Question about Motorola Mobility RAZR V3
Razor making double beeps or weird sounds while on battery seems to be going down quick
My razor when on occasionally makes a weird double sound. also, the battery seems to be going down quicker than before. what do you think?
  • Anonymous Sep 01, 2008
    I seem to have the same problem even after recharging the phone and the batery life seems ok to me. The sound drives me crazy! Any suggestions?
  • 3 Answers
Remember to turn your bluetooth off and set the backlight lower. the double sound is probably telling u low battery
Posted on Aug 17, 2008
How to solve the shorting battery problem when I use PPT button?
What make and model of camera are you having this problem with ?
Aug 21, 2016 | Cameras
My Fridge isn't cold anymore, what could be the issue?
call a repairman , sounds like it need freon added
Nov 17, 2015 | Refrigerators
Had customer with CO detector sounding quick double chirp about every five minutes. What is this?
This is not a beeping smoke detector. It is probably a CO detector that was installed by your alarm company. GE model 240-COE will give a double beep every 5.5 minutes when the device reaches end of life. Call your alarm company to have it replaced.
Jun 07, 2014 | Kidde DC Voice-Alert CO and Smoke Alarm
My dishwasher won't drain properly. The pump has been making a weird sound for a month or so and last night it couldn't drain. It starting beeping and the pump was running. I cleaned the drain filter
If the pump is running but noisy then that indicates a loose pump impeller (new pump I am afraid) if running (no noise) but failing to remove water, then I would be checking that drain hose is clear, or even that your machine is not syphoning water from waste disposal, a quick check would be to disconnect waste hose from waste disposal and see if it will then drain into a bucket, hope this is helpful.
Feb 18, 2013 | Dishwashers
1995 Super Duty XLT sometimes misfires at highway speed. (It seems to happen going uphill, even VERY slightly, so that might not be relevant.) It also occasionally dies when stopped. It always restarts...
if Equipped with coil packs(5.4) sounds like one or more are going bad this will make the truck miss fire unless it's deisel. When was the last time the fuel filter was changed? sounds like it might not be getting enough gas.
Aug 13, 2010 | 1999 Ford Super Duty F 550
Fender bassman 200 producing fuzzy tone
I would check all the connections, try switching different connections making sure it's not the jacks, if that doesn't work, try sending to company if under warranty.
hope this helps
Apr 01, 2008 | Audio Players & Recorders
Samsung c630
Just bought one recently, and experienced a melt down like that..
What batteries are u using?..
This cam uses lots of power and i started off with 2700 rechargeables, after their 1st charge they emptied fairly quickly, after shutting the cam down for a few mins, they soon picked up again, i was using flash everytime, i guess this was the problem... When my rechargeables started to run down, the cam acted weirdly.... i think ur problem may be because of batteries weakening at that particular time??
Are you aware whether ur batteries were full or nearing empty at the time??
Colin
colinfenning@yahoo.co.uk
Dec 15, 2007 | Cameras
Sound problem
All you can do is a battery reset. Important thing for battery reset is to always make sure unit is on. Remove the battery. Wait 10 sec and then put it back in. Other then that check your warranty status.
Oct 16, 2007 | Motorola Mobility Q Smartphone
Motorola Mobility RAZR V3 Logo
54 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
