Question about Panasonic Computers & Internet
Trying to use network easy settings to connect to the internet using the panasonic DMR-BW880, the LAN cable connection gets a pass and the IP address settings says that the home network is available, but connection to gateway failed., not sure what to do from here, asks to check the settings of broadband router. It is currently setup as a wireless homenet work. Can someone point me in the right direction.
3 Suggested Answers
kakee
  • 1269 Answers
SOURCE: Connecting PSP to wifi
Change the primary DNS of your PSP to 4.2.2.1 and secondary dns to 4.2.2.2
Posted on Apr 25, 2009
Eclipse412
  • 23 Answers
SOURCE: i am trying to connect
This could be a few things. 1) Did you ever set p your router to only put out so many IP addresses? Meaning normally it is set for 50 IPs but a lot of people go in and set the IPs up for only how many computers are on it. This causes problems when people come over your house and connect their phones and such. 2) Some time when you put on new devices you have to reset your router. It has conflicts sometimes and all that is needed is a good reboot. 3) I don't know your unit but make sure you have everything setup to be auto on your device. Meaning auto ip, DNS and, Gateway on your player is set that way. 4) It maybe that your cable is bad. Just to make sure it isn't the cable try it on a laptop. Making sure you turn off your wireless on the laptop when you try this. Is the cable is bad the wireless will still pick up an IP faking you out thinking it works.
Hope this helps.
Posted on Jun 23, 2011
I am trying to connect a panasonic blue ray recorder model number dmr bw 780 to the network i have followed the instrutions on connecting a lan cable to the unit and connecting the other end to a router...
Hope this helps.
Jun 23, 2011 | Computers & Internet
Trying to connect two computers to the internet through a router (not wireless) having problems after connecting both computers to the router, only one computer has internet connection. My internet...
Initially check whether the ip address is assigned in the computer in which internet is not browsing using the command ipconfig/all for windows and ifconfig for linux.If ip is present try to ping the default gateway ip address,if ping is success there is no issue in the cable you used and also with ip address.If ip is not assigned assign ip by manually or by using dhcp of router.Enable and disable the lan card in the router so that sometimes the problem get resolved.After ip is assigned and ping with router is ok .Ensure dns servers are correct else give google public dns server 8.8.8.8.Then try to ping www.google.com in command prompt if ping is success then you can browse.
Mar 01, 2010 | HP Pavilion a1610n PC Desktop
Cannot connect to the internet
how are you trying to connect it? if you have wired internet, just plug the LAN cable at the RJ-45 LAN port of your laptop and you will be connected. You must have set your LAN Adapter to get IP Address automatically. Also, if you have a wireless network adapter, if you set it up to get IP address automatically, you can connect to available wifi zone.
Sep 15, 2009 | Apple Powerbook G4 15" Screen Mac...
One static IP has internet. how on a LAN?
You need two network adopters in your system.
Connect Internet connection in first Network card and from the other network card give it to your Switch or hub
If you are using XP system you can use Internet connection sharing to share the internet in your LAN systems.
Follow the steps to enable using ICS
1.Enable Internet Connection sharing in the LAN properties in the first network card.
2.Now your second network card automatically get an IP address in the range of 192.168.*.* series
3.Connect other systems in the LAN and make sure the system has selected Optain IP atomatically from DHCP.
You are all set.
There is also an advanced way to setup this .
Install IPCOP firewall in a system with two network cards and u can share the internet with the firewall settings
Aug 28, 2009 | Computers & Internet
Router -> Modem Connectivity: I am fine if I'm hard-wired to the modem but if I connect wirelessly through the router I can't get WAN. I can get the modem page wirelessly. This just started tonight. I...
Have you check your DNS settings within your Wireless Network Adapter TCP/IP properties settings? Or it may be a proxy server or firewall settings wich may block internet access to the internet. Try testing it with your LAN cable first and see if you are able to connect to the internet using that cable from the laptop/pc to the modem. If it works using the network cable then it might be a DNS related issue on your wireless network adapter tcp/ip properties.
Jul 29, 2009 | Belkin (F5D5231-4) Router
Unable to connect with dlink300 router
You must configure first its settings both on your network card and router. See you manual.
First you must connect your internet directly to the computer then get its DNS settings, jot it down. Then connect the router lanport1 to lan card port of your computer using LAN cable. Under lan properties goto TCP/IP settings input the default IPaddress 192.168.0.1 of the router then its subnet mask commonly 255.255.255.0, the router's default gateway, input the DNS settings of your ISP 2 of the set.
Then goto default router's utility web. Open internet explorer, key in router's ip add 192.168.0.1 you should go to router's configuration log in user = admin, pass = just hit enter. Set your time and date then save. You could also test its connection by pinging the IP address of router. on windows DOS. Type ping 192.168.0.1 you should get 4 lines.
If everything is set. Connect the internet cable(UTP/LAN cable) to its WAN port of the router then test to browse the internet. If not then change the DNS settings with the remaining set (on Lan setting).
If I miss something just leave a comment.
May 22, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Apr 25, 2009 | Linksys WRH54G Wireless Router
Can't connect to my router
Try this;
Just set it again via wired connection or LAN. Access it via Network Connections, and under Network connection look for for your LAN. Right click Local area connection,click properties, then highlight Internet Protocol(TCP/IP), click properties. Under General choose "Use the following IP Address ".
Input on IP address you should have router tutorial. Commonly its default is 192.168.1.1
Subnest Mask 255.255.255.0
Default gateway 192.168.1.2
Under it choose " Use the following DNS server address"
Input DNS address DNS of your ISP
Click ok
goto Inernet browser tab input 192.168.1.1 this will direct you to router configuration setting input its user and pass. If unchanged see tutorial of your router or at the bottom of the router. Then you can change setting of your router.
Hope it helps.
Apr 08, 2009 | Zyxel Prestige 660R Router (P660R)
Computer says connected to internet,, wont display page
usually routers are setup using DHCP... on your second computer. try going to
start, control panel,  networkconnection,  "your LAN connection",\ properties Internet Protocol (TCP/IP) (should be checked)
Obtained Ip address automatically should be selected
Obttained Dns server automatically should be selected.
then click OK, OK to save settings...
if your router is not setup as a DHCP,it would require you to setup your ip address manually... let me know if this dont work, so  i can help u setup manually...
if it helps, try comparing the settings of your pc1 and pc2 (the network connection settings)
Feb 02, 2009 | D-Link DSL 604+ (DSL-604+) Wireless Router
How to set up for internet use with muliple pc's
I assume you router came with a configuration manual or CD. Its very easy. Once by following the instructions, go into the router like:
http://192.168.x.x (whatever IP is suggested by the manufacturer) and make sure the internet connection type. Mostly the ISP's use 'Dynamic IP' (if you scroll other ones will be like PPPoE, PPTP etc). Select Dynamic IP and restart your router and you will see after few seconds that your router has started to offer IP's to the internal Lan Pool. connect your ethernet cables from the computers to the router (behind the router you will find the ports to connect them)
In your Network settings in the router assign an internal IP to the router like '192.168.x.x' subnet mask 255.255.255.0, enable DHCP server and assign the internal LAN ip pool like 192.168.x.20 to 192.168.x.100 and you are all set.
Very important:
Security settings Always make sure your router (if in case its wireless router as well) assign and use an authentic security feature like 'WPA, PSK or WPA2, PSK' you could also use WEP (but WEP its getting old) I recommend WPA higly for wireless clients. If you have NONE wireless connections to offer than do not worry about it.
OR
simply put the CD inside your system connect it with router and it will guide you through for configuring it.
I hope it helped
Dec 16, 2007 | Linksys EtherFast Cable/DSL Router
Computers & Internet Logo
47 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
