Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Washing machine bowl seems to have dropped in 7kg fisher and paykel machine just stopped and started beeping approx 4 or 5yrs old
  • 5 more comments
  • jmfarr May 28, 2011
    maybe the bowel does drop when water is in it not sure I went in and changed setting to heavy duty and machine began agitating however it does not fill as level is at med heavy duty is high I then advanced it to spin and nothing happens just hums hope this is helpful
    I did that it seemed to work correct I then advanced it to spin but it just humed
    Never had a problem with it filling or empting before I cant hear a clicking when opening the lid however when i turned the machine off and restarted it, it go to fill but water level was already at med it is when the machine is advanced to rince or spin it just hums do you think it could be a faulty pump?
    where is the timer switch located ? and is it hard to replace ?
    Hi thanks for that is this timer switch eazy to locate and replace And where is it located ?
    sorry yes Im still here there is absolutly know clicking when i open the lid
    Just restarted the machine on normal wash med water level, it filled and agitated and stopped and just humed on rince I had to bail out the water
  • 4,323 Answers
Hi
How many times is it beeping? Are there any error codes/blinking lights as well on the control panel? What exactly do you mean by Bowl here, is it the tub or any other thing that you are referring to?
Daniel
Posted on May 28, 2011
  • Daniel Scott
    Daniel Scott May 28, 2011
    Hi
    Daniel
  • Daniel Scott
    Hi
    Daniel
  • 4,399 Answers
Thanks for choosing FixYa and welcome to the site. What do you mean by it dropping? Thanks.
  • 3 more comments
  • Richard Hale
    Richard Hale May 28, 2011
    OK. It was helpful. Try and set it to final spin and see if it works. If it spins, reset the timer to the first stage and begin the wash. If it won't, try unpugging the washer for a minute or two and plug it back up. This will reset the washer. Try to start the washer with normal wash settings and let me know what it does. Once you do this, please let me know what happened. Thanks.
  • Richard Hale
    I believe you have a bad timing switch. Have you had any problems with filling the tub up with water and draining?
  • Richard Hale
    The washer may be out of time or it may need a new timing switch. You need to make sure it is not the lid switch though. Make sure the washer begins and stops when you raise or close the lid to the washer. If so, you will hear it clicking and this means it should be working properly.
  • Richard Hale
    I don't think it is. I believe your washer is out of time. This may be caused by the timer or the timing switch. You can make sure if you want. You should hear it working. Drain the water out and restart the wash from the first setting. If it fills up, the pump is fine. A bad water level switch can cause similar issues as yours, but I believe it is out of time. It is not the motor. We determined that a little while ago, same as the lid switch. You have power to the washer. It does spin. You need to see if it will drain though. We ruled out the motor and all components. I believe the beeping is associated with the washer not in the correct setting.
  • Richard Hale
    Hey there buddy. You still here? I waited for awhile last night.
Why won't my Fisher & Paykel washing machine complete its cycle?
it appears to be a control module problem
have it checked by an authorised F&P technician
Jun 06, 2015 | Fisher and Paykel Washing Machines
Fisher and Paykel Washing Machine model mw512
this sounds like the motor controller cant start the motor. I would be looking at the motor controller itself.
when it's filling with water, does the bowl go around slowly?
Sep 11, 2013 | Fisher and Paykel Washing Machines
Fisher and Paykel GWL11 Top Load Washer starts but drum won't turn, it twitches and beeps then turns off with solid beeps
Hi ken
Can you turn the bowl & agitator by hand.
If it can't turn by hand, Your seal & bearings need replacing.
Feb 01, 2013 | Fisher and Paykel GWL11 Top Load Washer
MW512 Fisher & Paykel Washer Machine...Where is the lint filter located?
Fisher & Paykel machines don't have a lint filter.
Manual cleaning of agitator and s/steel bowl will make your washing cleaner.
Oct 12, 2012 | Fisher and Paykel Washing Machines
Fisher Paykel washing machine Smartdrive 703 Advance, Power and Start buttons are non responsive when pushed. Is there a part that can fix this. Does the control panel have to be replaced?
Fisher & Paykel Smart Drive beeps and stops during rinse cycle. If I hit pause and wait and restart it eventually continues. It seems like it has problems detecting water level.
Apr 13, 2011 | Fisher and Paykel GWL11 Top Load Washer
My Fisher & Paykel AquaSmart 7kg top loader shows Error Code 245
Error 245: SmartPump Stall
Pump Impeller is jammed cannot turn.
May 24, 2017 | Fisher Washing Machines
Fisher Paykel washing machine not working properly
It's most likely the Lid switch (reed switch). Does it come up with a fault code or beep at all? if so there are eight LEDs reply with the lights eg 00100010 1=on 0=off cheers
Mar 24, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
59 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
