Question about Hyundai ImageQuest B70A 17" LCD Monitor
Screen is black light is orange when i connect rgb cord
My monitor displays analog rgb then goes to blank black screen?
Here's some tricks I would try. Something here, might help...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your monitor on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Aug 04, 2014 | Xerox Computers & Internet
How to solve acer monitor sleeping issue?
Press left mouse key and wait 10-15 seconds. Black screen and orange light is caused by computer going to sleep. Adjust your power mode.
Apr 30, 2014 | Computers & Internet
Ibm thinkpad wont connect to LG TV
Lower the screen resolution to 720 dpi.
Another issue is the reference to RGB. Is it the 3 cable (YPBPR) or the standard 15 pin VGA? You may need a converter.
Oct 08, 2012 | IBM ThinkPad T40p 2373 Notebook
I have dell c840. Suddenly only the left most light of the three lights gets orange when power is switched on and then there is no activity and screen remains blank. Bty light when plugged in also remain...
hello
shut down computer - unplug power cord from laptop - remove the battery from laptop - plug Ac adapter into computer and Ac outlet (wall)
turn on computer
if computer does not turn on, replace the AC adapter and cord - then place battery back into computer
plug in new Ac adapter and cord - recharge battery - if orange light stays on after 4-6 hours of charging battery, you need new battery as well - replace battery, charge it up and it should be fine
if you have attempted these steps before and no change occurs, then you may have issue with power connection in computer - locate a service centre to replace power connection on computer
Nov 07, 2010 | Dell Computers & Internet
My phone was dropped and the touch screen and the inside screen is all black. Also the top half is broken where it closes and you can see the orange cord connecting the screen and keyboard from the inside...
Both the screens need to be replaced as the orange cord is connected to the screen and cannot be replaced separately.
Unfortunately it will require a visit to a service center. If you would like to replace the parts your self, let me know.
But you should know that it will requires special screw drivers and may cost you more than a service center. Also if the damage is extensive, its more economical to buy a new phone.
Sep 25, 2010 | LG enV3 VX9200 Cell Phone
The screen wont turn on but the computer is
> try to power drain the computer by pressing the power button while the battery and the power cord is unplugged,removed the battery first and unplugged power cord then press and hold the power button for at least one minute
Jun 27, 2010 | Toshiba Satellite A100-S8111TD Notebook
I was given a Xenon flat screen monitor. The back has 4 usb ports and 1 usb input and an analog rgb port. It came with no cables. Can I just use a usb cable or do i need the analog rgb cable? Also when I...
The USB hub/connections cannot be used for driving the monitor... It is only an extra feature so that you can connect USB devices (such as a mouse & keyboard or flash drive) at the monitor instead of the computer ports.
You must use the RGB/VGA connection to use the monitor.
When you turn ON the monitor, it should "announce" itself with a logo...
When you were given the monitor, were you told that it works?
Please connect the monitor and comment back...
Thanks!
Sep 10, 2009 | Computers & Internet
What colour are the power wires, are they green & yellow, black, black & grey, blue & grey, red & grey or black & green. I want to connect a cd/radio player but don't know what wires connect to the cd...
JVC KW-AVX800 The black wire is your ground The yellow is your positive 12v constant so connect this to the wire that has 12v when the car is off. The red connect this to the key switch wire meaning the wire will have a 12v signal only when the key is tured to the on position. The blue is for a power antenna the blue/white stripe is if you have external amps this wire goes to the amps remote on The orange/white stripe connect this wire to your cars dimmer switch Happy Wiring
Mar 21, 2009 | JVC KW-AVX800 CD Player
LG 32LG30 no signal when pc and tv r connected via rgb cord
For No signal try- Updating your Video drivers, and making sure it shows a connection on your laptop ( by going to propertys on desktop and then dysplay)
For format try- Updating and or turning down the screen resulotion becuase the size differs on screen even if you think it shouldnt.
Mar 14, 2009 | LG 32LG30 32 in. LCD HDTV
MONITOR NOT COMING ON . RGB NO INPUT SIGNAL .
You first take post( power on self test) connect power cord & disconnect signal cable you will see massage no signal check siganl cable then problem will be in cpu this problem may be solved by cleaning dust in cpu if montor shows no display then problem will in monitor open it check o/p of smps if not disolder path of eht if o/p comes then eht is faulty replace it
Oct 28, 2008 | Computers & Internet
Hyundai ImageQuest B70A 17" LCD Monitor Logo
29 people viewed this question
Top Hyundai Computers & Internet Experts
Tom Stevenson
Level 1 Expert
Randy Schumann
Randy Schumann
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
