Question about Sunbeam Microwave Ovens
I am trying to use my sunbeam coffee machine for the first time, after pressing manual for the water to run through...machine makes a noise but no water comes through! Model is Cafe Series espresso Kathleen
  • tztaylah May 28, 2011
    Thank you for your suggestion....however this coffee machine has just come out of the box....never used it, first time....it is making the normal coffee machine noise as we have one at work however just no water coming through....i have filled the water container
    Guru:
  • 352 Answers
Hello.
It sounds like the pump is not functioning at all, if the unit is under warranty then I would suggest taking it back ti the manufacturer. To replace this unit while under warranty would not be worth the time or cost in parts and labor. Nothing can be done without having to dis-assemble the unit.
I hope this helps Regards GM
Posted on May 28, 2011
  • Grant Meier May 28, 2011
    It still sounds like the pump is not functioning, if you have done everything correctly from the outside then my only suggestion is still to replace it under warranty.
    If it making all the right noises then the motor that spins the water pump has come loose or the pump mechanism has failed in some way. Not common for a new unit to do this but it does happen.
    Good luck
    Regards
    GM
Keurig Coffeemaker says to descale. How do I do that?
Hi, unplug the coffee machine and remove the cup.
Turn the coffee machine upside down over the sink in order to fully drain it of water. Be careful of the plug and avoid getting it wet.
Pour undiluted white vinegar into the reservoir up to the top edge of the viewing window.
Place a ceramic cup under the machine, plug it in and press "Brew" for a large cup. Pour the cups of vinegar into the sink and repeat the process until the reservoir is empty.
Remove the final cup of vinegar and empty it. Fill the coffee maker with clean water and allow it to sit for four hours, remaining on.
Unplug the machine and dump the water into the sink.
Fill up the reservoir with fresh, clean water and plug it in. Place the ceramic cup back on the drip tray and run multiple brews in order to rinse the machine of any remaining vinegar residue.
Apr 28, 2011 | Microwave Ovens
Working instructions not included would love to be able to use my new cafe series coffee machine purchased yesterday in WA at Rick hart
hello lyn... go to this link http://www.sunbeam.com.au/Pages/Browse/ProductDetail.aspx?pid=1136
just below the picture of the machine, click on "manual pdf" and you will have a free download of the instructions you are seeking. Joe
Thanks for choosing Fixya!!
Mar 06, 2011 | Microwave Ovens
Ive lost my manual for slush magic machine do you have the recipe please ??
The manual for the Sunbeam SlushMagic SL5200 can be downloaded from this webpage:
http://www.sunbeam.com.au/Pages/Browse/ProductDetail.aspx?pid=1464
Click on the icon for Manual (pdf) just below the picture of the machine.
Feb 16, 2011 | Sunbeam Microwave Ovens
My Sunbeam coffee machine model EM900 twin thermolock cafe series.Was leaking water around group head . Have replaced the grouphead seal but still leaks infact worse My machine is 7yrs old but in good...
I have a Sunbeam twin thermoblock Im having trouble with my steam wand I im not getting much steam out for the milk to warm up try to clean it with a pipe cleaner can you give me an advise how to get it woking
Feb 01, 2011 | Sunbeam Microwave Ovens
Inserted K cup and closed machine. Says Brewing but coffee machine only dispenses a few tablespoons of water...tried turning machine off and off, but same amount of water is dispensed each time, no matter...
Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Jan 01, 2011 | Microwave Ovens
Water will not pass through the capsule?
Try running vinegar in stead of water, without the coffee thru it several times.
Dec 27, 2009 | Microwave Ovens
Noise while not running
don;t worry;
all you need to do is lubricate the fan bearings with light machine oil and make sure the fan is not hitting anything
Apr 18, 2009 | Kenmore 63682 / 63684 / 63689 Microwave...
Microwave Ovens Logo
85 people viewed this question
Top Sunbeam Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sunbeam Microwave Oven Expert? Answer questions, earn points and help others
