Question about Whirlpool Estate TAWS750PQ 27-Inch Washer
Washer fills and then stops. No agitation and the motor is making a humming noise.
  • Billy Haynes May 28, 2011
    I took the pump and motor off down to the coupling and found it wasn't broken. The model I have is etw4400wq. I also put it on spin and it didn't drain.
  • Whirlpool Master
  • 2,605 Answers
Hello, welcome to FixYa.
Based on the info you provided in your post, it quite likely is the drive coupling that has broken...it is very common, that would indeed explain the noise appearing to be from the motor. (possibly a jammed pump too, but you'd know if it drains or not by advancing the timer)
**Unplug the washer from it's source/the wall before performing any service to the unit...safety first**
To inspect the drive coupling to confirm it is broken or not, you can lean the washer back (careful of the hoses) to allow you to visually inspect it or remove the cabinet completely...it is fairly straight forward and can be done even by a novice "handyman/person"
Part number is 285753A and will look like this image....
I've attached a link here that will provide the part availability and clear instructions to replace the coupling but also help describe the removal of the cabinet or to just inspect everything thoroughly. Once there scroll to the bottom of the page.
http://www.repairclinic.com/PartDetail/Motor-Coupling/1195967
Let me know how you make out or if you require further assistance and I'll be glad to help in any manner I can. Good luck.
Regards,
Macmarkus :)
Posted on May 28, 2011
  • Mark MacDonald
    Mark MacDonald May 28, 2011
    Hello again,
    Thanks for replying. Knowing the coupler is good, I'd like to know if the unit makes a "hum" when placed in drain or spin ?
    If so remove the pump (leave hoses on) and see if the pump can spin freely by hand...you'll need a screw-driver or something to spin it. It is possible something got into the pump, such as a sock, undergarment etc.
    Let me know what you find and we'll go from there.
    Regards,
    Macmarkus :)
Washer wont spin or drain
Yes, you can check the LID switch as it needs to activate the program to move forward. If the water fills up and there is no wash cycle, check if the motor hums, if so check the capacitor, check the friction on the spindle/drum. If the spindle does not agitate with movement the assembly must be reset.
Jan 23, 2013 | Washing Machines
The washer will fill up with water but it wont start washing or drain or spin you hear a humming noise then everything stops. Then in about 5 mins it will hum again then stop again
If the washer will not agitate, spin or drain it's a motor problem, capacitor or a broken motor coupler. It's either a loose wire connection on the start circuit or failed contact in the timer. When you say that the motor hums during spin, that would indicate that the motor has run voltage, but it has no start voltage. It needs both start and run voltage in order to get the motor started and running. The start voltage gets the motor started, and once started all it needs is run voltage to keep it running. The only difference between agitate and spin is that the polarity is reversed in order to start the motor in the opposite direction. The reversal of the polarity is controlled by timer contacts 7 and 14.
Most likely it's a timer or loose wire connection.
Jan 22, 2011 | Estate ETW4400VQ Top Load Washer
No agitation. Humming noise
Check if the belt is fitted correctly and not broken.
Nov 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washer fills with water does not wash or spin.
does it hum when it's supposed to be agitating or spinning? if so, the motor coupler is probably broken or stripped. if it fills and just stops, no noise at all, then most likely the lid switch is broken or loose
Aug 17, 2009 | Whirlpool Washing Machines
Washer won't spin or agitate
bad lid switch or bad motor coupler or both-mike
Jun 02, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
Kitchenaid Washer Model #KAWS700JQ4
Washer has a motor coupler linking motor to transmission. If this motor coupler is broken or has rounded out where it engages the motor and/or transmission gear it will only fill and drain. You can view this coupler by leaning washer back against the wall & looking underneath with a flashlight. There may be a sound dampener panel on the bottom that you have to remove to see it. It is two pieces of white plastic with a rubber grommet in the middle.
Dec 15, 2008 | KitchenAid KAWS700L Top Load Washer
Loud grinding motor protesting humming w/no spinning or agitating
The drum/agitator bearings are bad I believe, or the gearbox has been damaged. This is an expensive repair. I would strongly consider buying a new washer. This is a great time to buy appliances since the stores are really competing, and the prices are at their lowest.
Ray
Dec 14, 2008 | Kenmore 22422 Top Load Washer
Model numer RAS6233RQ0...only get humming sound, and nothing else
yes i have a roper ras6233kg top load washer. I have not had any problem with it until about Two weeks ago, it over filled and it would only make a hummuing sound. Now it has dried out and have been working beautifully. Then Three days ago it stopped agitating,will not spin only making a loud humming noise. I guess its time to get another one.
Jul 24, 2008 | Roper RAS6233KQ Top Load Washer
Washing Machines Logo
Sal De
Gerry Harvey
Gerry Harvey
