Question about Summer Infant Hand Held Video Monitor
There is no signal between the base and monitor. It has slowly seemed to be cutting out throughout the night for a few days and now has no signal at all. I have tried unplugging, turning off, adjusting cords, etc. Have only had the monitor for 3 months. I have the new version of the colour video monitor with touch screen.
    President:
  • 1,961 Answers
The monitor oftenly affected by the interference from any electronic device. It is also cause by the monitor on for too long
Try unplugging your monitor and turn it off for an hours.
Then, remove the battery from your device.
Put the battery back in.
Plug the monitor back in.
See how it goes..
Posted on May 28, 2011
Why does it keep "saying" out of range?
if camera and base are within a few feet of one another does it have a problem obtaining a signal (syncing ) ?? as if it works ok then there might be a object that is getting in the way of the signal , radio waves move from its transmitter (camera) towards its receiver (monitor) in a straight line , if there is too large a mass in the way then the radio wave can't penetrate it and will be "lost" also ck both the camera's and bases battery levels (if they have one) for proper peak power level , as it takes energy to drive the radio signal towards its receiver .
Feb 09, 2016 | Summer Infant Secure Sight Handheld Color...
Why do both incoming and outgoing calls cut off after a few minutes on base hand set?
It could just be a bad battery, swap battery's and see if the trouble follows. If so it is bad. Also on these lithium battery's you build the life to them, when it is fully charged, do not just use it for a few min. and put back on the base, if you do that's all they will last is a few min. after charged. Use it and leave off base, then get in the habit of only charging it at night and leave off base during the day. The battery should last 6-8 hours or more if not in use a lot.
Jul 22, 2015 | Lands Phones
Solar cockerel light. the prolem is the light does not light up at night. I think the light sensor does not work, the light is on during daylight, the battery does not charge enough for the light to work...
Yeah, there seems to be something covering the light sensor causing the light to stay on throughout the day preventing it from having any energy to produce light for night. Good luck
Apr 19, 2011 | Garden
Hi, recently purchased new pc asrock m/b amd phenom II 555 cpu etc installed XP run ok shutdown that night switched on next day say midday and no signal on monitor, subsequently have installed XP and Win 7...
when you install windows 7 dont download the drivers from there website unless you can find the 32bit version. if not. windows 7 will find the drivers right for you that will solve the problem. i have seen this on a few asrock m/b issues with win 7
this is your solution if this doesnt work give me some more details im on all night you may contact me via aim littleiceylilb for more trouble shooting help
Mar 16, 2011 | Computers & Internet
The WPN111 RangeMax wireless UBS 2.0 adapter I bought a few days ago keeps disconnecting. At first the connection is fine throughout the day, but at night the connection fails. Internet access in the...
Do you have a good signal strength with the wireless USB adapter?
If not try moving the wireless router away from walls or metal objects and cordless phones, locate the wireless router higher.
See if there is a later driver for the wireless USB adapter, if so download and install it.
Dec 21, 2009 | NetGear WPN111 RangeMax Wireless USB 2.0...
My moniter has completely stoped working. It at first was fading out for after a few minutes. I could turn it off and back on again to make it work but now it just is black
Good day sir/maam, hi, it seems that your monitor's power supply is slowly loosing power, this may be cause by parts inside to fail slowly, this may be resistors and capacitors, or a slow blow fuse, and a faulty switching regulator IC, then stops. Servicing LCDs are quite difficult, you need to bring it to your dealer for proper advice on your LCD.
Oct 23, 2009 | ViewSonic VX2235wm LCD Monitor
I have the same problem
Remove the Ram from the slot and clean the slot , refix the Ram.
Jun 03, 2009 | Dell Dimension C521 PC Desktop
When I turn on the tv it automatically turns off itself
Back again. It appears that the key is the order in which you connect things and switch the TV on or off. It took some experimenting to get to what's reliable. I'll spare you the details and confine myself to what works.
1. Start with the monitor cable disconnected at the laptop.
2. Turn on the TV with the source set to your regular satellite (or cable) signal.
3. With the laptop on, plug the monitor cable into it.
4. Switch the source (at the TV) to receive the VGA signal (from the laptop).
Voila!
To turn off, reverse the procedure.
Mar 27, 2009 | Televison & Video
Thomson GE DECT 6.0 28213 Cordless Telephone
I finally find a way to stop this problem from occuring : never leave your phone on the charger with the battery isnt empty !
I know this sucks because what best place to put your phone at night than its base. But try it and it will work (unless your battery is already damaged). In the morning when i go to work, I charge it for 8 hours, then when I come back, I take it off the charge until next morning.
I used to put it on the charge for all night and all day until I read an interesintg post :
http://en.allexperts.com/q/Telephony-Clecs-Long-2450/Cordless-phone-interference.htm
Since I have been doing this, I didnt get any more problems with my phone.
May 28, 2008 | Thomson GE-28115FE1 Cordless Phone
Summer Infant Hand Held Video Monitor Logo
410 people viewed this question
Top Summer Infant Baby Gear Experts
Colin Stickland
Colin Stickland
Paul Bade
Falling star
Are you a Summer Infant Baby Gear Expert? Answer questions, earn points and help others
