Question about McCulloch Garden
Proper spark plug - McCulloch Garden
  • Canwoodjc
    Canwoodjc May 28, 2011
    which motor and model number
  • 3,740 Answers
BM6F (Champion) or BM7A (NGK) of DJ8J (Oregon)
Posted on May 28, 2011
How to change spark plugs?
Spark plugs to be unscrewed properly and carefully out of place , and to make sure when you put back that it is done properly and in place slowly and easy by hand to make sure that you are doing it as per the threads in the engine , if threads go bad you will have a big problem to correct.
If the plugs have oil on them from the spark end , means the engine is kicking oil to the plugs and that could mean that the piston rings are weak.
You could always use the proper tools as attached to pull the plugs out
Jul 04, 2014 | 1997 Jaguar XJ6
Tip
How to Test Spark Plugs in Audi A6 car?
1) Test the spark plug ignition. For that disconnect the spark plug wire from the spark plug.
2) Then touch the spark plug wire close to a metal surface of the car. Then spin the key in ignition switch. If you will see a spark or hear a crackling noise. This means the wire to the spark plug has voltage in it.
3) If there is no spark when you crack the engine it means that a spark plug wire is dead.
4) Check out all the battery cable, ignition wires and coil wires are hooked up properly to their points.
5) If any of the battery cable, ignition wires and coil wires is loose then this can also relate to no spark.
6) But if all the battery cable, ignition wires and coil wires are properly connected then its time to replace the spark plugs.
7) Before replacing clean the old spark plugs connections and recheck.
8) Many a time’s cleaning or moving the spark plug connections makes it work.
9) If nothing is getting the spark plug to spark, then it needs replacement.
This will help. Thanks.
on Mar 15, 2010 | Audi A6 Cars & Trucks
Tip
How to Test Spark Plugs in car?
The procedure is as follows:--
1)Test the spark plug ignition. For that disconnect the spark plug wire from the spark plug.
2)Then touch the spark plug wire close to a metal surface of the car. Then spin the key in ignition switch. If you will see a spark or hear a crackling noise. This means the wire to the spark plug has voltage in it.
3)If there is no spark when you crack the engine it means that a spark plug wire is dead.
4)Check out all the battery cable, ignition wires and coil wires are hooked up properly to their points.
5)If any of the battery cable, ignition wires and coil wires is loose then this can also relate to no spark.
6)But if all the battery cable, ignition wires and coil wires are properly connected then its time to replace the spark plugs.
7)Before replacing clean the old spark plugs connections and recheck.
8)Many a time’s cleaning or moving the spark plug connections makes it work.
9)If nothing is getting the spark plug to spark, then it needs replacement.
on Mar 15, 2010 | Audi A4 Cars & Trucks
Did tune up on my 91 ford f150 302 5.0L V8 4x4 pick up which included s[ark plugs and wires, cap and rotor, oil change, new oil and air filters...now it is riding rougher and worse gas mileage than before?...
did you properly "gap" the spark plugs? many spark plugs have to have the ends properly "gapped" before installation, by using a "gapping" tool/wheel to properly space the arc gap to the correct distance.
if the plugs were properly gapped, or already came pre-gapped out of the box for your specific vehicle, then you may have air getting into the cylinders around the spark plugs. were you careful to properly tighten the spark plugs straightly into place, or is there a chance that you left one loose, or, even worse, cross-threaded one of the spark plugs?
Mar 26, 2011 | 1991 Ford F150
How to replace spark plugs in a kia sorento
The 2006 KIA Sorento is a smaller SUV with a 3.5-liter V6 engine. This engine uses six spark plugs to run the engine properly. There will be three spark plugs on each side of the engine. All six spark plugs will need to be changed at the same time to ensure that all six are working equally. The spark plugs are in plain sight on the right and left side of the engine and have rubber wires connected to the top of each one.
  1. 1 Insert the edge of the spark-plug gapping tool under the meal arm in the center of the one of the new spark plugs and turn the gapper until the number .038 is in the center of the metal arm. Repeat this for all other new spark plugs.
  2. 2 Open the hood of the 2006 KIA Sorento and remove a rubber wire from one of the spark plugs. Use the ratchet and spark-plug socket to remove that spark plug from the engine.
  3. 3 Insert the new spark plug into the hole where the old plug was. Hand-tighten the new spark plug until you are certain it is seated properly, then tighten it further using the ratchet and spark-plug socket. Replace the rubber wire to the top of the new spark plug.
  4. 4 Repeat for all other new spark plugs. Once you have replaced all six spark plugs and replace the rubber wires to the tops of them, close the hood.
Jan 21, 2011 | 2006 Kia Sorento
Tip
How to Test Spark Plugs in Audi car?
on Mar 15, 2010 | Audi A3 Cars & Trucks
No spark at plug hear cylinoid click but no spark at plug.350 yamaha warrior 1997
Just checking if your battery is fully charged, your coil is properly connected and ignition cables are properly seated and if you are still using carburator, the float are seating properly as not to flood the combustion chamber. The spark plugs are clean and properly gapped. I have found that if sprk plugs are not properly gapped at recommended gap, it may not give out sparks to burn compressed fuel.
Cheers. If you find this advise helpful, please give it a rating. Thanks
Dec 24, 2010 | Yamaha RD 350 Motorcycles
Need procedure to replace 6 spark plugs. Have been told it is a very labor intensive job.
unplug spark plug connector. using a proper tool to unscrew the spark plug. screw in new plug. plug in connector back to its proper position. just make sure the order is right.
Nov 08, 2009 | 2005 Hyundai Tucson
Spark plug
The proper air gap is .032 to .036 depending on spark plug brand.
Nov 10, 2008 | Harley Davidson XL 1200 C Sportster Custom...
Garden Logo
53 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
