Question about Brother Office Equipment & Supplies
MFC-5840CN 4 yrs. Old Error Message: Unable to Clean. Tried troubleshooting suggestions in manual including unplugging to reset but it doesn't work. Please help.
    Genius:
  • 3,422 Answers
Please try this reset procedure:
hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed."
Go through the items with "down" key and located Purge Counter.
"Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero
Press the Stop/Exit key to return to the initial stage of the maintenance mode.
Press the 9 key twice to return to the standby state."
Posted on Aug 16, 2008
  • 446 Answers
I assume you are having this error...pls read
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An “initial purge”, for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an “Unable to Clean” external message and will be unable to use the printer. The “Unable to Clean” external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If there is a Machine Error 46, it is necessary to dismantle the printer, replace the ink absorber box (or possibly break the ink absorber box open and clean its absorbent sponges under a tap), re-assemble the printer and reset the purge counter to zero.
Resetting purge counter MFC620CN/420CN/410CN/210C and FAX2440C
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
hope this helps, cheers
  • Brother Master
  • 19,396 Answers
Try replacing cartridges and performing a nozzle check head clean procedure, this should fix it.
  • Ginko
    Ginko Aug 16, 2008
    what is the exact error message? and what is happening to the printer? LOL
    It is a error 46 unable print head error, as stated when this happens usually you have to replace waste ink absorber which can be bought as a spare part from any repair shop.
    When the absorber is replaced you also need to do a printer reset.
    Guru:
  • 1,894 Answers
What is the exact error message? and what is happening to the printer.
please tell us clearly.
  • 1 more comment
  • dewan nafees ahmed Aug 16, 2008
    The waste ink tank is full and has to be changed. Buy a new one from a
    service partner. Dont clean the old one, cause the felt will be as
    stone afterwards and wont take up any ink!
    See link how to open printer:
    http://www.hstt.net/refill-faq/inside.ht...
    See here how to do the reset code procedure:
    http://www.fixya.com/support/t139675-nee...
    DO NOT only reset the code but change the waistinktank!
    Otherwise ink will flow into the machine and will cause serious damages!!!!!!!!
    this error 46 is very wide spread and faced by many users.
I have got the error message " unable to clean , see troubleshooting and routine maintainance in user's guide" . I have tried all ways in the user's guide and also other suggestions. Please gi
If your your printer cannot clean automatically, your printer head is probably clogged so badly that you will have to do it manually.... your manual should tell you how to remove it...
Jan 12, 2013 | Brother MFC-210C All-In-One Printer
My brother 5840CN. lit says unable to print. the manual says to take the jam out - there was no jam. Turn it off, then on. i did that. It still says unable to print, look at troubleshooting page
errr.....No, no it does not. The Manual says that "unable to clean" means one of two things.....
1. The MFC has a mechanical problem.-OR-2. A foreign obstacle, such as a clip or ripped paper, is in the MFC.
but regardless, I don't believe it *IS* a 'cleaning' problem per se.Try resetting the power purge counter.
Press menu > Mono Start > 4x Arrow up after another. All lights will flash.
1. Power clean - Press 7>6>4 >Mono? Start.
2. Power Purge: 7>6 >3 >Mono Start.
Press 9>9 to exit maintenance mode. Run a print quality test print.
http://www.brotherprinterrepair.com/cleaning-a-brother-mfc-420cn-printer-head/
Tallon41
Sep 16, 2012 | Brother MFC-5840CN All-In-One InkJet...
My unit has a unable to clean message on the screen and I do not know where my manual is (just moved) How do I fix this
The ink absorber box and the flushing case will need to be replaced. Then the purge counter and the flushing counter will need to be reset to 0.
Aug 03, 2009 | Brother MFC-5840CN All-In-One InkJet...
BROTHER MFC-5840CN "UNABLE TO CLEAN"
If you go to this page you can download the user manual right from the Brother website: http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000075/MFC-5440CN_UsaEngUsr_D.pdf
May 27, 2009 | Brother MFC-5840CN All-In-One InkJet...
Unable to clean
you might try cleaning the grid on the drum cartridge with a fine brush like a painters brush
Jan 13, 2009 | Brother MFC-5840CN All-In-One InkJet...
Unable to clean message in brother dcp-115c aio
I saw on this site codes for another MFC to clear memory and reset the cleaning unit count code to zero. It worked on two of my brother mfc 820cw units. The third mfc 5840cn had unable to print error message 46- nothing at Brother. they want you to take everything to a repair shop.they don't help at all. Then the error went to 4F when I tried toclear the memory.As Iunderstand that message- it means I have to replace the printer head. Have no clue where or what it is. But I can read a manual as well as anyone and follow directions to fix it! Can't be worse than it is now! Good luck
Jul 22, 2008 | Brother DCP 115C All-In-One InkJet Printer
Brother MFC-5840CN unable to scan
From Brother Customer Service email:
You can try the following reset - it will most of the settings back to the default options.
Unplug power cord to the machine.
Press and hold down Menu.
Plug power cord back in.
Let go if menu when fax/scan/copy flash.
You may see either "maintenance" or "machine error xx" on the screen.
Type stop/exit, 9, 1.
The machine should show "param init" or similar to show that the reset is being done.
It will then go back to or machine error.
Type stop/exit, 9, 9.
This should take the machine out of maintenance mode and back to normal.
If the error is still present the machine will require an engineer to resolve the issue.
Jul 08, 2008 | Brother MFC-5840CN All-In-One InkJet...
Print function stopped working. Brother MFC 5840CN
First things first:
press menu then start bk-copy then fourtimes arrow-up button. machine will display an error code no. plz post AS A NEW POST again.
BTW: The update has nothing to do with the stopping of the machine!
Jan 10, 2008 | Brother MFC-5840CN All-In-One InkJet...
133 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
