Question about Dryers
I have a Eurotech Electric Dryer Model EDV 158, It turns on, the timer works but no heat on any setting. How do I know if it is the heating element or something else? Would it be possible for me to repair this myself? It is no longer under warranty.
zeusfaber
  • 247 Answers
SOURCE: kenmore electric dryer throwing breaker
Might not be a dryer problem. Following assumes that the breaker that's going is an overcurrent device (something in place of a fuse - what we in the UK usually call an "MCB") rather than an earth leakage circuit breaker. MCBs often have two trip devices - an electromagnetic trip which protects against major faults, and a thermal backup which protects against chronic overload. It could be that you're cooking the thermal element. How much current is the dryer meant to take? (Calculate by dividing power consumption in watts by supply voltage). Is there anything else coming off the same circuit breaker at the same time? Calculate the current drawn by the other loads, and add them all up. If the total current is more than the rated current of the breaker, not only have you found the likely source of your problem but also you've identified that you are overloading your wiring (finding this out is a good thing, as it gives you the opportunity to stop before you set the place on fire). If the total current is below, but near the rated current of the breaker, then you may have a problem with the breaker itself. Possibilities include inadequate ventilation around it or location in a cabinet which is picking up external heat (both need sorting out urgently) - or it may be that the breaker is old and tired and has gone out of calibration. Investigating any of these needs more skill than it's wise to try to acquire from a stranger on the web. A.
Posted on May 24, 2007
zeusfaber
  • 247 Answers
SOURCE: no heat
First port of call is thermal cutouts - little switches that monitor the temperature of the air going into the drum and cut the heat off before it sets your house on fire if something goes wrong and it all starts to get too hot.
Disconnect the power, then open the machine up. Look for the metal duct that directs the hot air into the drum (you'll recognise it by the funny-shaped blower bit at one end, and the collection of terminals sticking out of it at odd places about halfway along).
You'll find that some of those terminals are associated with flat coin or button like objects held tight against the surface of the duct (the number and exact appearance of these objects varies a little from amachine to machine). Look carefully at these, and you'll find that one or two of them have a little reset button in the middle of them. Check again that the power is off, then give each of these buttons a gentle prod. With a bit of luck, one of them will make a sharp clicking sound - you have just reset a tripped thermal cutout.
Check whether this has worked by running the machine. If it has, then you need to find out what made it overheat in the first place and stop it happening again. This usually just means giving all the filters and ducts a thorough clean to remove lint that's restricting the airflow.
If the thermal cutouts aren't to blame, then the next suspect is the heating element. Diagnosing this is a bit more involved, though still managable as a DIY job. Check the cutouts first, then come back if you need help checking the element.
A.
Posted on Feb 24, 2008
  • 7 Answers
SOURCE: Maytag dryer heating element does not turn off when tumbling stop
your timer is bad,the cost of a timer is close to a new dryer.
Posted on Jan 21, 2009
  • 1122 Answers
SOURCE: kenmore heavy duty clothes dryer will not heat
REMOVE THE BACK AND CHECK THE HEATER FUSE AND THE HEATING ELEMENT-MIKE
Posted on Feb 26, 2009
hunter19_46m
  • 7482 Answers
SOURCE: LG Dryer won't dry, no heat.
The heating coil is not too big of a problem to replace if you are mechanically inclined and have tools to do the job.
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the saftey of overheat from the machine.
Good Luck,
Hope this helps
Posted on Oct 17, 2009
The belt of my eurotech edv 158 broken from where I can buy new one???
Try going to repair clinic at repairclinic.com or parts pros.com
Jul 31, 2015 | EuroTech EDV158 Electric Dryer
I have a eurotech dryer model # EDC 158. Where can I purchase a latch assembly for it?
I have just spent 2 days trying to find a belt for a eurotech edc 158 Dryer. The company went out of business a few years ago and there is only one place to get parts. Call 972-941-1900. You will have to leave a message for a call back. Belt is $61 with shipping. They indicated they replacement parts will be available for 4 more years.
Feb 27, 2014 | EuroTech EDC158 Electric Dryer
My dryer model dv231aew/xaa Will not shut off unless you open the door....on/off & pause shows its working but its not
follow this steps and fix it. Merry Christmas
Timer
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is faulty replace it. If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. Replace the heating elements.
Dec 17, 2013 | Samsung DV231AEW 7.3 Cu. Ft. White...
Who services eurotech dryers near zip 98368
Clean out your vent before calling a repair man.
Apr 18, 2012 | EuroTech EDC158 Electric Dryer
My EuroTech dryer turned on for a second then I heard a popping noise and it turned off. I noticed at the bottom of the dryer (right side) looking through the vent, I saw a spark. What is wrong? I do not...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The electric heating element broke and is touching the metal and shorting out...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 13, 2010 | EuroTech EDC158 Electric Dryer
Heating element replaced. Worked one load and back or dryer seemed very hot. Turned off and later ran on low. Next load no heat.
Hi.
There is either a problem with the thermostats that turn off the heating element, or the heating element is plugged (elements has contact to ground and stays always on).
Heating element and thermostats are tested reading Ohms with a multimeter set at Rx1. If the circuit is open (Ohms stay infinite), then the part is defective.
If the machine overheated, then the element may be gone again. Test reading Ohms.
Also replace the thermostats (there should be two or three of them), unless the element had a contact, the most common cause for overheating is a shorted thermostat.
Aug 04, 2010 | EuroTech EDC158 Electric Dryer
Runs but no heat - can't find a Minnesota appliance repair business that supports Eurotech
Could be heating element or thermostat.....Look for a reset red button at back to push in 1st...
Jun 10, 2010 | EuroTech EDC158 Electric Dryer
Problem with Dryer Timer or heating element
The heat cycle must be working for the timer to advance in the Auto Dry setting.
Your heating element and or high limit thermostat is bad.
We need a complete model number to be more specific.
May 31, 2010 | Kenmore 600 6965 Electric Dryer
Kenmore Elec Dryer timer & Heat Element Failed
if you set timer on time dry it will count down but if you have it set on more or less it will not advance without heat,change out the heater and you will be fine
Nov 04, 2009 | Kenmore Elite HE4 Electric Dryer
Timer only works on Timed Dry Setting
Check your heating element. If one coil of the heating element is burnt out the dryer will heat on the remaining coil, but the timer will not advance in automatic dry.
Nov 13, 2008 | GE DBSR453EBWW Electric Dryer
Dryers Logo
46 people viewed this question
Top Dryers Experts
