Question about John Deere Garden
John deere lx280 will barely move in reverse when peddle is pressed down, fluid level is ok. no problems going forward
  • 154 Answers
SOURCE: cub cadet 1863 trans/pump slips and whines in
sounds like the clutch not releasing all the way
Posted on Aug 05, 2009
  • 11057 Answers
SOURCE: John Deere LT155 Lawn Tractor has trouble going uphill
u can change belt yourself need belt size and have to remove cutting deck but check belt tension first if loose with brake off belt stretched out and slipping needs replacement
Posted on Sep 29, 2009
  • 195 Answers
SOURCE: My sons john deere gator started going forward in
It sound to me that you have put the battery on the wrong way round.
Check that it is connected the correctly.
Regards
Alan Hood
ami-man
Posted on Apr 06, 2010
philwalker78
  • 605 Answers
SOURCE: I have a L118 John
Hi, remove the battery and battery support tray and clean all debris from around the hydrostatic drive, fan and cooling fins. Your problem is caused by the hydrostatic drive overheating. Hope this helps, regards Phil
Posted on May 23, 2011
  • 328 Answers
SOURCE: '95 Mercury Tracer automatic transmission;
sir .
it is a torque converter problem not a gearbox problem
it contains oil also if it lost no power transfer between engine and gearbox could be th oil sealing of your converter
have a good day
Posted on Jun 11, 2011
My reverse won't work
Donna, there could be an issue in the transaxle/gear box take it into a good small engine repair shop and have them diagnose and estimate repair. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
John deere riding mower l120 has no reverse
John Deere SX 85 will not go into reverse or move backwards
Riding Mower Will Not Go In Reverse Quick Fix
Jun 12, 2016 | John Deere Garden
My John Deere 345 barely moves in Reverse slow going forward then all at once it takes off and everything works as it should for no rhyme or reason does this every time I start it up
Does your tractor have a hydrostatic drive? It could be just low on fluid. It is a hydraulic system and the pressure is reaching a functioning pressure at start up. If the fluid is low it will take a while to reach that pressure. It will gradually get worse as the fluid gets lower. Could be more serious, but this is something you can do without taking it to a repair shop!
May 20, 2015 | John Deere Garden
My Lt155 ride on wont engage in forward or reverse
(Simple answer)Hydrostatic drive machines have a setting that allows you to push them. machine won`t move if this is engaged.
Also If park brake is on. Otherwise check drive belt has not snapped is loose or broken. Jack machine up and see if wheels will drive without weight of machine.
Jul 26, 2014 | John Deere Garden
John deere sabre 2354 hv moves slow forward, even slower in reverse
this hydrostat drive tractor is designed to max at 5.5 mph forward, 2.5 in reverse, check linkage at pedal if you dont think your achieving those speeds
Mar 23, 2013 | John Deere 420,1020,2010,2020,2510,2520...
LX280 slow in reverse
check the pedal adjustment to loose will slow down reverse
Aug 12, 2012 | Garden
My John Deere LX280 is slow when backing up & has very little power. The fluid lever is good. Where should I look.
I have a LX280 that had this same issue. The problem was grass clippings blocking the pedal movement underneath the mower. Follow the rear pedal path and you may find the same issue. After removing the clippings buildup under the mower, the power was restored. Cheers!
Feb 29, 2012 | John Deere Garden
I have a L118 John Deere mower. When cold, the mower moves forward and reverse without problems. I mow my 1/2 acre yard and at the last couple passes, the mower barely moves forward and has no reverse. ...
May 23, 2011 | John Deere Garden
Garden Logo
100 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
