I have a 32 inch audiovox lcd tv that will not turn on. The power light blinks blue then back to solid red.
  • 2,275 Answers
You LCD might have a defective power supply. If the LCD fails to power up, it means that the 5VDC are low due to defective capacitors or other components associated to the 5VDC standby voltages.
Posted on Aug 16, 2008
    Guru:
  • 1,894 Answers
Do you have the sound?
please try a hard reset. by leaving the unit plugged off from wall power for one night. this may fix the problem some times
thank you
  • dewan nafees ahmed Aug 16, 2008
    and how many times this red lights blink?
    do they follow any blink pattern?
I have a 42 inch philips lcd tv and it will not turn on. Tried unplugging it for 60 seconds and only the light will blink red sometimes and then blue sometimes. Do I change out the power source
Number of TV have a bad batch of capacitors on the power board. If you look like split mushrooms that is a bad sign. But there are kits if you know how to solder.
Oct 25, 2015 | Philips 42PFL7403D/F7 42-Inch 1920 x 1080p...
My Samsung LED has a flashing blinking light on the front. When I power on, it does not go into standby mode. It just turns solid red for a few seconds and then starts blinking. No image on screen. Is it...
I'm guessing you meant to say 'power off''. Otherwise it sounds like you have reasonably guessed there may be an electronic malfunction -- but with this, as with any device with a 'chip', I'd suggest first literally 'pulling the plug,' or if it's surge protected powering that down. Give it 30 seconds or so, then power back up. Best of luck!
Feb 25, 2015 | Samsung UN32D4000 UN32D4000NDXZA 32 inches...
Has verticle lines and turns off.
SONY LCD TV 32 inch, Display problems. Display half white colour.
Jan 20, 2012 | Sony KDL-32M3000 32 in. LCD Television
My 32inch audiovox flatscrren will not come on but
Now in the front of the tv panel power blue light on and it solid green?Take ur tv aparts.The T-con board, this board sit in the botom in the middle of the LCD screen.This board is defective replaced it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-con board for the replacement.
May 11, 2010 | Audiovox FPE3205 32 in. HD-Ready LCD...
Emerson LC320EM82 S red light will come on and when you go to power the tv on it blinks green and never turns on
Power supply board is dead,if green light on keep blinkings,notthing come on.Power green light is solid,nothing come on.Than ur Tuner signal board is dead.
Feb 09, 2010 | Emerson LC320EM8 32 in. LCD TV
I have a Polaroid flat screen TV 32 inch lcd W Red Light Plz HELP
blown cap in the power supply it will be domed on the top where it vented
Sep 16, 2009 | Televison & Video
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Will not turn on, red light as off, when I push power the red light goes off but
Look for 2 pico fuses in the secondary section of the power supply. I'm sure one of them is blown, that is why the 24 volts are missing.
I will let you know the locations later when I get home.
Good Luck.
Jan 10, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
Flat panel tv
I had a similar problem, except I had sound and with a flashlight I could see audiovox when i turned it on and I could see the video when I put a DVD in. It is hard to see even with a flashlight so you have to look closely. Well, I researched and investigated what might be the problem because I was upset that I had the TV for less than two years. Everyone was saying the inverter was defective. Apparently the inverter is what gives the LCD screen the back light to see the video. So I called audiovox and found that thier part's selection was only a power board and a remote control for this TV. I asked them if they could get me an inverter and they did. With shipping cost it was approximately $150.00. They ensured that I know that there is no refund on this part (which is common for electical parts). So I took a chance on it not being the right part for the problem. I replaced the defective inverter myself and it worked. It solved my problem. The inverter is a circuit board that plugs in and has a few screws to hold it in place. I had to remove the back cover first and a couple of brackets inside the tv to get to the inverter and replace it. There is a quite a few screws so I recommend writing down where each came from for easier reassembly. I hope this helps!
Aug 16, 2008 | Audiovox FPE3206 32 in. LCD Television
Lcd not turning on
May i know is it the power led light blinking or just steady?
Jul 20, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
Electro Med Services...
