Question about Apple Cell Phones
How can you unblock a imre number without additional infomaton iphone 3 gs
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 104 Answers
You cant unblock a phone once its blocked
Posted on May 28, 2011
I would like to unblock a number 352 428 4215
A make and model of phone would help? We can't do it, you have to do it yourself.
Steps to block a number on your iPhone 6.
  1. From the home screen, tap the Phone icon.
  2. Tap the Recents icon.
  3. Scroll to the preferred contact and tap the Info icon.
  4. Scroll to and tap Block this Caller.
  5. Tap Block Contact.
How to Block or Unblock a Number on your iPhone 6 - Sprint Support
https://support.sprint.com/...Unblock-a-Number.../WHowToSetupGuide_542_GKB8146... Feedback
About this result
Block or unblock contacts on your iPhone or iPad ' Vodafone Support
vodafone.intelliresponse.com/index.jsp?id=1911...Block...unblock... Block on iPhone. Make sure you've saved the phone number and/or email address as a contact first. Block on iPad. Make sure you've saved the phone number and/or email address as a contact first. Unblock on iPhone. Open the 'Phone' app. Unblock on iPad. Open settings and tap 'Messages', or 'FaceTime', and then 'Blocked'.
how to unblock a contact on android - AndroidFact
androidfact.com/how-to-unblock-a-contact-on-android/ Jun 15, 2016 - If it turns out the number you are trying to unblock is not in your contact list you will have to head on over to the call log and find the number you ... unblock number Google Search
Jan 17, 2017 | Cell Phones
Tip
IMR - Inlet Manifold Runner valve
1.10) IMR- Inlet Manifold Runner valve (actuator)
What is it? The inlet manifold consists of a plenum chamber onto the front of which is mounted the throttle . Extending from the plenum is a series of moulded pipes called 'runners' curve round to the intake ports on the cylinder head. In some instances there are two intake ports for each cylinder fed by slightly different lengths of runner. When the engine is at low revs the longer pipe works well. However at higher speeds the shorter length of the alternative runner is better suited. To cater for this the shorter port, which is normally shut off at low engine speeds by a plate (very similar in operation to the throttle plate), is opened by a motor or solenoid. The shorter runner is usually opened in addition to the longer runner and not as a substitute. The opening of this additional shorter runner is done by the IMR.
Where is it located? The IMR valves are located in the throat of each inlet port and the controlling motor is located at the end of the interconnecting shaft.
How does it work? At a predetermined engine speed (>3000rpm) the ECU sends a voltage to the IMR that snaps open the additional inlet portsto boost power output. It does this by either a) directly with an electrical motor or b) it opens a solenoid valve and allows vacuum, sourced from the inlet manifold, to act on a diaphragm to rotate the valve shafts.
Symptoms of a faulty IMR
Associated OBD2 error codes DTCs: P1500 - P1599
  • Power reduction - If the IMR fails to open in the upper rev range the engine will seem to lack any (power) 'head-room'. The engine will still operate but the usual additional power boost in the upper rev range will be absent.
How to Check? Visually check the action of the action of the actuator in response to increasing engine speed.
How to Fix? Check the wires and connections. If the device uses a vacuum, check the tubing for leaks. If the IMR unit is faulty replace it.
NEXT 1.11) EVAP - Fuel Vapour Evaporative Control System
on Jul 22, 2011 | Mercedes-Benz E-Class Cars & Trucks
I have one telephone number in my phone that is on mute so that when she texts or calls me it doesn't alert me
The contact is probably Blocked. It happens by accident sometimes.
On iPhone, go to the Contacts App, Find the affected contact and select it. Scroll to the bottom and select 'Unblock'.
On android it can vary. In general... Go to Contacts app...Select the Contact that is not ringing. Now, select the 3 dots in top right of the screen. There should be an option to 'Unblock'.
Also added guides with pictures I found online for you. Hope this helps.
How to Unblock Phone Numbers on Android Block calls and block or filter messages on your iPhone iPad or iPod touch
Oct 25, 2016 | Cell Phones
I have a blocked number pranking me how do I unblock iy I have a I phone 6
why would you want to unblock it.....and how is it even ringing your phone if it IS already blocked.?
next to the number on all you received calls....click the little i (info) button, scroll down and block or unblock.
Jul 11, 2016 | Apple iPhone Cell Phones
How to restore blocked number
Unblock by going to:
  1. Settings
  2. Phone
  3. Blocked
  4. Edit
  5. Delete number you no longer want to block.
Sep 01, 2014 | Apple iPhone 4 Black Smartphone
Unblock my iphone
Do you want to get your iPhone unblock/unlock from Network lock?
You can get your iPhone unlocked from Network lock using Remote unlocking method.Which is the safe and secure method to unlock iPhone.You can get this service from SimpleUnlocking.com here you need to specify your country,Network name to which it is locked,IMEI number of your iphone.Here they unlock your iPhone latest versions of iTunes.This is a permanent unlocking solution.Both Upgrading and Downgrading will not lock your phone again.
Mar 14, 2014 | Apple Iphone 4s I Phone 4 S Factory...
Pair visor go bluetooth with iPhone 3GS
iPhone 3 GS, This should be able to help you: http://www.lcd-screen-digitizer.com/iphone/iphone-3gs-usb-port-flex-+mic+ringer-speaker+antenna-us.html
Sep 27, 2012 | Supertooth One Bluetooth Visor...
Unlocked GS can't locate wifi connection.
yeah u can , and u need a software for your settings
Jul 13, 2009 | Apple iPhone Smartphone
Cell Phones Logo
46 people viewed this question
Top Apple Cell Phones Experts
David
Martin Murray
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
