Question about One For All URC-6131 Remote Control
The remote will not instal on my tv - One For All URC-6131 Remote Control
    Brigadier General:
  • 3,301 Answers
I have an old Tedelex tv and want to install a diffrent remote on it. the tv work by by pressing buttons per hand. I am in hospatal and can'nt stand up
I usually get remotes from a cheap Chinese shop. They have codes for most TV makes. Incidentally, they also do remotes for aircon units. If no local shops, you'll get one on ebay.
Feb 08, 2015 | Televison & Video
Protron lcd tv installing a universal remote but no where to turn on tv. old remote has gone out
It is preferred to have the TV on when programming a remote,but usually not necessary.If you enter the programming codes in the remote,it should be able to turn on the TV if the code is correct.(The remote puts out the same command to turn the TV on or off).
Jul 31, 2012 | Protron PLTV3250 32 in. LCD Television
I have no dirver of SAA7130 TV Card - Video Capture
Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Cardr I installed the hardware, no sound was coming, neither did the
remote work. After I troubleshot following the
guide on the official website of sabrent, I successfully solved the sound problem by reinstall the
driver.
However the remote still
does not work. I installed the remote driver, there is a icon on the taskbar :
"SAA7130 TVcard Remote control receiver".
I also made sure the
batteries are good, the sensor are installed correctly, but still couldn't solve
the problem,
Jan 27, 2011 | Philips SAA7130 TV Tuner/FM Radio/Video...
Problem in recording and using the remote
this is only a wild guess, change the battery of your remote, i once use a tv tunner and the only problem is the battery from the remote
Sep 23, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
Tv Code for Time Warner Cable Remote
I need got a different tv tan i had when my tv was installed s i need the code
Nov 14, 2008 | Televison & Video
Zenith TV not programmed for home purpose
If you have a remote that can access menu and your remote has number buttons and an enter key, you can follow this instructions to go to installer menu. Note that the installer menu is slightly different for each model, eg. some options are not available.
I was able to go to installer menu using two universal remotes. The remotes that I used were Dish Network 3.0IR and RCA RCU300WBL. Both remotes programmed for Zenith H2531DT TV. The reason why I had to use two remotes is that Dish Network remote was only able to access menu. It did not have ENTER key but RCA remote had ENTER key but I wasn't able to go to menu with that.
To go to installer menu (different from regular menu):
- Hold MENU for 8 seconds.
- Press 9, 8, 7, 6 and ENTER in the sequence.
You should be in the installer menu now. There should be a line that looks something like this:
03 VERT POS 13
Use SELECT button to scroll through each option, and ADJ button to adjust the values for each option. For example, to enable the front panel buttons on your tv, set KEY DEFEAT to 0. Other options that you might want to check:
CHAN LOCK which locks your TV to a single channel and wont let you change (set 0 to turn off)
START CH/VOL will set your tv to a specified channel when you turn on tv. (set 255 to disable)
You will have to look in the menu for some of the options because they are different for different TV series. A good place to find manual is on www.zenith.com or http://safemanuals.com/
I work in an old hotel and it took me few hours to figure out how to disable start channel lock. It drove me nuts. I hope someone finds this useful.
May 26, 2008 | Zenith SC652 Remote Control
TV Stuck in TV Guide Plus+ Installation Mode
buy a good universal remote and it will have the correct button, that's what I did, I got the Radio Shack 8-in-1 remote and programmed it and it got rid of it.
Dec 03, 2007 | Mitsubishi CS-36609 36" TV
Universal Remote
please open it & get the reply.
http://www.remotes.com/
Oct 18, 2007 | Panasonic CT-27G11 27" TV
One For All URC-6131 Remote Control Logo
16 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
