Question about Noritz N-069M-DV, N-084M, and N-084M-DV Pipe Cover
The burner is not coming on model N-069M - Noritz N-069M-DV, N-084M, and N-084M-DV Pipe Cover
N-069m pulsating when hot water is turned off.
Do you have a well our on city water? Check in coming water pressure make sure it is not over 60psi
Sep 14, 2014 | Noritz 6.9 Gallon Residential Tankless...
I have a Model N-069M and i get a flashing code 16. I just had the unit flushed two days ago and i still get the same code. thanks for any help
I feel your pain. I am experiencing the same issue which started about 3 weeks ago. First it happened twice that first week and we discounted it. Now that my heater has been flushed the same issue is occuring. I called Noritz 3-4 times now and they are saying that I may have high manollowifold pressure and should have that checked.
FollowUp: Plumber determined my Natural Gas inlet line was too small. He Tee'd off before my manifold to other appliances and fed with a 3/4 line. Issue resolved and it has been trouble free since. (Updated 2/2017)
Feb 12, 2011 | Noritz 6.9 Gallon Residential Tankless...
How difficult is it to convert a N-069M Noritz from natural to LP?
It is not very hard, you can contact Noritz directly or a local distibutor to get a LP gas valve and change it out with the natural gas valve. It takes about 10-20 minutes. just make sure you check for leaks before starting it back up.
Jan 11, 2011 | Noritz N-069M-DV, N-084M, and N-084M-DV...
What does a F12 error indicate on a Noritz system
F12 occurs on a multi-system or quick connect. It means one of the units on the system suffered a flame loss. More specifically, it means the flame rod stopped detecting flame on the burner. The most typical causes are as follows:
1) insufficient BTUS (low gas pressure)
2) leaking heat exchanger
3) clog in the manifold, burner, or heat exchanger
4) stuck flue damper or improperly sized venting
5) dirty flame rod
6) damaged circuit board or gas valve
Sep 28, 2010 | Noritz N-069M-DV, N-084M, and N-084M-DV...
Where can I get parts for N-069M and N-063S Heater
Parts can be ordered directly from Noritz. Simply contact them and they will guide you through the process.
Jul 01, 2010 | Noritz N-069M-DV, N-084M, and N-084M-DV...
I opend Drain Plug on my Noritz Unit N-069M and didn't find filter on it. Where I can buy that filter?
The filter is frequently stuck in the filter hole on that model. Look for a black plastic washer with a circular hole in the center; that's the bottom of the filter. You can remove it with a screw driver. Put the screw driver in the circular hole, turn it at an angle, and use it as a lever to wrench the filter out.
Jun 21, 2010 | Noritz N-069M-DV, N-084M, and N-084M-DV...
Noritz f 76 error blinking f 76 and on off light blinking at the same time. Everything works fine turned on and off hot h20 it goes to burner on 120 and then goes back to blinking f 76 after burner...
F76 is a communication error between two quick connected heaters. To clear the code, disconnect power from both heaters, wait 20 seconds, then reconnect power.
Apr 23, 2010 | Noritz 6.9 Gallon Residential Tankless...
I have a noritz n-069m-dv. it is coming up with a trouble code 66. Any ideas?
I had the same fault code. Noritz told me it was a Bypass Control valve that was blocked from shutting all the way. It is located inside the unit on the bottom right there is a small motor with two wires attached to the bottom of the valve... these wires could possibly be not contacting... I resolved the problem by tapping somewhat strong on the valve with a hammer with a type of punch... i was lucky the tapping unstuck the valve.... i would reccomend if you can't resolve tis simply get a tech who knows how to work on this... there are two gears inside that are keyed by marks on them... be sure that they go back right if you dissasembe this valve. Good Luck...
Dec 31, 2009 | Noritz N-069M-DV, N-084M, and N-084M-DV...
Noritz N-069M-DV, N-084M, and N-084M-DV Pipe Cover Logo
60 people viewed this question
Top Noritz Plumbing Experts
Kyocera HP Expert
Paul Carew
Muzammil Razzaq
Muzammil Razzaq
Are you a Noritz Plumbing Expert? Answer questions, earn points and help others
