Question about Mackie ProFX12 Professional Compact Mixer
I. Have a profx12. I am running just into laptop.i want to use my jvc receiver to playback recording instead of listening through headphones. Is this possible.
  • 670 Answers
It should be if you hook something up to an input channel like w the band i was in i had to hook my turntables up to a microphone jack on an open channel . so yeah if u plug lets say a cd player plug the output of that into the input of the mackie and make sure you have your speakers in the output of mackie all set up and it should work no problem. We have the same mackie
Posted on May 28, 2011
Can't hear playback through Headphone socket, only through speaker monitors!
i suggest you contact Behringer Customer Service for advixce. Without the setup in front of me, it's hard to figure out the wire routeing, switch positions, ect. that may be leading to this problem. As they would be the people most familiar with the gear, they'sd be the people to ask. http://www.music-group.com/support/behringer/askquestion
Oct 28, 2016 | Behringer Music
Mackie profx12 fuse keep blow
Be sure the capacitor was replaced with the correct polarity?
in the beginning of my tech career I have replaced caps back words on accident. ..
Mar 06, 2015 | Mackie ProFX12 Professional Compact Mixer
I can't hear the sound from my PC when I'm using the mixer. Its hooked up to both the computer and the speakers, but when I'm recording in pro-tools 11 I can't hear any of my playback. I have to bounc
hello. Im not too familiar with Protools (mainly because its a headache right out of the box), but MY understanding is that Protools won't recognize a lot of external audio devices. (such as behringer)
however..if you are able to record and 'see' the audio there, just not hear it, there might still be a solution, & seeing as how i never used protools, it still might just work.
First of all:
if you're using the UCA-200 external usb box connected with rca cables, then my solution SHOULD work, as it is what i did to get mine to finally do the same thing.
#1) you will need to pick up (x2) RCA-1/4 jack adapters . (radioshack, about $2 each)
#2) insert a red and white rca cable in the RIGHT side of the Mixer's CD/Tape out .....the other end of the rca cables will go into the UCA-200 INPUT.
#3) with 2 more cables in the OUTPUTs of the UCA-200, put the rca-1/4 jack adapters on both cables, insert them back into the Mixer inputs 9/10 (in the analog 1/4 instrument inputs)
#4) adjust volumes accordingly, make sure channel 9/10 isn't muted, headphone volume is up, etc..
.......if that didn't do the trick, then you will need to go into the Audio Settings menu on your computer..(or protools) and change the default playback device to your mixer (probably named Generic USB or something similar)
I really hope this helps somewhat, because i remember going through the same thing & it took a looong time to find the correct awnser.
best of luck!
*also*
check for any updated drivers for your mixer! (I personally recommend you do a Google search for Asio4all drivers, they're pretty good)
if your awnser is A), i would suggest going into your computer's Audio Settings menu, and select the mixer as your default playback device.
Nov 23, 2013 | Behringer XENYX 2442FX Mixer
Right channel cuts out when I increase the volume
Blown or defective Headphone Amp IC or alternatively a defective Pot. Either way only AVID can fix it for you.
Outside parts and service is impossible.
Oct 03, 2012 | Digidesign *mbox2...
Volume meters are not picking up sound and is not recording,
This is probably pilot error. There are a bunch of things to do to setup this correctely. I would recommend looking at the videos about mixer setup on YouTube. There is a procedure you go through that is COMMON to most brands of the mixer. The fact that the volume meters aren't working at all implies a problem that the mixing buss is not receiving audio. Turn trim gains up, turn the faders both the channel and the main up, and UNMUTE the channels of interest and you should be getting audio through the unit. ALso does your headphone jack work?
Feb 12, 2011 | Mackie ProFX12 Professional Compact Mixer
I just installed my vestax typhoon and the drivers. everything seems to be running fine but i can only listen through the headphones plugged into the controller. no sound comes through my laptop speakers....
Make sure the Windows computer has the audio output selected to use the computers output hardware.
In the control panel, under "sounds and devices" pane, VOICE tab, that the Voice playback window shows your COMPUTER's audio system AND then check the volume is turned up by clicking the Volume button right under that same window. Now do the same under the AUDIO tab at the sounds and devices pane.
Feb 11, 2011 | Vestax Typhoon USB DJ MIDI Controller with...
Goodmorning, I'll try to explain the problem: when I listen to the files (MIDI and MP3) directly with Cakewalk sd-50 using the USB Key the playback is correct. When I listen to the files playing them...
You have to make sure that the clockspeed of the program that you use to play the files back with matches the clockspeed of the program that created them. I might be wrong about that. Here is a good resource:http://forum.recordingreview.com/f18/midi-troubleshooting-101-a-5208/ You will have to join to access but its free and the Killer Home Recording setting up is also free from the site and is full of good info.
Dec 13, 2010 | Cakewalk Roland SD-50 Mobile Sound Canvas
I hooked up my Mackie MR5 Monitors to my MacBook Pro through an audio interface, I use it to record my band in the studio I use out of my basement. Except everytime I try to use the monitors they give me...
try hooking headphones to the output and see if the crackling is still there.
then, try it with the speakers, at a lower computer voume level and higher speaker volume level. perhaps the headphone output is too loud and distorting in the speaker inputs.
Nov 28, 2010 | Mackie MR5 MR5 Reference Monitor
BR 8 headphone jack
This may also sound stupid but; have you tried a different set of headphones? If you have never used the headphone jack there might be a chance that the contacts inside the jack are dirty from airborn pollutants such as cigarette smoke or cooking smoke. Another good example is if you have a flute or silverware laying around in the open , they will tarnish from the sulfur dioxide in the air. Try spraying a very small squirt of contact cleaner on a stereo plug and plugging and unplugging it into the jack. Make sure you do this with the power turned off. If that doesn't work, do it to the jack itself. Only use a very small amount. If that doesn't work you may have a bad solder joint in the connections to the jack or a circuitry problem. The jacks sometimes a have a built in switching circuit to defeat the signal when phones are plugged in and sometimes the jack fails. Hope this gives you some ideas.
Oct 30, 2009 | Boss Micro BR Digital Recorder
Mackie ProFX12 Professional Compact Mixer Logo
134 people viewed this question
Top Mackie Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Mackie Music Expert? Answer questions, earn points and help others
