The display rotae clockwise i want to go back from normal position
  • 32,281 Answers
An upside down image - this is caused by unintentionalpressing Ctrl-Alt plus the down arrow key. Restore by pressing Ctrl-Alt plus the up arrow key. ALSO To change the display from portrait to landscapePress Ctrl-Alt plus a left or right arrow key.
Posted on May 28, 2011
I need the firing order for A 2001 suzuki swift
1.3 engine 1-3-4-2 rota arm anti clockwise Cylinder 1 left as you look at engine,
May 23, 2011 | 1994 Suzuki Swift
How do I wind up my tag carrera automatic using the crown??
Wow, how wrong yall are.
There are three positions for the Carrera's push-down crown. The inner position is used for normal wear and winding. To wind the crown manually, simply rotate it clockwise.
Changing the date on the Carrera is done from the middle crown position. Turn the crown clockwise to advance the date, one day at a time. Push the crown back to the inner position when finished.
The outer crown position is used for setting the time. You can turn the crown in this position either clockwise or counter-clockwise. Adjust the time forward or backwards. Setting the time backwards will not damage the watch. When the time is correct, press the crown all the way into the inner position.
Feb 24, 2011 | Tag Heuer Automatic Chronograph Series...
My kenmore 417 94082500 dryer keeps pausing and shutting off with no errors between 5 and 10 min from starting.
Rotate the cycle selector knob three clicks clockwise (3 o'clock position) from the Normal cycle option then press and hold the Select and Pause Cancel buttons simultaneously for six seconds.Immediately after, press and hold the START and Pause Cancel buttons simultaneously for 4 seconds. Rotate the cycle selector knob one click counterclockwise (2 o'clock position) and the error code will appear in the digital display as an "E" followed by two numbers, a number and a letter or two letters. Post back the error code for further advice.
Feb 23, 2011 | Dryers
On my 1994 fireblade which way should the fuel tap face for normal tank compared to reserve? my fuel tap is long at one end and short at the other but which end is normal for fuel?
Start with the fuel tap (called a petcock) in the horizontal position. This is pointing toward the back of the bike, and it is in the "off" position. Turning it counter-clockwise to point up is "on," and turning it clockwise to down is "reserve."
Normally, you'll want to run the bike with the petcock set to on, and save the reserve for the emergency situation when you run out of fuel.
Feb 08, 2011 | 1994 Honda CBR 900 RR Fireblade
How do i set the day of the week on my Invicta subaqua noma 6125?
For Invicta chronographs to set the day you need to pull the crown out to position 3 (2nd click after releasing the crown/ furthest crown position/ same position to adjust time). You can only set the day by rotating the crown clockwise. Every 24 hours of clockwise rotation will move the day indicator forward 1 position (Mon>Tue, Tue>Wed, etc). If your watch is set one day ahead of the correct day (Its Tuesday but the watch displays Wednesday for example) you will need to rotate the crown clockwise through the entire remainder of the week in order to get to the correct day, you CANNOT rotate the crown counter-clockwise in order to move the indicator back a day.
May 21, 2010 | Invicta Subaqua Noma Iii Chronograph men...
I have a tag heuer aquaracer crono automatic and i can hear it and feel it when its self winding is this normal?
this is normal if you didnt i would be worried..all automatics do this its the rota in the back theres no such thing as a silent automatic in the trade we call them swinging bricks..
Mar 23, 2010 | Tag Heuer Aquaracer Chrono Automatic...
Polo not firing which way do plugs run on to distributor cap 1.4 96
Firing order 1.3.4.2
Number 1 cylinder left as you look under bonnet
Rota arm turns anti clockwise
Feb 13, 2010 | Volkswagen Scirocco Cars & Trucks
Changing the date on a fossil watch- how do you do it?
Which Fossil do you own?
Analog Date Watch:
Date Setting
  1. Pull the crown out to position 2.
  2. Turn the crown either clockwise or counter-clockwise and set the date for the previous day. The direction that moves the date varies on different watch models.
Analog Automatic:
Time and Date Setting
  1. Pull crown out to position 2 and rotate clockwise to set time.
  2. Pull crown out to position 3; date will advance automatically. To set to required date, continue to rotate crown between positions 2 and 3.
  3. Push crown back to position 1.
Analog Digital:
Time and Calendar Setting
  1. Press and hold pusher A for 2 seconds to enter setting mode. Year will begin flashing.
  2. Press pusher A to select year, month, date, hour, minute, second, and then exit setting mode.
  3. Press pusher B to adjust digit.
  4. Press and hold pusher B to adjust digit automatically.
  5. If no pushers are operated for 30 seconds, setting will be returned to Normal Time Display.
These are the three most common Fossils. If yours isn't here please let me know which model you have and I'll get you the instructions.
Hope this helps.
Dec 12, 2009 | Fossil Watches
Setting instruction for Accurist world time wrist watch
Same just happened to me, performthe following:
The analogue hands are not precisely synchronised with
the digital time?
1. Press the lower right button to move the mode indicator
hand to CHR.
2. Pull the lower right button out one click. The hour, minute
and UTC hands will retract towards the straight up 12 O’clock
position. You will see UTC on the top half of the digital display.
3. Press the upper right button to advance the hands to the
straight up 24-hour position. Use the lower left button to go in
reverse.
4. Press the upper left button. You will see HR on the top half
of the digital display. Press the upper right button to advance
the hour and 24-hour hand clockwise until they both point
straight up at the 24-hour position. Use the lower left button to
move the hand anti-clockwise.
5. Press the upper left button. You will see MIN on the top half
the minute hand clockwise or the lower left button to move
anti-clockwise until it is pointing straight up at the 12 O’clock
position.
6. Push the lower right button back in one click.
The watch malfunctions in some way and the above
procedures do not work.
1. Press the lower right button until the mode indicator hand
points to TME.
2. Pull the lower right button out one click. Press the other
three buttons down simultaneously for three seconds and
release. You will see 8’s on the digital display.
3. Press the upper left button. You will see UTC on the top half
the hands of the top dial to the straight up 24-hour position.
Use the lower left button to go in reverse.
position.
Jul 06, 2008 | Watches
Computers & Internet Logo
David Payne
David Payne
