Question about HP LaserJet M3035 MFP Printer
My ip address on my computer does not match the ip address on my hp3035 xs mpf
  • HP Master
  • 1,915 Answers
When you say does not match, how close are they? Normally in small office or home network, the address should be almost identical except for the last 3 digits. For example:
Printer 192.168.1.20
Computer 192.168.1.25
If you are connecting both units to a router then if you set both your laptop and the printer in DHCP mode you should get the correct address for both.
Posted on May 28, 2011
Connect fuji xerox printer - mac pro computer as it was
Hi Lindsay. Was the fuji xerox printer plugged into the old modem by a blue ethernet cable ?
When you changed your modem it would have had a device inside it called a dhcp server that allocated the IP addresses to your computers automatically.
Now I suspect that the new modem has a device inside it called a DHCP server that is allocating a different range of IP addresses to your computers from waht it used to be.
Here comes the technical part
On the printer menu screen there should be a network setting option . Take a note of the IP address of the printer it will be 192.168.0.x or 10.0.0.x x being the unknown number. also take a note of the subnet mask . it will most likely be 255.255.255.0
next but I have no idea how to look that up on a MAC IOS system.
you may see the ip address in the printer settings properties in the MAC
you may be able to get your ISP to remotely set up your DHCP server in your router to work in the appropriate ip range to match your printer IP address and to avoid allocating the printers ip address to your computers. Then restart the computers to get new ip addresses.
If you tell them the printers IP address and Subnet mask they should be able to alter the modem's settings DHCP settings for you.
The other option is to get the DCHP IP address range of the modem and subnet mask and change the printers IP address setting and subnet mask to match the DHCP leases range by giving it a much higher number than the computers are most likely to be running on.
so if the range was 10.0.0.1 to 10.0.0.254 with subnet mask of 255.255.255.0 then the printer would be set to 10.0.0.254 and subnet mask 255.255.255.0 The first three left numbers must match they are known as the network component of the ip address 10.0.0.0 or it may be 192.168.0.0 the zero end number is the network address so you can't allocate it to a device. 192.168.0.1 or 10.0.0.1 is usually the modem address.
ISP may be able to guide you how to change the setting on the printer .
I had a client that had a lot of trouble getting a tech to come out and set up their printer to an APPLE system. I was the final Tech that eventually came out and set up the printer .
Feb 17, 2016 | Computers & Internet
How to change your computer ip address so it matches the printer so it can print
go to printers devices ,right click on icon for 2050, click on printer properties, then click on portd , then click on configure port
enter correct ip address on bottom ip position.this should fix the problem
Dec 12, 2013 | Kyocera CS-2050 Black and White Copier
How to use ip address for printing connection
First thing, you need the driver(you can download it). Copy the ip address of your copier match with the ip address of your computer.
Jan 17, 2012 | Minolta bizhub 350 Black and White Copier
I have a IBM netvista desktop and a HP Pavillion on my home office work desk. Now I am getting a message that they are sharing the same IP address! What happen to change one of the Ip address to match the...
Do you use both computers in an existing network (same network)?
Are you using both computers in this same network sharing broadband (internet connection in the same networK?)
Mar 16, 2010 | HP Pavillion s7420n PC Desktop
I changed the IP address range of my LAN and need to assign the new range of addresses to my HP printer P2015dn
Press the Menu button on the printer to open the printer’s menu and enable the Network Card – these print servers use a static IP address therefore, configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP's are 192.168.0.xxx then set the network card to a high number say 100. (This is to prevent a conflict with the router issuing the same IP address to a computer on your network).
Then set the Subnet Mask IP address to 255.255.255.0
Jan 13, 2010 | HP LaserJet P2015dn Printer
IP address invalid
8360169.jpg music studio 12 deluxe installed correct on vista openns to studio but wont finish loading computer locks if i click on any tabs ???
Dec 18, 2009 | Computers & Internet
First of all sorry for my english i have 10 user pc and 1 server (windows 2000 sp4) and 1 modem i have static ip address in my modem and i give the local ip in my modem 192.168.0.2.......ok i give the...
Each of the eleven(!) computers needs:
1. a _unique_ IP-address
2. the IP-address of the "gateway" device
3. the "network-mask" (usually 255.255.255.0)
The IP-address for your server must *NOT* match the IP-address of any of the 10 computers.
The IP-address for your server must *NOT* match the IP-address of the "gateway" computerl.
Nov 13, 2009 | Microsoft Windows 2000 Server
Cannot connect the 2nd computer to the internet using the ethernet adapter
Most likely, your ISP only allows a single MAC address to connect to them. To make this work with multiple computers you'll need a router that can do MAC address cloning, i.e. it reads the MAC address off of the computer that works and presents this to the ISP in all cases even when the request comes from different MAC address.
The MAC address is unique and set at the factory for each ethernet card so it's not something you can or should attempt to change. If you were able to change the MAC address on the second computer to match the first you would break your network rather than fix the problem.
It is also possible that you are using fixed ip addresses and simply need to configure the NIC on the new computer. If you check the IP v4 settings for the old computer and they have an explicit address for the card then this is is the issue. If so, simply configure the new computer to match the old computer but make sure the last of the four numbers in the ip address is something between 1 and 254 that does not match the first computer or the gateway address.
Oct 04, 2009 | NetGear Powerline XE102 Ethernet Bridge...
Dell 5100cn won't recognize mpf tray
Go to the printer web page by entering the IP address of the printer in an Internet Browser.
click Printer Settings menu entry
If the Substitute Tray value is not MPF Feed, click on the Printer Settings tab
Set the Substitute Tray value to MPF Feed
Click the button Apply New Settings, it will request the admin id & password for the printer.
In trying to resolve this issue, initially I set the Tray Settings to Panel Specified from Driver Specified at the printer's panel. Since the issue was resolved with this set, I just left it that way.
Nov 01, 2008 | Dell 5100cn Laser Printer
After changing LAN IP, can not access setup page
If using DHCP, reboot your machine or release and renew the IP on the network card. If using static IP addresses, change the computer's IP address to match the new segment and remove the old default gateway and replace with the new LAN IP.
Feb 16, 2006 | Linksys WRT51AB Wireless Router
HP LaserJet M3035 MFP Printer Logo
51 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
