Question about Refrigerators
Hi there, My fisher and Paykell N249T fridge is working fine but the freezer part seems to be playing up. Icing over on the bottom and not freezing food contents in the freezer. Does this sound like a thermostat ? Do the fridge and freezer share the same thermostat and can I replace it myself as although cosmetically excellent the fridge is only worth about $150 second hand. I can buy a thermostat online for $16 Thanks a lot Jenny
    Guru:
  • 352 Answers
Hello.
It sounds like a ventilation issue. Check all the vents leading into the freezer and see if there are any fans located inside them, also make sure no food items are blocking them. Do this while holding the door switch in as some models turn these fans off when the door is open. Also make sure the door seal of the freezer is closing correctly, a small opening can affect the freezers performance. I do not believe it is a thermostat issue but if the vents are clear and the issue remains then it could be.
I hope this sheds some light on the issue. Regards GM
Posted on May 28, 2011
Fisher and Paykell E522B icing
The thermistor sets the defrost cycle. Always go with the cheapest solution first but also ohm out your heater that could be the issue also.
Apr 13, 2013 | Fisher and Paykel Active Smart E522B...
I bought a second hand F&P Fridge Mod N249T about 7 years old..and it keeps feezing all of our food!!! The teperature control shows 1-7 seven, we tried setting it to 1 which we thought would be the...
I was not able to find a manual for your model; perhaps the company has not posted going back this far. Your model seems to be available on the resale market in Australia. If your model is not from Australia, vist the following site http://www.fisherpaykel.com.au/customercare/userguide/ and in the bottom of the webpage select the country the refrigerator was purchased. verify your model number and then go to Customer Care > Find A User Guide. Use the search fields to find your User Guide; if you leave the model number blank and select rerfigertaor you wil get a selection of all the available User Guides for refrigerators.
The Fisher and Paykel site seemed to only has one User Guide for all their refrigeration model but it does not list as applicable for the N249T. See here: http://www.fisherpaykel.com//admin/pdfs//pdf_usecares/837186-Ref_Freezer-UG_NZ-AU-UK-PAC.pdf
However on page 18 it does describe the Temperature Control:
1 is for the warmest setting
7 is for the coldest setting
The Problem Solving Section on page 29 advises that when food is freezing in the refrigerator the temperature setting is not correct or food is placed directly in front of air outlets.
If the unit is not shutting off when the desired temperature is reached there may be a problem with the thermostat.
Hope this is of some assistance.
Sep 10, 2011 | Fisher and Paykel Active Smart E522B...
Fridge not cold compressor running fine sides are warm to the touch, enough ventilation bottom freezer and top fridge setting at maximum cold both freezer and fridge fan are working with an external 12V...
There are three reasons for your fridge problem. 1. Malfunction of defrosting. 2.Gas chocked.3.Thermostat setting.
1. The freezer can be set to atemperature between.
Thanks, helpful?
-14°F and 8°F.
Feb 08, 2011 | Fisher and Paykel E522BLE Bottom Freezer...
Hi There My Parents have a Fisher & Paykel (E331T) the Freezer is working fine, but the fridge where the dairy products sit don't seem to be freezing at all im not sure if there suppose to be a fan...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 11, 2010 | Fisher and Paykel Active Smart® E522BR...
Freezer icing up.......fridge doesn't work.
I have the same problem with this stupid samsung RS 2630. Check the defrost sensor that is behind the ice maker box and seems most likely the cause. If this is the fridge and model number, what you need is part No. DA3200006Q. This link from UK will also help you in many ways.
http://www.ukwhitegoods.co.uk/modules.php?name=Content&pa=showpage&pid=209
Nov 03, 2009 | Fisher Refrigerators
Bottom of fridge section freezing, rest fine.
maybe fridge fan not working when door is closed could also be iced up air ducts between fridge and freezer
Oct 09, 2009 | Fisher Refrigerators
Refrigerators Logo
49 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
