.
Jul 03, 2010 | Zenith XBV442 DVD Player/VCR
I have a widescreen monitor at home, my parner
Find the menu button on the monitor, and make corrections as you need to. This will all show up on screen as you make the adjustments.
Oct 01, 2009 | Computers & Internet
Picture is only in middle of screen, top and bottom of screen is blacked out
If you are watching widescreen format movie or tv programming on a non-widescreen tv, that is how it will appear. The widescreen is a wider picture so to show it on a less wide screen, it has to shrink down to fit. and leave blank space top and botton.
If not, sorry.
Sep 12, 2009 | Toshiba 36A40 36" TV
3 inches missing on both sides
Sounds like it is a widescreen TV stuck in standard view mode. Should have a menu option called widescreen or movie format.
Do you see the whole picture squeezed down or is it actually cutting off the sides of it?
Jan 08, 2008 | Proscan PS32125 32" TV
Screen resolution
From the Console Settings screen in the System area of the Xbox Dashboard, you can configure the video output of your Xbox 360 console.
Change your display output settings from this screen. Display settings include screen resolution and screen dimension (or aspect ratio, either standard or widescreen).
In some cases you can select an "Optimal Resolution" button, which appears only when Xbox supports the native resolution of the TV or monitor and automatically applies the best setting but that might not work with your tv.
If you are using VGA you must choose from among the following output resolutions: 640 x 480, 848 x 480, 1204 x 720, 1280 x 720, 1280 x 768, 1280 x 1024, 1360 x 768, and 1920 x 1080.  Much like a PC you would want to select a lower resolution (640X480).  That will make your fonts larger.
Screen Format: The default setting is Normal (a standard 4:3 aspect ratio); select Widescreen to change the output aspect ratio to 16:9 if you have a widescreen TV or monitor.  You should select normal and not widescreen for a standard tv.
Hope this helps,
Bob
Dec 26, 2007 | Microsoft Xbox 360 Console
Playing back widescreen problem
The TV itself uses the CTC203 chassis and is not capable of switching between normal and widescreen. This is an issue with your DVD player and not a problem with the TV.
Jul 16, 2006 | RCA F27442 27" TV
Sony FD Trinitron WEGA KV-29LS35 29" TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
