Question about Philips PET702 Portable DVD Player
My dvd has a white screen - Philips PET702 Portable DVD Player
    Guru:
  • 586 Answers
this problem you are encountering is common with most portable DVD player's. The problem most at times is coming from the flex or screen inverter. The flex eventually worn out as a result of regular opening and closing of the player.
The screen displaying white is a symptom of bad flex or inverter.
To confirm, insert a disc into the player, press play. You should hear sound coming out of the speaker of the portable player even as it is playing.
Furthermore, connect an AV cord from the portable DVD player to your TV and you will eventually find out that it is going to display on your TV.
Having done the above, and having confirmed that the flex/inverter is that cause of the problem, please get back to me so that I may direct you further on what to do next.
Your sincerely.
Elect_Comp.
Posted on May 28, 2011
  • 1 more comment
  • marili27 Jun 17, 2011
    Mine has the exact problem. I hear the music but screen stays white. What can I do?
  • Shanda Smith Nov 03, 2011
    I am having that problem with the white screen. I connected it to the TV but I can only hear the sound threw the TV no picture can you please help.
  • ivorycruz17
    ivorycruz17 Aug 25, 2012
    can you please help me ASAP
  • 83 Answers
Hello this GHeng, pls double check ur jack my it has loose connection try to get another jack... gd luck!
DVD player is black and white and screen is split
Make sure the player is compatible with your TV broadcast standards. A Pal player will show b&w pictures when connected to a NTSC tv and vice versa
Feb 26, 2015 | Samsung DVD-V3500 DVD Player/VCR
My PDV-088PT White Screen?
The video processor has failed, or the LCD panel display, either way the cost to repair cannot be justified.
Apr 09, 2012 | Polaroid PDV-088PT Portable DVD Player...
My Phillips DVD player has a white screen. It will play the DVD but still show white screen.
The wire could be loose that connects the screen to the dvd player board, these are a common problem on alot of portable dvd players.
jon
Aug 10, 2009 | Philips PET702 Portable DVD Player
I don't know where to put the yellow, red and white connectors on the TV or the dvw
look on the back of your flat screen , there is a panel with inputs , example: VIDEO 1 , VIDEO 2 , etc. , connect your yellow , red & white from the DVD COMBO to video 1 (input) there colored to match with your cable , yellow w/ yellow , red w/ red , white w/ white , hope this helps AJ
May 08, 2009 | Sanyo DVW-6100 DVD Player/VCR
The screen is blank and white and the sound works
maybe the set-up of your dvd is pal. try to select auto
May 05, 2009 | Televison & Video
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
DVD player won't work on my 27gt615
alexa,
good day, if youre saying that you program the DVD to work on channel 2 or 4 does it mean you convert the signal of your dvd player from A/V output to RF out?
because the simpliest way to connect your DVD player to TV screen is by using RCA cable ( 3 wired cable being color marked as yellow/red/white) yellow = video red and white = audio
the connection would be: from dvd back part you'll see colored socket yello/red and white. connect the RCA to those socket following the same color .
and from the TV screen there should be A/V input socket. can be locate at the BACK/Side or FRONT of the screen marked as
"INPUT" ( AV1, AV2,AV3 if multiple inputs). Then select which input you want to place your DVD player ex.AV1 (from AV1 there will be 3 scoket in a row, yellow/red/white)
Connect the other end of your RCA cable following the same color code to TV "AV1 INPUT" yellow = yello/red =red/white=white. then from the remote commander of your TV screen locate a button marked as "TV/AV" or "A/V" press this button until the screen display switch to AV1.
cheers,
mark
Jan 31, 2009 | GE 27GT619 27" TV
Screen is white
Hi
maybe you have defective Flrx ribbon wire or the LCD is the defect.
Thanks!
Dec 14, 2008 | Haier Portable DVD Player PDVD7
Thin white line on screen
this is a screen fault... this should be sent to the maufacturer for repair/replacement if still in warranty
Sep 28, 2008 | Durabrand DVD-1002 DVD Player
WHITE SCREEN
Our Philips PET702/37 Portable DVD player has white screen, when i press the screen appears the image. please help me. thanks
Jun 07, 2008 | Philips PET702 Portable DVD Player
Philips PET702 Portable DVD Player Logo
813 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
