Question about Acer Aspire 5600 Series 5630-6951 Laptop
My ASPIRE 5520-5290 just died while I was on-line using the battery. Once I plugged it in, it never booted up and I still have no powwer??
I have the same problem :[
Posted on Aug 16, 2008
SOURCE:
After booted up and just sitting there for a few
Get the battery checked. Its malfunctioning. you probably might need to buy a new one.
May 06, 2010 | Acer Aspire 6920 Notebook PC
My Acer Aspire 9805 battery was replaced. For
It could be an AC adaptor issue.
It should boot when connected directly to the power outlet through the laptop adaptor. If it is not boot, then the adaptor might not be supplying the needed power to boot it up.
If it is possible, try to isolate the issue. Charge your new battery using another laptop. Then plug it in your laptop to see if it works. If it will work, then it is the AC adaptor of your laptop that is defective. If the charged battery still won't make the laptop boot, then there is something wrong with your laptop hardware. If could be a motherboard issue of your laptop.
Feb 23, 2010 | Acer Aspire 9805WKHi Notebook
Hello there, i have problems whether plugging the AC supply into my acer aspire 6920G laptop. when i plugging the AC, the laptop will suddenly shutdown, then boot up again. but when im using battery, it...
I am sure its totally fault of your OS. Becouse some when ac working well, some where battery. your OS does not recognised your power control properly. Try to use single OS and get batter result. if done thumbs me.
Dec 16, 2009 | Acer Aspire 6920 Notebook PC
My computer will not boot up Acer 5050 all the lights com on but it never boots the screen stays black. it will not turn off unless you remove the battery.
If you have a VGA cable and a monitor, attempt to plug this into a monitor to verify that the laptop will not boot into your OS (Windows generally). If it does end up booting into your OS, then it sounds like your LCD has died or become unplugged inside the laptop.
Nov 25, 2009 | Acer Aspire 5050-3242 Notebook
BATTERY BACKUP JUST 30 MINUTE
Sounds like your battery in your laptop only lasts 30 minutes.
This happens for 2 reasons.
  1. The battery is old and worn out.
  2. The battery was never used or exercised.
If its old its just time to replace it. The batteries only have so many charge cycles before they go bad.
If you have never really used the battery, and have always used it plugged in, the battery just went to waste. If you don't use it the cells in the battery will slowly die from not being used.
You have to purposely run the laptop on battery until it says low battery once in a while.
This laptop is 7 years old that I am using right now and it still has the original battery and it works good because I always un plug it and run it off battery at least once a week.
Nov 25, 2009 | Acer Aspire 1360 Notebook
The aspire 3680 will not trun on. battery will not charge. even with the charger plug in
plug unit into wall remove battery boot computer. if it boots up you will need to replace your battery
Nov 14, 2009 | Acer Aspire 3680 Laptop
Acer aspire laptop won't charge
First of all you have to determine whether it's the battery, charger or the laptop itself.
Remove the battery and boot the laptop on AC power only, if the laptop boots up you can rule out the charger and the laptop, you may need a new battery if that is the case.
Regards.
Sep 08, 2009 | Acer Aspire 4520-5582 Notebook
My acer aspire 5315 doesnt boot up the power
remove the battery and plug in power..if it works then your battery having problem..if not then ur power adpter having problem...
Apr 20, 2009 | Acer Aspire One PC Notebook
Acer aspire 5100 won't stay on when booting on battery
replace the battery. Batteries usually only last about two years and it sounds like it just cant hold any more juice. To find a battery go to google.com and type in the model of computer and push search. Sorry for the news but its an easy fix
Dec 30, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 9300 Mainboard battery?
I agree with leecom72's suggestion,beside this, i suggest you exchange the battery.in my opinion,i guess the main problem is your laptop batterya0a9e16.jpg has lower lifetime or the battery quality is very bad.there is an online shop website which specialized exporting replacement batteries,it also contents some technology of how to use oe maitain laptop battery well, I believe it's very useful to you.
Nov 14, 2008 | Acer Aspire 9300 Notebook
Acer Aspire 5600 Series 5630-6951 Laptop Logo
122 people viewed this question
Ekse
Alun Cox
