Question about Video Game Consoles & Games
Tower fell over and the disc wont work now? - Video Game Consoles & Games
  • 2,404 Answers
Its possible because the laser inside of the disc drive is sensitive to motion. The console dropping could cause the laser to go bad because the "eye" goes bad. The part that reads the disc. Depending on what game console your talking about, try getting another know good working drive and replace it to verify that the original is bad.
Posted on May 28, 2011
I need a picture of what the insides of the tower looks like a plug fell out
Tell me what is the wire color ? it should be nothing other than the LED light / reset / power button.. Just confirm me if all the front panel buttons are working ?
this is the motherboard picture but it wont help unless you find what is not working in ur pc - https://www.blueraven.com/BlueRavenResource/ItemimagesLegacy/Z3807-0.jpg
Jan 28, 2013 | Acer Aspire T180-EA350M (AST180EA350M) PC...
The spay tower in the bottom fell out. should
If the spray tower is not in place then water will not get to the spray arm for the upper rack. You should be able to re-install the tower. Look for small tabs at the bottom that fit into slots in the mounting. The tabs should snap in or lock when the tower is turned slightly. If the tabs are broken off you should replace the tower. You can use the dishwasher without it but he dishes on the top rack will not get cleaned and the pressure tot he bottom spray arm may be reduced causing dishes to not get completely coean.
Dec 21, 2009 | Kenmore Dishwashers
Wii console fell and now it wont eject the disc
sometime on consoles there is a small pin like hole next to the drive. a paper clip inserted into this and jiggled around might free the disc to open. works on computers might work for you. but if it fell looks like its f**ked
Aug 31, 2009 | Nintendo Wii Console
Our wii wont read disc
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Jul 10, 2008 | Nintendo Wii Console
HP DVD 740e wont burn Dual Layers anymore!
Try re-installing the software associated with the burner, so it installs the necessary drivers and files needed for the burner to work according to your needs.
Also check the connections and cables... sometimes moving it around causes the cables to loose some contacts.
Hope this helps...
Feb 26, 2008 | HP DVD 740VI 16X16 Dual Layer LightScribe...
Spray tower fell off
The Spray tower fits in the bottom rack, Its actually pretty obvious as there is no way it can sit int he position it has to without being in the rack itself otherwise the rack and tower would block each other all the time.
 Examine the base of your spray tower it should have two "clips" or plastic protusions that will, with a circular twist, snap onto the bars of the middle of the rack itself. Then when in place and your rack is slid inside the dishwasher the tower should sit directly over top of the exact middle of your bottom spray arm.
et Voila.
Nov 09, 2007 | Kenmore 24 in. 16309 Built-in Dishwasher
Video Game Consoles & Games Logo
18 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
