Question about MSI N430GTMD1GD3OCLP GeForce GT 430 (Fermi) (1 GB) 128bit DDR3 PCI Express 20 x16 HDCP Ready Video Video Card
I installed everything and it seemed fine, then when I restarted the computer the desktop was at 800x600. I tried to change the resolution back but when I did this the screen goes black. I shut the computer down then tried to restart. I get the windows 7 start up screen then it goes black again. When I start in safe mode it works fine. I have the latest driver from the NVIDA web site. I remove the card and it reverts back to the original and everything works fine again. What more can I try?
  • 336 Answers
Try first clean motherboard PCI-E slot using contact cleaner also the videocard maybe some slot loose. then try again to booting operating system windows 7.
Posted on May 28, 2011
    Problem Solver:
  • 10 Answers
Did you hook up your monitor directly to your video cards' visual port (whether it's VGA, DVI or HDMI) ?
Did you make sure the driver you downloaded are compatible with your graphics card ? with your operating system ?
Frankly, I don't have any more suggestion than looking in your graphics card's manual to check troubleshoots. They might give you an idea.
One more thing, if you time ahead of you, you might want to check if your motherboard is compatible with your graphics cards. To do that you might want to pay a visit to the almighty Google.
Good luck !
Nb205-n310/bn maxes at 800x600 screen resolution
Make sure you have the correct driver installed for the graphics. Right hand click on the desktop, select resolution and pick a size that fits.
Feb 12, 2014 | Toshiba NB205-N310/BN Netbook
I changed resolution settings by mistake.now to change them back i cant see bottom to click apply,also same problem when i try a restoe point
OK, when you first boot up, press F8 and select VGA MODE 800x600. Then when you get to the desktop, which you now will be able to see, go to your Video card resolution settings choose for now say, 800x600,and reboot,next time at the desktop, you can change resolution more carefully this time, :) Also, make sure you check the box, to apply, the resolution settings, without restarting the PC
May 21, 2010 | Microsoft Windows Vista Home Premium with...
No input signal on monitor after changing resolution
While booting press F8 , Go to safe mode and change the screen resolution and reboot the system.
Hope this helps
Siju.D
Nov 12, 2009 | Compaq Evo D500 PC Desktop
Screen resolution has interference when changed.
set it to the other display and then restart your computer.
Jul 10, 2009 | ViewSonic VA1916w LCD Monitor
Dialogue box in the middle of the screen
Out of range usually means that the computer is trying to use a resolution that is unsupported by the monitor. Try loading the PC in safe mode (for windows, press F8 before windows loads) and change the desktop resolution to 800x600, which is supported by pretty much any monitor. Restart the computer normally and you should get your video. Once inside windows you can experiment with different resolutions, and when it goes out of range, just wait 15 seconds for it to go back to 800x600.
May 15, 2009 | Microtek 710S 17" Flat Panel LCD Monitor
Display resolution goes from 1024x600 to 800x600 at start up.
try reinstalling the drivers for the onboard graphics and for the monitor. Might be the monitor is not supporting the default resolution.
Jan 18, 2009 | ASUS Eee PC 900 Notebook
Video problem
I had this same problem. What worked for me was going into safe mode, and in there I removed the video card from the device manager. When I restarted normally & windows re-installed it I was set back to the 800 X 600 which seems to be the default.
If that does not work I guess you could fall back to the old standby of delete windows & reinstall. While not my 1st choice it would fix the problem. Or another thought is take the machine to someone that has a better monitor, load into windows set it back to 800 X 600 & shut down. Back home it should be set again.
May 29, 2008 | ASUS P4S800-MX Motherboard
Trying to scan and I get message saying to change display setting to 800x600. How do I do this?
Right click on your desktop, go to properties. On display property click on settings then change the screen resolution to 800x600. hope that help get back to me if that error persist.
Apr 19, 2008 | Office Equipment & Supplies
Desktop resolution
turn power off... turn power on, right after turn on, keep tapping F8 till a boot screen shows up. then select safe mode.
after you boot up into windows, change the setting.
if it won't let you then you need to go into device manager and uninstall the display adapter. then restart computer.
the display adapter should auto install itself to default 800x600 or 1024x768.
Apr 09, 2008 | Samsung HCL5515W 55" Rear Projection...
Display problem
try to do a system restore, for windows (xp or vista) click start>all programs> accessories>system tools>system restore> next> choose date> next....>system will automatically restart and reset your computer back to the date you have chosen. Just make sure that you choose a date when all was working ok.
Feb 16, 2008 | Compaq Presario 1200 Notebook
MSI N430GTMD1GD3OCLP GeForce GT 430 (Fermi) (1 GB) 128bit DDR3 PCI Express 20 x16 HDCP Ready Video Video Card Logo
79 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
