1) How do I know which refrigerant to use 2) How can I tell if the AC has the right amount of refrigerant
ALL A/C units & you gave us nothing at all,
have the type of refrigerant on a label somewhere
You can only tell how much is in there by using
the proper manifold gauge set & using a temperture
& pressure chart, for each refrigerent type
I was sent to the a university for 3 weeks to learn
alternating current, such as you have coming to
your home or business,before I was allowed to
go to a refrigerent class that was a week or two
Still want to work on it?
Really fun stuff, but your not licenced, so you
can not buy ozone polluting freon
Posted on May 28, 2011
Changing the ac compressor in my 2007 Saturn Relay, how do I do it?
Evacuate and recycle the old refrigerant. Disconnect the belt and hoses. remove the old compressor. Use an AC flushing kit to flush out the system. Install the correct oil in the new compressor. Use a vacuum pump to pull a vacuum on the entire system. Use a manifold gauge and refrigerant scale to add exactly the right amount of new refrigerant. Without those special tools, keep your mitts off!
Oct 15, 2017 | Saturn Cars & Trucks
Charging amount on frige model no ksu405226x
Get that info from the manufacturer. On a refrigerator, unlike AC units, the correct charge amount is very critical to its operation. U have to be right on and there is very little tolerance for error.
Aug 19, 2015 | Refrigerators
My Goodman condenser which was recently replaced is making a severe swashing noise when it stops. Like a back flush or something. Need to know if this standard.
Normally if it does not sound right, it is not right. By your discription it sounds like your compressor is having a problem with flood back caused by a txv not metering properly, or an overcharged system. You will need a tech who can determine superheat and subcool for your refrigerant system. Find a tech who can determine these values. Superheat and subcool is normally around 8 -12 degrees. Superheat is the amount of additional heat the refrigerant picks up in the evaporator once it is turned to gas and is needed to keep liquid refrigerant from flooding back to the compressor. Compressor are designed to compress gas not liquid. Subcool is the additional cooling refrigerant undergoes once the refrigerant turns back into into liquid in the conderser. Subcool ensures the refrigerant remains in liquid form until it reaches the metering device. Only liquid suppied metering devices will pass the required amount of refrigerant to achieve the rated cooing or heating rates. If it is liquid flood back, your compressor will be damaged and will need to be replaced. Hope this helps
Oct 07, 2014 | Goodman Manufacturing Goodman R410A 13...
Ho many pounds of LOW pressure refrigerant does the 2000 toyota sienna take.
If you are talking about the pounds PRESSURE (PSI), it depends on the ambient temperature. That information is what is on the dual set of gages that you see refrigeration techs using. If you are talking about the weight of the refrigerant to fully charge an empty system, there should be a sticker under the hood, near the AC system that tell you the type and how much to charge the system, it will also tell you how much and type oil to add. That all pertains to a completely empty system. The amounts specified by the Toyota are very important.
Also, you know that an empty system has to have the system purged of air and moisture, That has to be done by pumping a vacuum on the system for about an hour. That usually provides a vacuum of about 22"hg. If you have replaced a major component or have disconnected any connections you will have to do that. Knowing exactly how much oil to put into the system is a challenge unless you know that there is no oil in there now. So it take some expertise and equipment to charge a system correctly.
ALSO, IT IS IMPORTANT THAT I TELL YOU AND THAT YOU KNOW THAT IT IS AGAINST THE LAW TO CONTINUAL RECHARGE AN AC SYSTEM THAT HAS A LEAK OF REFRIGERANT. THE LAW SAYS YOU HAVE TO CORRECT THE LEAK BEFORE YOU CHARGE THE SYSTEM.
Thanks for using FixYa.
Gaker
Jul 12, 2011 | 2000 Toyota Sienna
2000 Chevy Malibu...Working on my AC replacing the compressor...What is the fluid capacity of the compressor/AC system on this vehicle...If I've added more than enough, how do I drain excess fluid to...
NEW AC COMPRESSOR POUR OUT SHIPPING OIL COME WITH IT ADD THEM SAME AMOUNT.IF YOU NOT SURE AND OIL BEEN POURED OUT.ADD 2 OUNCE R 134A REFRIGERANT OIL TO NEW COMPRESSOR. YOUR AC SYSTEM HOLD 1.75 LBS R 134A REFRIGERANT.
Jun 22, 2011 | 2000 Chevrolet Malibu
How much r22 charg in 1 ton split ac unit
What your asking is impossible to answer. True the charge goes up with the btu size but there is no set amount. To figure this out you need a couple of things.
1. On the condensor (outside unit) has a lable that will tell you how much R-22 the condensor will hold.
2. On the evaporator (inside) should also be a tag that will tell you how much the evaporator will hold.
3.Then you have to know the line sizes and also length to tell you how much refrigerant the line set will hold.
You add all these up and you will have the correct amount.
Hope that this helps.
May 21, 2011 | Heating & Cooling
My ac needs refrigerant
Different model and make of AC use different refrigerant so call an AC repair guy and he will be able to fill it with the correct number and amount of refrigerant your AC needs. Also get the AC checked for any leaks before filling.
May 09, 2011 | Heating & Cooling
A/C NOT BLOWING COLD
sounds like your refrigerant is low. to check this there is a cap on one of the ac lines take off the cap and put a gauge on it and that will tell you if it is low or not the gauge you can usually get with the refrigerant. if it has the right amount in it than the problem is with your compressor.
Apr 28, 2011 | 2001 Chevrolet Impala
Hi..i had to change a/c condencer, and the a/c compresser, both at the same time.how will i go about charging the system? do i need to add coolent too both ports? or just the low side.?
YOU TAKE TO A GARAGE LET THEM PUMP IT DOWN FIRST MAKE SURE YOU PUT THE RIGHT AMOUNT REFRIGERANT OIL IN COMPRESSOR.IT COME WITH SHIPPING OIL IN IT BUT YOU HAVE TO POUR IT OUT.PUT IN THE RIGHT AMOUNT OF REFRIGERANT OIL IN COMPRESSOR LOOK IN OWNERS MANUAL TO PUT IN THE RIGHT AMOUNT.NOW IF YOUR OLD COMPRESSOR SEIZED OR LOCKED UP THEN LET GARAGE FLUSH OUT METAL SHAVINGS OUT .IF YOU DONT FLUSH OUT SHAVINGS THE NEW COMPRESSOR WILL BE DESTROYED.ALSO YOU HAVE TO REPLACED THE ACCUMULATOR OR ORIFICE TUBE IF EQUIPPED.IF OLD COMPRESSOR DIDNT LOCK UP.PUT NEW REFRIGERANT OIL IN COMPRESSOR IT TAKE AT LEAST 1 OUNCE OF OIL BUT CHECK OWNERS MANUAL ALL VECHICLE HAS DIFFERENT SPECS.AFTER COMPRESSOR OIL BEEN PUT IN EVERYTHING ALL REFRIGERANT LINES TIGHT.TAKE VECHICLE TO A GARAGE THAT DO AIR CONDITIONER WORK.THEY HAVE TO USE A VACUUM PUMP TO PUMP DOWN THE AC SYSTEM TO REMOVE MOISTURE AND LEAK TEST THE SYSTEM WHILE IT PUMP DOWN.IF YOU DONT LET THE GARAGE PUMP DOWN SYSTEM. THE MOISTURE WILL FREEZE UP IN AC SYSTEM CAUSING POOR OR NO COOLING.THE GARAGE GOING TO CHARGE YOU TO PUMP DOWN AND CHARGE UP SYSTEM.IT WOULD BE CHEAPER TO DO THIS THAN TO BUY A VACUUM PUMP AND MANIFOLD GAUGE SET.WHEN DOING AC WORK YOU NEED SPECIAL EQUIPMENT AND TOOLS TO DO THE JOB OR THE AC SYSTEM WILL NOT WORK RIGHT.
Jun 12, 2010 | 2004 Nissan XTerra
Need to know how much refrigerants needs to go into it
unless you have the expertise; the tools: i.e. a vacuum pump; gauge set and, recovery equipment; you should not attempt an AC recharge
of the system: there is no way to properly charge a system based on amount of refrigerant gas; we do it based on temperature/pressure
refrigerant is dangerous,please take your car to an AC professional
Sep 10, 2009 | 1986 Jaguar XJ6
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
