Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
How do i change from 480i to 1080i on a sharp 52"
  • Sharp Master
  • 10,291 Answers
You don't. The TV picture will be fuzzy when watching a program in 480. If you have a lot of video in 480 or 720 you can get an up scaler. They are expensive, but that is the only way you'll ever get a Hi def picture from a low resolution signal
Posted on Dec 31, 2014
3 Suggested Answers
JTC13
  • 17 Answers
SOURCE: 480i to 1080i?
It depends on which input you are using, but the HDMI inputs are auto detecting. Most likely whatever device you have connected is not putting out a 1080i signal, and needs to be configured to do that. Once you do, you should see the input icons on the top right briefly come up, and below the input number, you should see "1080i"
Posted on Feb 19, 2009
SOURCE: sharp aquos 1080i is showing up at 480i. How do I
I have the same problem I'm sending 1080i to the screen and it will only display 480i. I too would love an answer to this question.
Posted on Nov 23, 2010
Changfrom 480i to 1080i
page 25 of the owners manual will explain how to put the TV in 1080i mode. Your source, if you use satelite or cable, must also be in 1080i mode.
The following website will take you to Sharp support , then click on the owners manual to download your manual.
http://www.sharpusa.com/CustomerSupport/SharpCareCenter/downloadfiles.aspx?modelid={DCEEF709-19D7-7A84-BCA2-F1CF67BABF0B}
Mar 05, 2015 | Sharp AQUOS LC60LE640U 60 inch 1080p...
Want to change my cable box from 1080i to 480i
U can't not change mode at will,the 480i or 1080i is determin by the show what mode is play on.1080i only in HD,more HD will need to order from ur cable,dish or telicom compannies.
Dec 17, 2009 | Sony Bravia KDL-40S4100 40 in. LCD TV
TV only formats at 480i
Check in your instruction manual to see if the set can actually work in 1080i. Most of the sets going back about 4 to 6 years ago were not capable of working in 1080i.
The signal coming to your Sat box may be in 1080i, but your Sat box has to be able to output 1080i. This can be quickly verified by calling the support for your service and giving them the model number of their Sat box.
Jerry G.
Dec 16, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Switch from 480i to 1080i
if the signal is not 1080i the tv will convert back to 480i. check your content.
Aug 20, 2009 | Mitsubishi VS-60111 60" Rear Projection...
Sharp aquos 1080i is showing up at 480i. How do I
Jul 18, 2009 | Sharp AQUOS LC-42D85U 42 in. LCD TV
How to change from 480i to 1080i
The TV has a automatic scalier chip installed so it depends on the input signal that you are using. For example you are using a HDMI connection with a xbox 360 and you set the display setting to 720P then the TV will display it in 720P. If you set it to 480P then it will display it in 480P.
Apr 01, 2009 | ViewSonic N2635w 26 in. LCD Television
480i to 1080i?
Feb 01, 2009 | Sharp Aquos LC-52SE94U 52 in. LCD HDTV
I dont know if my lcd tv supports 720i, 1080i, or 1080p
Sorry. It does not. 480i and/or 480p.
http://www.generalmanual.com/Televisions/Sanyo-CLT1554-STEREO-LCD-TV-EDTV-Monitor.htm
Picture Resolution: 1024 x 768 (XGA);NTSC (480i) EDTV (480p)
Dec 24, 2008 | Sanyo CLT1554 15 in. EDTV-Ready LCD...
Want to change my sharp hd tv from 480i to 1080p
You Can Not Change. The TV Recognize the signal on the INPUT.
If the signal is 480i than the tv shows 480i
If the signal is 1080p than the tv shows 1080p (if supported)
If you try with your areal antenna (for now digital broadcast is maximum 1080i (in USA) The TV itself doesnt "upconvert" lower resolution signals.
Dec 18, 2008 | Sharp AQUOS 52" Flat-Panel LCD HDTV
1080i???
YES ! Please provide detailed info so we can help you......
Verify Make,model #,service #,chassis # and MO/YR built
from the sticker on the back of the TV.................
Also, the part # of the " D " board installed in your set.......T.
Nov 19, 2007 | RCA HD52W56 52" Rear Projection HDTV
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
169 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
