Question about Kitchen Ranges
The NW-60R6 Hitachi Neuro and Fuzzy Control is a 110v that was plugged to 220 volt..Its fuse broke and The controls are in japanese characters.. Do you have a translation for the controls?
reddevil6
  • 1673 Answers
SOURCE: Accidentally plugged into 220 volt outlet
The wiring diagram isn't showing a fuse, but there could be one on one of the circuit boards. Maybe the converter is bad. You will just have to take it apart and look it over. Maybe this pic. will help:
Posted on Feb 16, 2008
  • 111 Answers
SOURCE: What will happen if it is plugged into a 220 volt AC
Hi there, it depends where you got your Wii from.
if your Wii was from japan or another country which uses only a 110v AC power supply then you could have either blown some fuses inside the wii or at worse you could have fried some of the internals.
First of all find out which adapter you where supplied with, check the voltage rating on the adaptor. if it is a 110v adaptor then you may need to have your Wii replaced.
Hope this helps
Posted on Oct 28, 2008
SOURCE: Problem with Hitachi 1TB external hard drive
Most likely you just burnt up the adaptor. You can order another one from Hitachi.
The data is probably still intact on the drive itself.
You can connect it to your computer with an adapter that plugs into the drive itself and the usb port on your computer. It then shows up as a drive letter as normal.
You can buy these sata to usb adapters at most computer stores for around $25. Tiger has a nice selection:
http://www.tigerdirect.com/applications/SearchTools/search.asp?keywords=sata%20to%20usb%20adapter
I would pick one with an external power supply. It also connects to your hd. The ends are keyed so you can't miss-plug them.
Or find a local computer tech (most have this cable in our toolkit) and he probably will copy your data in a few minutes for you.
Posted on Mar 05, 2009
  • 6 Answers
SOURCE: plugged 4w 120v trimmer into 220v outlet with a 50-2000w 220-110v coverter - it blew fuse and doesn't work. soldering melted off wire inside
scrap the trimmer...
probablly damaged beyond cost of new one
a step down transformer would have been a better choice than a voltage converter ( not trying to be a wise guy here)..
Posted on Mar 09, 2009
noranda21
  • 1547 Answers
SOURCE: translating japanese to english on fuse box
is located under the dashboard on the driver's side. The fuse label is attached under the steering column. If something electrical in your vehicle stops working, check for a blown fuse first. Below table outlines detail fuse number, its ampere and circuits protected. honda-crv-interior-fuse-diagram-thumb.png
No.
Amps
Circuits Protected
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
7.5 15 10 7.5 (15) (20) _ 10 7.5 7.5 10 10 10 7.5 7.5 10 10 20 15 7.5 20 _ _ (20) 20 20 (20) 15 15 20 (15) 20 20 7.5 7.5 10 7.5 30
Power Window Relay Fuel Pump ACG ABS/VSA Heated Seats* Front Fog Lights* Not used Rear Wiper ODS (Occupant Detection System) Meter SRS Right Headlight High Beam Left Headlight High Beam Small Light (Interior) Small Light (Exterior) Right Headlight Low Beam Left Headlight Low Beam Main Headlight High Beam Small Lights MAIN TPMS Headlight Low Beam Not used Not used Moonroof* Door Lock Front Left Power Window HAC Option Rear Accessory Socket Accessory Front Right Power Window Accessory Power Socket on the Center Table* Rear Right Power Window Rear Left power window ACC Radio ACC Key lock HAC Daytime Running Lights Front Wiper
Posted on Dec 13, 2010
Can harmony touch work in country with 220 volt. Does it control the home theatre lights also
Your Logitech remote should be able to work on a 220 volt system so ling as the AC adaptor that plugs between the wall and the charger is rated 110-220v. Unplug it from the wall an read what it says on the outside. In should say "Input 110-220v" to be safe to put on a 220 system. If it is only rated 110v input power, you may need to purchase a universal power adaptor in order to provide power to the charging cradle. Another solution is to buy a "power transformer" which is a box that plugs into the wall and steps down the voltage and provides an outlet that can be used to power multiple 110 devices. What ever you do, do not plug in a 110v only device into a 220v circuit. If you do, it will "fry" the electronics rendering them useless, but it could potentially even start a fire.
With regard to your lighting system, the Harmony will emulate just about any remote controlled system that uses an IR signal. You may just need to program that device into your remote. Since you will not always want lights on or off during a movie, I would teach the remote the the audio systems * key is the same IR command as your lighting system. That way you can control the lights at the push of a button, independent of that activity.
Feb 02, 2014 | Logitech Harmony One Advanced Universal...
I plugged my 110v KG25H3XWH mixer into a 220v outlet via a voltage transformer and turned it on. It immediately sparked, popped, emitting a burnt smell and tripped the circuit breaker. Is it possible for...
First here is the link to a good suuplier with OEM parts for 110 and 220 volt http://www.appliancezone.com/SearchProducts.aspx?ID=9707627&x=12&y=7
you can change any KA mixer from 110 to 220 and 220 to 110, you need the armature stato phase control board and speed swith for eith conversion, the 220 madel number or 220 model has a letter in front of the ka which is the indicator for 220 volt go to http://www.kitchenaid.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchResultView?catalogId=10552&langId=-1&storeId=10202 for a exploded parts list and part numbers look any where for a KA 220 volt model and you can find the same thing
Oct 04, 2013 | KitchenAid Food Mixers
110v plugged into 220&worked. then blew when switched back to 110
The moment you plugged it in and tripped the fuse bad things happend, so most likely it won't hurt it anymore to plug it back into 220, although it could over volt and catch on fire. I would check the back of the screen to find out what it's operating range is. Many electronics are designed for a range of voltages to deal with other countries and power sources. I would guess something failed inside the system, most likely the Power Control Board (PCB) Why it held up for the night I have no idea.
May 25, 2010 | Televison & Video
Is kenmore 98702 220?? or 110???
if it has a small 3 prong plug then it's 110v for the washer but the dryer should be factory 220 volt however many were sold wired too! 110 volt! just look at the plug small plug 110v large 3 prong! 220v
Jan 22, 2010 | Kenmore 98702 Stacked Washer/Dryer
GEW9250 CAN I PLUG IT ON A 110V?
NO. The dryer needs 220 volts. Never cut the plug off your dryer. It will not dry cloths using 110 volts.
Dec 28, 2009 | Whirlpool GEW9250 Electric Dryer
I plugged power supply into 220 volt. do you
check out for the main fuse in system, and if you have 110v, rating..then the transfomer for the device is damaged, just replace the transfomer and on the system again..the whole system is not damaged, could be the transfomer, and the fuse.
Oct 25, 2009 | Boston Acoustics MicroMedia Computer...
Hope this helps
Oct 28, 2008 | Nintendo Wii Console
Does the Maytag LSE7806ACE require a 220 plug?
If you hook it up to 120 volts (by connecting L2[red] to common [white] the dryer will operate, but your heating element will only produce 25% of the heat it would on a 220v circuit. The drying time would be about 3 hours, and the auto dry setting may not work. Heat difference is about 5000 watts of heat on 220v, vs 1250 watts on 120v circuit.
Dec 19, 2007 | Maytag LSE7806A Top Load Stacked...
Fuse
You can't plug electrical items which are 110v into 220v sockets...you need a bulky and expensive transformer to convert the electrcity to the correct voltage. It is the only way to 'step up' the voltage
It sounds like you have might have damaged the cookers beyond repair!
Aug 19, 2007 | Zojirushi NS-ZAC18 Neuro Fuzzy 10-Cup Rice...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
