Question about Sharp AF-S120FX Air Conditioner
Ac shuts off E1 error message - Sharp AF-S120FX Air Conditioner
  • 17,970 Answers
E1 Error Code -->> Clean Filter
Owners of Sharp air conditioner models AF-S60FX, AF-S80FX, AF-S85FX, and AF-R80FX may experience the following (highly annoying) issue. After 720 hours of fan operation, the error code E1 will appear on the seven segment LED temperature display. This error code is intended as a reminder for the user to clean the air filter. However, because the procedure outlined in the user manual does not clear this error code as indicated, and the appliance has a nonvolatile memory that cannot be reset by simply unplugging it, the user of the appliance will become mightily frustrated, standing in potentially sweltering heat watching the appliance repeatedly shut down in the midst of operation with the "E1" display flashing.
Believe it or not, that is what it does: if you unplug it to remove the "E1" code from the display, and plug it back in and re-start it, it will simply run for anywhere from a few minutes to a few hours, and then merrily shut down again with the same flashing "E1" code.
Many people at this point, having put the manual under the canary or some such, will simply return the unit and never buy another Sharp air conditioner. But for the tech-savvy and search-adept, I offer the following procedure to clear the nefarious E1 indication, and obtain another 720 hours of cooling bliss:
1. Power down the air conditioner using the "power" button on the front panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air conditioner in. Continue to hold the power button down as the machine goes through a brief test sequence (fan & compressor each come on briefly, etc). There is a "beep" sound at the end of the test sequence, and the machine will be off. At this point, you can release the power button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air conditioner normally for another 720 hours, but only if you followed the instructions above exactly.
If you doubt the veracity of this information, or it does not work as expected, you can get it directly from the source at: 1-800-237-4277 (Sharp customer service line). You'll need to call between 7 AM and 7 PM US Central time, and have your model number and serial number ready.
Posted on May 28, 2011
  • 4 more comments
  • marieking82 Jul 15, 2011
    This information solved my problem. I thought I would need to replace And started looking in stores to no avail, as we were in the middle of a heat wave. Thank you so much.
  • williambozad Jul 30, 2011
    Worked like a charm. This info should be in the operators manual. Who wants to wake up in the middle of a hot night to an error code and now way to fix it. Takes 5 seconds to reset the unit,
  • CHRIS FINLAY Nov 15, 2011
    RIGHT ON SOME ONE WITH GREAT KNOWLEDGE AND DIDNT HAVE TO PAY FOR IT WORKS LIKE A CHARM.
  • Sharppy May 07, 2012
    Thanx a lot! That did it! Just in time 4 heating time :)
  • subabi
    subabi Jul 21, 2012
    Thanks a lot, It's works, almost bought new one.
  • Takia Washington
    Takia Washington Aug 30, 2015
    Thanks that works plus I needed to replace the filter.
2 Suggested Answers
  • 51 Answers
SOURCE: yonan ac split mini 1.5 ton error codes E1
CHECK ROLLOUT SWITCH AND CHECK FOR A POSSIBLE
GROUND FAULT..OR FUSE..
Posted on Apr 13, 2010
What does E1 mean on portable AC
E1 "Error Code" means different things with different appliances and you need to give a specific Make and Model of AC..
It should be explained in the troubshooting section of the user's handbook..
"Clean Filter" is a common routine message..
Oct 19, 2014 | Heating & Cooling
What does treadmill error code E1 mean?
Precor Error 01, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicate an upper PCA problem when they are consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis.
Here's a link to more error codes:
Error Code List for Precor Fitness Equipment
May 26, 2014 | Precor Exercise & Fitness
E1 Error on air conditioner
It's time to call a professional. Call the manufacturer and ask them who they recommend in your area. Note :Some questions can be answered if you put enough information such as brand and model number.
Mar 25, 2017 | Haier HWR08XC7 Air Conditioner
I get a E1 error code on my window ac unit. What
Indoor room temp sensor defective. Replace it.
May 26, 2010 | Haier hwr10xc6 Air Conditioner
Sharp AF-S120FX Air Conditioner Logo
1,648 people viewed this question
Top Sharp Heating & Cooling Experts
Tim Whalen
Pete Norton
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
