Question about Philips AJ3980 Clock Radio
Philips Model AJ3980/37 would only display time, no alarm presets, and no audio. Since there is no reaction to any operation of the buttons, the manual said the problem may be "electrostatic discFixYaharge". Manual said to unplug and wait for 5 minutes, and as the display goes through the demo mode, press any button to exit the demo mode then insert presets. Pressing all of the buttons has no effect on exiting the demo mode. I'm not sure that what is displayed is the demo mode, as the only display is "Philips" scrolling righ to left. Any suggestions as to how to get the unit operational?
5 Suggested Answers
Ajkill
  • 2035 Answers
SOURCE: CD operation problem. Need manual.
Please click on this link and download the operation manual :
http://safemanuals.com/user-guide-instructions-owner-manual/PHILIPS/AZ1010-01-_E
Good luck..........
Posted on Oct 24, 2008
  • 4 Answers
SOURCE: Philips HDRW 720/17 stuck in '':demo'' mode???
Okay. I found that there IS a manual release for the disc tray UNDERNEATH the unit. It is a sort of toggle lever that you have to slide to the other side and that releases the disc. The Manual does not even mention this manual release lever!
Also, it may be hidden or covered by a paper like cover.
GL
Posted on May 14, 2009
SOURCE: Philips wake-up light HF3475 clock frozen
I had the same problem, that is how my problems with my beloved Phillips wake-up light started, the clock froze after having it for a little over 1 year..nothing worked so I gave up on it. I had it unplugged it for a few months over the summer.. when I turned it on again and the clock was unfrozen..?! Of course not fix-it solution for you..
But now it has new problems: It acts very strange, turns the light on and off by itself and sometimes gets this very annoying humming/buzzing sound.. which is gone when i "re-boot" it. I am sending it in for repair this week.
I simply can't survive the winter months without it!
Posted on Nov 18, 2010
SOURCE: How do I retrieve fax from the memory of my
inserted new ink cartridge and still showing cartridge low!
followed all instructions.
Posted on Aug 24, 2011
I have a CR15 and cannot have the clock ignore a preset alarm. The alarm goes off every day.
To turn off an alarm and cancel its7-5-2 settings, press its "Alarm Button" so that its Alarm Indicator no longer appears on the display.
Apr 30, 2017 | The Audio Players & Recorders
How do I set alarm? Instructions long gone
To the left of the display are two buttons, engraved "1" and "2". (Note, I'm NOT referring to the buttons for radio presets, which are below.)
Hold either of these buttons for a second or two to enter alarm set mode. The screen prompts will prompt you to set the time for the alarm to go off using the time set buttons to the right of the display. You can also press one of the radio preset buttons or the AUX or CD buttons to wake to one of those. Once you're done setting the alarm, quick presses of these alarm buttons turn the alarm on and off and choose between music and beeper.
As a side note, if you've installed the backup battery and the power fails during the night, the alarm will still go off with the beeper so you're not late for work -- a thoughtful touch from Cambridge Soundworks.
May 22, 2014 | Cambridge Soundworks CD-740 Clock Radio
How to set time and date on kenneth cole watch model a126-03 rk5033
I had 2 problems:
1- my watch was stuck in 24hr time format.
2- I didn't know how to turn the alarm off.
Solution for issue #1 (switching between 24hr and 12hr time displays):
You press both the upper right and lower left button at the same time's
Solution for issue #2 (turning alarm on/off):
You press both the upper right and lower right button at the same time, twice.
Apr 14, 2011 | Kenneth Cole RK5034 REACTION
How do I set the alarm clock on my wharfedale ne 3120?
Press the INFO button several times until you see "Alarm Status" displayed. I had to press it five times.
Then use SELECT button to choose between ALARM OFF and ALARM ON. If you choose ALARM ON, you can adjust the alarm time by first holding down the SELECT button until the display flashes. The you use the UP and DOWN buttons on either side of SELECT, to adjust the time, the type of alarm (Beep, FM or DAB) and if you choose FM or DAB, you then select the preset. Exit by pressing SELECT a final time.Then the INFO button to exit from setup.
Hope this helps.
Feb 10, 2011 | Vacuums
Operating instructions for blaupunkt 300 in car radio cassette ,got the code but dont know how to punch it in to the radio
ENTER A BLAUPUNKT CAR300 RADIO CODE
Switch the ignition key ON
Press and hold
AS button *  and the  ON button at the same time
Display Shows SAFE  then goes to 10 - - - - with a
"Beep" from the speaker
Press Preset Button "
1 "repeatedly until the 1st Digit of your Code is displayed
2" repeatedly until the 2nd Digit of your Code is displayed
3" repeatedly until the 3rd Digit of your code is displayed
4" repeatedly until the 4th Digit of your code is displayed
If the display  now shows the correct Code number then
Press  Button
AS  and hold to Enter and if successful  there should be a "Beep" from the speaker and the radio should switch on
Nov 30, 2009 | Blaupunkt Car Audio & Video
I`ve entered the code i was given for my philips bmw business rds PH7850V1303828 (code given was 8396) but nothing happens! am i missing something?
8396 is the correct code for that Serial Number.
Here are the Code Entry Instructions
Philips DC785/24E BMW Code Entry
After switching on the unit the display will show ' CODE - - - - '.
Press preset [ 1 ] repeatedly for the first digit
Press preset [ 2 ] repeatedly for the second digit
Press preset [ 3 ] repeatedly for the third digit
Press preset [ 4 ] repeatedly for the fourth digit
Followed by pressing the ' > ' rocker key.
The set will now operate.
Oct 02, 2009 | Philips Car Audio & Video
I have a radio model model 5000 RDS EON for a Ford Escort estate. The code i have has a 0 in it but for some reason this number doesn't appear when i scroll through the numbers, can you help please? Thanks
0 should display either on the 1st or 10th press of the Preset Button.
Ford Code Entry Instructions
Once the unit has been turned on the display will show ' CODE - - - -'
Press preset [ 4 ] repeatedly for the third digit
To save the code press the [ 5 ] key to accept.
The set should now operate.
Oct 01, 2009 | Car Audio & Video
Kenneth Cole Reaction watch date set problem
I just dug my watch out after not wearing for a few years and had the same problem. There is an easy way to adust this watch's time and alarm, basically one way to enter both.
1) With the watch in the regular time display mode (doesn't matter if 12 hour or military time), depress and hold the lower left hand button (mode button). After a few seconds the watch appears to shift to alarm mode and it is blinking. This puts you into the mode for adjusting the alarm.
2) If you want to adjust time, date, etc rather than alarm time, after you have done step one, simply press that same lower left button again, and then it will put you into the time mode, but this time the time mode is blinking and you can adjust the various components (seconds, minutes, hours). You can only move minutes, hours, etc forward, no way to move backward. You will start off with the second display blinking, probably skip that unless you need to adjust seconds. Depress the upper right button to shift to the next option (minutes) and you will see the minute display blinking. Adjust the minutes by depressing the lower right button. When finished depress upper right button to move to next option (hours) depress the lower right button to move the minutes/hours/month/date forward as necessary, when you finish just press the lower left button again and it pulls you out of adjust mode and you are back in regular time viewing.
I had to post this because I've had this problem in the past and it killed me. Its kind of intuititve after you get into the adjusting mode by pressing the lower left button- remember, initially it will put you into adjust alarm mode, but press again and you will get into adjust time mode.
Oct 30, 2008 | Kenneth Cole RK5034 REACTION
Zenith Z212B CD clock radio
Have you done the presets on the memory. Do that then select the station you want to wake up to. Hopefully its fm. Per the instruction manuel . Set or adjust the alarm time if necessary. Press the Alarm on/off button if necessary until one of the alarm indicatior either the note or alarm appears on display when the buzzer alarm is selected. While the alarm time display is flashing press the tuner button to select am, fm, or tv band. The selected indicatior appears in the display ( Note : you can only select the band when you have selected wake to music. While the alarm time display is flashing press one of the preset buttons to select the station you wish to hear when the alarm goes off.
Apr 17, 2008 | Audio Players & Recorders
How do I reset the radio alarm preset on Timex (T307S) Clock Radio
if the radio alarm is still showing the nonexistent 98.5, you would need to reset the radio alarm. Press and hold button 1 (top left hand side) until the display starts blinking. Then press the preset button for 98.1. It should then display 98.1 on your radio alarm. good luck this is the most difficult set of instructions I've seen yet
Sep 11, 2007 | Timex (T307S) Clock Radio
Open Questions:
Philips AJ3980 Clock Radio Logo
56 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
