Question about Vizio 42 in. LCD TV
Lost picture at first and now it appears to have lost sound also
    Genius:
  • 1,622 Answers
Hi,lost picture - Sometimes, the TV may display a black screen, now you need to check the cables whether they are properly plugged or not. Reconnecting all the cables can also work for this problem. Also, if the screen has a screen saver, check how it's set up. And, if nothing works for this issue, then there is a possibility that the lamp, rear projection, or the LCD panel may have been damaged. Now, you need to check your warranty card of your television and se your set comes under the manufacturer's warranty period. Call the customer service for technical problem and get replaced if a part demands it.
consigning no sound on your TV
You might need to do some troubleshooting tips first before calling arepair man to replace the sound IC inside the TV.
Check the volume setting. It might sound simple, but it's the best place to start. Make sure the television sound is not muted or turned all the way down using the remote or buttons on the front of the television. If the batteries are dead in the remote and the TV is muted or turned down, it might seem like the sound is broken.
Examine cables connected to the TV. Sometimes a loose connection can cause a loss of sound. Ensure all cables are tightly connected to the television and correctly inserted. Some peripherals are connected using a three-plug system and are usually labeled red, white (sometimes black) and yellow. Both the red and white leads are sound cables. Try removing all the cables (except the power) from the back of the television and turning it to TV mode, then listen for static or other sound.
Plug in headphones to the television with all cables re-attached. See if you can hear sound through the headphones. If you can, it may indicate that the TV's internal speakers are not working. If you can't hear anything through the headphones, it may be indicative of a larger problem.
Call a repairman. If at this point everything has failed to produce a sound, it's time to call in the professionals. A qualified technician should be able to fix the problem either at your home or in a workshop.
Posted on May 28, 2011
Vizio tv has sound no picture
Hi Brenton,
You have sound and no picture. It appears to be a case of backlight failure which is common in LED TVs. The problem is technical and involves opening the tv, diagnosing and replacing or repairing the defective board. Please consult some good local TV tech. Good Luck.
Apr 28, 2015 | Vizio Razor E461-A1 46" LED TV 1920x1080,...
I got sound but no picture
if you push menu button the letters have to be there: meaning the signal is not arriving and maybe selecting a differnt input could appear video and the problem is only to find where is the video lost maybe only the wire.
The other case scenario is no picture at all; meaning the high voltage area is damage. keep us post it in this problem
Apr 08, 2009 | Sony KP-51WS520 51" Rear Projection...
Sylvania SRT2232S Powers On, No Picture, High Frequency squeal
Hello there. I'm sorry to say that it sounds as if the element that actually energizes your screen is bad. It is most likely overheating. or quite poosible the power converter lost a resistor or 2.
Nov 27, 2008 | Sylvania SRT2232S 32" TV
Blue screen with Green Star-burst image in center?
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jan 19, 2008 | Mitsubishi WD-52725 52". Rear Projection...
NO PICTURE OR SOUND ON THE TV
I'm not sure if you've done this yet, but this might work.. goodluck to you... let me know if it helps
Dec 31, 2007 | Philips DVP3340V
No picture but has sound
hello .this does sound like bad solder joints .all printed circuit boards do this after a while due to heating and cooling .is not advisable to try to repair yourself .possible electric shock and spiking .will do a lot of damage .take to a shop to have repaired
Oct 30, 2007 | Sony KV-36XBR450 36" TV
Sony KV-36FV15 TV Picture appears and then disapears,but sound stays
resold the lost contact varicap tuner beside tv tuner
Sep 17, 2007 | Televison & Video
Mitsubishi 6043A Loss of color
Sounds like many different problems maybe related thou. You say 6043a but you are under WD-62327. So this info is for that.1. Suspect the Light Engine part # 939P977020 also you could need.. Suspect the Signal PCB part # 930B923002 if no video keeps up
Aug 27, 2007 | Mitsubishi WD-62327 62" Rear Projection...
No pictures and no sound on Toshiba TW40F80 television
Check soldered-in micro fuses in power supply. Ex.--F851,F852.
If there is a blown fuse, identify which B+ circuit it protects.
Most common - convergence IC's bad===replace.
Need more help? Let me know.....T.
May 21, 2007 | Toshiba TW40F80 40" Rear Projection...
Open Questions:
See all Vizio 42 in. LCD TV Questions
Vizio 42 in. LCD TV Logo
118 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
