Question about Mitsubishi WD-65733 65" HDTV
My tv color is very dim and the green light is blinking continuously
  • 345 Answers
Hi! Your lamp is nearing the end of its life and needs to be replaced. You can do this very easily yourself and your manual explains how to do it. It's two screws. Order it directly from Mitsubishi. The OEM lamp costs $249. Do not buy an aftermarket lamp from an online retailer. They are of inferior quality, normally do not come with the cartridge can damage your set and they usually cost as much after you add the cartridge.
Here's the link for Mitsubishi.
WD-65733 Manual.
Posted on May 28, 2011
My T.V. will not come on.... Green light blinks for about a minute, then red lamp light begins to blink and continues... never stopping. The fan runs while the green light is blinking but stops when the...
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
Apr 09, 2011 | Sony KDF-E50A10 50 in. LCD HDTV
Tip
The green light is blinking constantly and the printer won't print
When the green lamp constantly blinking this mean one or both print head are defective.Here we can find which cartridge is defective.Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
This printer can work with only one cartridge.If you don't use color printing just remove the color cartridge.
on Oct 26, 2009 | HP Deskjet 3845 InkJet Printer
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
I own a Samsung HL-R5067W 50'' DLP. Set is about 3 years old. Recently I heard a loud pop while viewing, picture distorted, but never went blank. I turned set off. When turned on again a loud whining noise...
Check your color wheel. There is a DIY guide for replacing the color wheel. Mine did the same thing yours is and my color wheel was all busted up. Unfortunately after replacing the color wheel my set continues to do the same thing, but this could mean I need to replace the ballast as well.
Sep 20, 2009 | Samsung DLP HL-P5663W 56" TV
TV gets vertical colored lines, then shut off, green blinks conti
Bad Capacitors in the Power Supply could cause this. This Chassis has be famous for bad capacitors through out many boards. If you are not comfortable with working on the unit, and most are not, I would call a professional. The Chassis may need to be sent to Mitsubishi to be refurbished. This is a expensive repair and it would be advisable to call a Mitsubishi Professional to confirm diagnoses. Mitsubishi's Customer Service Number is 1800-332-2119. They also may be willing to help with the cost of repairs.
I hope this helps,
Skyassoc
Jul 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Lost green color, lights blinks
Ur high voltage is dead,FBT,flyback transformer is dead,the big black block of plastice with a red wire with a cap hook to a CRT(tv tube).Resoder for lost green color,by the crt yoke RED GREEN YELLOW connection to the main PCB board.Might also have to resolder crt board connection pins socket.
Mar 29, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
TV makes humming noise, lamp light is blinking, does not turn on
Your color wheel needs to be changed. Mine just did the same thing. I changed mine, and the buzzing sound went away, however now my picture washes out with light or yellow colors. The darks look green and purple also.
Mar 28, 2009 | Samsung HL-R6167W 61" HDTV
Mitsubishi WD-65733 65" HDTV Logo
118 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
