Question about GE Profile JB988 Electric Kitchen Range
JB988SOH3SS left touch controls for left surface top elements are not working. Unable to turn on left side elements. Oven controls and right side smooth top elements are operational. What is the problem?
  • 26 Answers
SOURCE: Electric Oven not getting hot enough
Sir, I think the top oelement is for broiling ONLY. It should not turn on when baking. The clicking may be the oven heating up.
How far apart were the oven temp instrument and the digital?
Don't expect them to match...they are inaccurate.
1. Heat water until it boils. Place digital therm in boiling water until it comes up to 212deg. If it is not at 212 in boiling water, record the error.(this gives a rough calibration to the digital)
2 Turn on oven, set to 350 deg, place digital therm on rack. Wait until oven reaches 350 (on stove) and read the digital. Note the difference between the two
Posted on Mar 30, 2008
BNewberry
  • 93 Answers
SOURCE: Frigidaire Smooth Top Range/Oven stopped working
Computer is cooked. Sorry to tell you.
I am a factory servicer for Electrolux / Frigidaire
I replace tons of those clock controls. They shouldn't be $160 though
Any questions about these stoves send me and email.
I will be glad to help you out.
Thanks
Posted on May 23, 2008
SOURCE: Top oven will not heat up
JKP55 The top oven would not heat. Got it fixed for $261.00 with tax. The bake element in the upper oven was bad. My oven unit is 14 years old.
Posted on Feb 07, 2009
SOURCE: GE JBP30 oven bottom element not working after being replaced
I would be looking at the bake relay on teh coven control board. Using a voltage meter test the output voltage when energizing the bake feature. Be sure to remove the bake element wire coming from the bake element to the control. Test this terminal without the bake element wire attached. From the terminal with one meter probe to the neutral on the terminal block (where your cord attaches to), you should read 110 volts when energized and 0 voltge when shut off. What are you reading? If I can help further, I am here.....
Waiting to hear from you,
Eric Campion
Posted on Feb 15, 2009
scottowa
  • 87 Answers
SOURCE: The surface unit light will not turn off but the
Is this when the oven and stove have been off and all cooled down?
Posted on Jun 06, 2009
No heat
The home's circuit breaker is not the problem if part of the stove / oven works. What is more likely to be the cause is a problem such as an "open" or "burned out" heating element or socket.
The control is "on" and sending power to the element. The control reports "Preheating" but since the heating element itself is no longer a complete circuit - it fails to heat. As mentioned above, it may be a problem with the socket that the heating element plugs into - but could be a problem with any wire between the control and the heating element.
I would suggest shuting off the circuit breaker for the stove / oven. Check to be sure it is off by turning on a heater that worked previously. If it stays off, you're ready to continue. Carefully inspect the heating element itself for damage. The surface of the heater should be uniform - smooth over the entire length. You may not be able yo view the back side of the heater - but you may be able to run your fingers gently over the surface to feel for damage. If damage is found on the surface, this would indicate that a new element is required. Once replaced, you should expect it to work again as new. If unable find damage, removal and inspection of both the oven's socket and heating element contact blades should be done. If found to be burned or damaged, replacement of the socket, heater or both may be needed.
Obtain replacement parts designed for you make and model stove / range. Contact an appliance repair service if unsure how to check / make these repairs.
I hope this helps & good luck!
Apr 27, 2013 | Bosch Kitchen Ranges
Could this be a User Interface,Board 316239500 part problem? or a Electronic Control Board part problem?
Normally, the E.O.C. (electronic oven control) only controls power the ehe bake/broil side for the oven. Doesn't control power to the element. If you have already replaced the infinite switch to that eye, the element itself could be faulty. There is a sensor inside the element that is supposed to communicate with the infinite switch to determine the proper cycling temp for what you selected.
Jan 31, 2013 | Frigidaire GLEF396 Electric Kitchen Range
Stoves 720 EF Electric Double Oven Model No 059040415 -when you turn the grill knob there is no light and it doesn't do anything at all - the grill is not working. However, the element must be working as...
First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set.
The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control).
To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
So if you have done all that and it still doesn't work, then the micro-switch could be faulty.
Best of luck
Nov 23, 2010 | Stoves 720EF Electric Double Oven
How do i work the grill?
Nov 21, 2010 | Stoves 720EF Electric Double Oven
Bottom element doesnt work in oven, but top does.
NOPE!
  1. Broil element does not have welded-on legs and will touch the bottom of oven, overheating itself and will end up the same way your bake element did; besides, the bottom of the oven will corrode pretty quick
  2. Many ovens use both elements during bake cycle
  3. self clean cycle uses broil element
  4. The bake and broil elements typically have different mounting brackets and screw holes ate in different places
  5. you'd have to cover the hole, left after removing the broil element, and insulate the wires, which went to broil element
  6. the ends, protruding behind the mounting bracket may have different length and different connectors. you may end up shorting the wiring to the casing, which may in turn destroy the control board if there is one
  7. Bake elements usually cost only $40-$60. No jury rigging required.
Hope this helps ;)
Mar 29, 2010 | Ovens
Stove top works, broil works, clean works. I can't get the oven to heat up past 220 degrees. Is there a fuse in this model? Any idea what the problem could be? Thanks!
At the back of the oven where the sides meet the top you will see a thermastat it looks like a small knitting needle with a copper wire disapering into the back of the oven, ensure that it is not touching the oven roof or side, it should be about 1/4 "from any metal surface.
This tells your oven when to switch the heating element on and off, the copper wire goes all the way to the dial on the front of your oven.
The element is working so the problem is either the temperature dial or the thermostat.
Nov 05, 2009 | Ovens
Oven is not heating properly
Could you find the completer mode number because the number listed above your post is for a gas oven.
Look at following areas for the model number
  • Under Right Front Burner
  • Under Left Top Burner Front Or Rear
  • Under Main Top Left, Rear Or Center Front
  • Under Left Rear Or Right Front Element
  • On Nameplate Inside Burner Box
  • On Front On Burner Box Bottom
  • On Nameplate On Oven Door Liner
  • On Main Front Behind Oven Or Compartment Door
  • On Front, Center Bottom Of Burner Box
  • On Thermostat Cover Under Main Top
  • Thank You, Sea Breeze
Mar 25, 2009 | DCS RGS-484GG Gas Kitchen Range
Kitchen Aid KESC 307 hbs4 electric range control
CESAR, THE OVEN CONTROL IS THE CLOCK,HOWEVER, ON MANY KITCHEN AID RANGES, THERE IS AN INLINE FUSE 15AMP, THAT IS IN THE OVEN CIRCUIT. I WOULD SUGGEST THAT THE INLINE FUSE BE CHECKED FIRST BEFORE CONDEMNING THE CONTROL.
DAVID, THE GLASS TOP ELEMENTS ARE CONTROLLED BY THE SURFACE SWITCH FOR REGULATING TEMPS. THE SWITCH WILL TURN THE ELEMENT ON AND OFF TO REGULATE TEMP. I WOULD SUSPECT THE SURFACE SWITCH(WHAT THE KNOB IS ATTACHED TO) AS THE DEFECTIVE COMPONENT. THERE IS A HIGH LIMIT SWITCH THAT IS PART OF THE ELEMENT. IF IT WAS BAD, THE HOT SURFACE INDICATOR LAMP WOULD BE LIT ALL THE TIME.
THE ELEMENT IS NOTHING MORE THAN A COIL OF WIRE THAT HEATS WHEN CURRENT IS PASSED THROUGH IT.
IF IT WAS BAD, IT WOULDN'T DO ANYTHING AT ALL.
Mar 28, 2008 | KitchenAid KERC607 Electric Kitchen Range
Kenmore oven
Is this an electronic control oven...touch pads to set temp? May have a bad ERC. Electronic Range Control. Also check oven sensor. This is steel rod in oven in back wall near top on left or right. Check ohms from the rear where it connects to harness. Disconnect at harness and measure resistance of sensor. Most are around 1.1k.
Oct 07, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
All Surface elements are dead
Sounds like you might have a bad oven surface control board also called power board. The part # is 316239400. It is located on the left hand side about mid way down on the back of the oven. First, disconnect power and make sure all connections on board are tight. Plug back in and make sure you have power to that board if possible with a meter. If all check ok then the board is bad.
Oct 05, 2007 | KitchenAid KESC307 Electric Kitchen Range
GE Profile JB988 Electric Kitchen Range Logo
74 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
