Question about Kenmore Elite 45986 Front Load Washer
F35 error displayed - Kenmore Elite 45986 Front Load Washer
  • Kenmore Master
  • 17,970 Answers
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Hope helps.
Posted on May 28, 2011
Kenmore elite 5t steam f35 and sud problem
The F35 error code indicates a problem with the analog pressure sensor, air hose or air trap. If the hose and trap are good you will need to replace the pressure sensor
The "Sud" error code indicates too much or the wrong kind of laundry soap was used. Be sure to use only HE (high efficiency) detergent on this model of washer.
Please see the links provided below for access instructions & other troubleshooting tips covering the error codes displayed:
- Link 1
- Link 2
Hope this helps (remember to rate this free answer and leave some testimonial).
Sep 25, 2011 | Kenmore Elite 45986 Front Load Washer
My whirlpool duet washing machine displays code F35 and won't complete the washing cycle.
Hello & Welcome to FixYa
F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
Apr 16, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer displaying F35 error message??
F35 Error
ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer component detected by the Steamer Electronic Board.
1. Check if pressure hose is fi xed correctly.
2. Check if the airtrap is not blocked.
3. Check if the hose is not blocked.
Dec 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool 9600 washer displays F35 error code and stops. Where can I find the manual to understand what F35 is? Thanks.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.****
Aug 29, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I am receiving an F35 error on my washing machine. Doesn't happen all the time but it is more often now. any ideas?
F35 error indicates Analog Pressure Sensor Failure. If this failure is displayed, there is a malfunction in the steamer component detected by the Steamer Electronic Board.
Please check for the following to solve this issue
Thank you !!
Jun 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet -Sud displays and washer stops
I;ve had the same problem (SUD on first fill) and found this most helpful for my WFW9600TW01 Duet washer
http://www.tellingmachine.com/post/Fixing-Sud-and-F35-errors-on-my-Whirlpool-WFW9600TW01-Washer.aspx
I duplicated his actions and it cleared up my SUD/F35 error. I think running the diagnostic test multiple times flushes the sensors/sensing lines to eliminate the problem.
Jan 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does f35 mean
Hello there
F35 found in this link
http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
F35 means ANALOG PRESSURE SENSOR FAILURE
1. Check if pressure hose is fixed correctly.
Dec 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F35 message, will not run through cycle. Starts to and then the F35 starts flashing and eventually shuts off.
Check between door boot seal and drain hose in basket. If this is clogged with lint or sock, towel it will code f35 or sud
Oct 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing clothes all day have an F35 flashing
F35
Possible Causes/Procedure
Check these problems.
Plesae leave a solved rating before you leave the site
Jan 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
75 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
